【HC32L136 demo板】+软件模拟I2C时序读写24C04
今晚搞了一下软件模拟I2C时序读写24C04,终于成功了。代码:
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
#define uchar unsigned char
#define uint unsigned int
* Local type definitions ('typedef')
stc_gpio_config_t pstcGpioCfg;
* Local function prototypes ('static')
* Local variable definitions ('static') *
#define SDA_0 Gpio_ClrIO(GpioPortA, GpioPin12)
#define SDA_1 Gpio_SetIO(GpioPortA, GpioPin12)
#define SCL_0 Gpio_ClrIO(GpioPortA, GpioPin11)
#define SCL_1 Gpio_SetIO(GpioPortA, GpioPin11)
#define SDA Gpio_GetInputIO(GpioPortA, GpioPin12)
* Function implementation - global ('extern') and local ('static')
unsigned char buffer;
* 名 称: DelayMS()
* 功 能: 以毫秒为单位延时,系统时钟不配置时默认为16M(用示波器测量相当精确)
* 入口参数: msec 延时参数,值越大,延时越久
* 出口参数: 无
void DelayMS(uint msec)
uint i,j;
for (i=0; i<msec; i++)
for (j=0; j<535; j++);
void InitSDAInput(void)
///< 端口方向配置->输入
pstcGpioCfg.enDir = GpioDirIn;
///< 端口驱动能力配置->高驱动能力
pstcGpioCfg.enDrv = GpioDrvH;
///< 端口上下拉配置->无上下拉
pstcGpioCfg.enPuPd =GpioNoPuPd;
///< 端口开漏输出配置->开漏输出关闭
pstcGpioCfg.enOD = GpioOdDisable;
///< 端口输入/输出值寄存器总线控制模式配置->AHB
pstcGpioCfg.enCtrlMode = GpioAHB;
Gpio_Init(GpioPortA, GpioPin12, &pstcGpioCfg);
void InitSDAOutputH(void)
///< 端口方向配置->输出
pstcGpioCfg.enDir = GpioDirOut;
///< 端口上下拉配置->无上下拉
///< 端口开漏输出配置->开漏输出使能
pstcGpioCfg.enOD = GpioOdEnable;
Gpio_Init(GpioPortA, GpioPin12, &pstcGpioCfg); //SDA
void InitSDAOutputL(void)
///< 端口方向配置->输出
pstcGpioCfg.enDrv = GpioDrvL;
///< 端口上下拉配置->无上下拉
//函数名称:Delay()
//功 能:延时子程序
void Delay(unsigned char us)//5,7,9
char i;
while(--us)
for(i=0;i<25;i++);
//函数名称:Delayms()
void Delayms(unsigned int ims)
unsigned int i,j;
for(i=0;i<ims;i++)
for(j=0;j<265;j++) { Delay(1); }
void Start()
SCL_0;
InitSDAOutputH();
SDA_1;
Delay(5);
SCL_1;
Delay(5);
InitSDAOutputL();
SDA_0;
Delay(5);
SCL_0;
Delay(5);
void Stop()
SCL_0;
InitSDAOutputL();
SDA_0;
Delay(5);
SCL_1;
Delay(5);
InitSDAOutputH();
SDA_1;
Delay(5);
char ACK ()
char c,i=0;
InitSDAOutputH();
SDA_1;
Delay(5);
SCL_0;
Delay(5);
SCL_1;
Delay(5);
InitSDAInput();
Delay(5);
//if(SDA==1)
// c=1;
//else
// c=0;
while(SDA==1)
i++;
if(i>100)
break;
// InitSDAOutput();
Delay(5);
SCL_0;
return c;
void NOACK()//·ÇÓ¦´ðÐźÅ
InitSDAOutputH();
SDA_1;
SCL_0;
Delay(5);
SCL_1;
Delay(5);
SCL_0;
Delay(5);
void SendChar(unsigned char ch)
unsigned char i;
i=8;
do
if(ch&0x80)
InitSDAOutputH();
SDA_1;
else
InitSDAOutputL();
SDA_0;
Delay(5);
SCL_1;
Delay(5);
SCL_0;
Delay(5);
ch<<=1;
}while(--i!=0);
unsigned char RecChar()
unsigned char i,j;
i=8;
j=0;
InitSDAInput();
do
SCL_1;
Delay(5);
j=(j<<1);
if(SDA==1)
j=j|1;
Delay(5);
SCL_0;
Delay(5);
}while(--i!=0);
return j;
void WriteChar(unsigned int addr,unsigned char ch)
unsigned char c;
c=((*((unsigned char *)&addr))<<1)&0x02;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
SendChar(ch);
ACK();
Stop();
for(ch=0xff;ch!=0;ch--) ;
unsigned char ReadChar(unsigned int addr)
unsigned char ch;
ch=((*((unsigned char *)&addr))<<1)&0x02;
Start();
SendChar(0xa0|ch);
ACK();
SendChar(addr);
ACK();
Start();
SendChar(0xa1|ch);
ACK();
ch=RecChar();
NOACK();
Stop();
return ch;
** \briefMain function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
///< 打开GPIO外设时钟门控
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
///< 端口方向配置->输出
///< 端口上下拉配置->无上下拉
//Gpio_Init(GpioPortA, GpioPin12, &pstcGpioCfg); //SDA
Gpio_Init(GpioPortA, GpioPin11, &pstcGpioCfg); //SCL
//InitSDAOutput();
buffer=ReadChar(0);
Delay(100); //延时一段时间
WriteChar(0,0x55);
Delayms(20);
WriteChar(1,0xaa);
Delayms(20);
WriteChar(2,0x27);
Delayms(20);
buffer=ReadChar(1);
buffer=ReadChar(2);
buffer=ReadChar(0);
while(1)
效果图:
可是发现一个问题,PA12不好拉低,而PA11就可以。
PA11初始化:
///< 打开GPIO外设时钟门控
///< 端口方向配置->输出
///< 端口上下拉配置->无上下拉
这样可以正常拉高拉低。
可是PA12则不行。
我搞了一下,找了个不太好的办法。
拉高之前这么初始化:
///< 端口方向配置->输出
///< 端口上下拉配置->无上下拉
拉低之前这么初始化:
///< 端口方向配置->输出
///< 端口驱动能力配置->低驱动能力
///< 端口上下拉配置->无上下拉
就可以了。
不明白为什么。
请大神指教,谢谢!
楼主void InitSDAOutputH(void)和void InitSDAOutputL(void)是要初始化IO引脚并且初始化成高电平和低电平吗?
在上电后设置未输出的时候,需要先设置输出电平,再设置输出方向,这样才有初始化为指定的高电平或者低电平。
比如调用void InitSDAOutputL(void)之前,需要设置输出低:Gpio_ClrIO(GpioPortA, GpioPin12);或者Gpio_WriteOutputIO(GpioPortA, GpioPin12, FALSE);
pstcGpioCfg.enDrv; //这个设置驱动能力,是指引脚上的拉电流和灌电流的能力(强驱或者弱驱能力),不是指输出高低电平的意思。 谢谢分享! Gpio_Init(GpioPortA, GpioPin11, &pstcGpioCfg); //SCL
配置了呀 martinhu 发表于 2019-9-30 23:35
楼主void InitSDAOutputH(void)和void InitSDAOutputL(void)是要初始化IO引脚并且初始化成高电平和低电平吗 ...
那两个函数一个是输出高之前调用,一个是输出低之前调用,你没仔细看我的代码吧 第一次读,如果没写过,那就是0xff啊 谢谢分享的。 没有硬件iic吗 楼主自己开发的iic吗? 看着好复杂了。 {:lol:} qiufengsd 发表于 2020-1-10 20:48
没有硬件iic吗
有。 kmzuaz 发表于 2020-1-10 20:48
楼主自己开发的iic吗?
模拟时序呀 多谢分享,很有用 就是0xff啊 不是都是封装库函数吗 楼主,有个加代码的小工具,
发帖的时候,选用<>,可读性会很好 硬件的iic我也调试通过。用的轮训模式,没用中断模式。
页:
[1]
