第2个函数是做什么
1.PWM_1_Start(); 初始化和使能。
2. PWM_1_TriggerCommand(PWM_1_MASK, PWM_1_CMD_START);触发方式
新手 哪位能解释一下那个第2个函数是做什么
什么意思?不是很明白你说的什么,能再解释一下这个现象吗
似乎我去掉那个 对于结果也没有影响。
是的,根触摸按键的值进行变色的,可以看官网的视频讲解。
这个例程都是纯硬件的,可以好好看看。
好的,我明天去单位试一下,多谢各位大侠了哈 担心里面的内容会很容易读出 然后呢?你是怎么应对这个的呢
我用PSOC MiniProg 和 PSOC Programmer 3.12 灌程序的。
PSoC Designer 中project file里有一个flashsecurity.txt文件
都能设置哪些保护级别?
Unprotected
Factory upgrade
Field upgrade
Full protection 不懂,如何设置?
Unprotected
Factory upgrade
Field upgrade
Full protection
分别是什么功能?
; @Id: flashsecurity.txt#2 @
; Edit this file to adjust the Flash security for this project.
; Flash security is provided by marking a 64 byte block with a character
; that corresponds to the type of security for that block, given:
; W: Full (Write protected)
; R: Field Upgrade (Read protected)
; U: Unprotected
; F: Factory
; Note #1: Protection characters can be entered in upper or lower case.
; Note #2: Refer to the Flash Program Memory Protection section in the Data Sheet.
; Comments may be added similar to an assembly language comment, by
; Using the semicolon (;) followed by your comment.The comment extends
; to the end of the line.
; 0 40 80 C0 100 140 180 1C0 200 240 280 2C0 300 340 380 3C0 (+) Base Address
WWWWW W W W W W W W W W W W ; Base Address 0
WWWWW W W W W W W W W W W W ; Base Address 400
WWWWW W W W W W W W W W W W ; Base Address 800
WWWWW W W W W W W W W W W W ; Base Address C00
WWWWW W W W W W W W W W W W ; Base Address 1000
WWWWW W W W W W W W W W W W ; Base Address 1400
WWWWW W W W W W W W W W W W ; Base Address 1800
WWWWW W W W W W W W W W W W ; Base Address 1C00
WWWWW W W W W W W W W W W W ; Base Address 2000
WWWWW W W W W W W W W W W W ; Base Address 2400
WWWWW W W W W W W W W W W W ; Base Address 2800
WWWWW W W W W W W W W W W W ; Base Address 2C00
WWWWW W W W W W W W W W W W ; Base Address 3000
WWWWW W W W W W W W W W W W ; Base Address 3400
WWWWW W W W W W W W W W W W ; Base Address 3800
WWWWW W W W W W W W W W W W ; Base Address 3C00
; End 16K parts
你现在是W,就是 Full (Write protected)
如果允许重新多次灌程序,但不能让其他人读出我的代码,我该设置成那种呢?
除了U以外,其他都不能外部读
R可以内部写,F可以内部和外部写 好的,我明天去单位试一下,多谢各位大侠了哈
页:
[1]
