接收TX资料进而转换成PWM
695|11
 楼主| chuxh 发表于 2019-10-19 10:16 | 显示全部楼层 |阅读模式
TX部分传输没问题
但RX部分该怎么接收TX资料进而转换成PWM
并控制PWM的大小
morrisk 发表于 2019-10-19 10:20 | 显示全部楼层
你用的是什么
zyf部长 发表于 2019-10-19 10:24 | 显示全部楼层
你做的是什么啊
kangzj 发表于 2019-10-19 10:27 | 显示全部楼层
可以到官网建一个case
zwll 发表于 2019-10-19 10:31 | 显示全部楼层
楼主是根据接收的内容确定PWM的大小吧
 楼主| chuxh 发表于 2019-10-19 10:35 | 显示全部楼层
我自己写的RS232+ G-传感器程式
 楼主| chuxh 发表于 2019-10-19 23:53 | 显示全部楼层
----TX部分----
// Custom.c
//   Custom functions for insertion into PSoC Express projects, including fixed functions
#include <m8c.h>
#include "PSoCAPI.h"
#include "custom.h"
#define START        0xa5
#define X                0x41
#define Y                0x52
#define STOP        0x5a
const BYTE data[] ={ START, X, Y, STOP};
extern SYSTEM_VARS_STRUC SystemVars;
void delay(unsigned int x);
BOOL fWaitToTx(void);
BYTE A;
BYTE B;
//  CustomInit() is run after driver and channel instantiation functions, but before the main loop
void CustomInit( void )
// CustomPostInputUpdate() is run after input drivers have updated SystemVars, but before transfer
//   functions are evaluated.
void CustomPostInputUpdate( void )
// CustomPreOutputUpdate() is run after transfer functions have been evaluated, but before the output
//   driver are updated with values from SystemVars.
void CustomPreOutputUpdate( void )
        unsigned char i;
        Counter8_Start();
        TX8_Start(0);
        M8C_EnableGInt;
        A = PRT1DR;
        B = PRT1DR;
        //START
        TX8_SendData(START);
        if (fWaitToTx());
        //X
        if (SystemVars.ReadWriteVars.pse_XAxis < 0)
        A = (-SystemVars.ReadWriteVars.pse_XAxis >> 3) | 0x80;
    else
        A = (SystemVars.ReadWriteVars.pse_XAxis >> 3) & 0x7f;
        TX8_SendData(A);
        if (fWaitToTx());
        delay(100);
        //Y
        if (SystemVars.ReadWriteVars.pse_YAxis < 0)
        B = (-SystemVars.ReadWriteVars.pse_YAxis >> 3) | 0x80;
    else
        B = (SystemVars.ReadWriteVars.pse_YAxis >> 3) & 0x7f;
        TX8_SendData(B);
        if (fWaitToTx());
        //STOP
        TX8_SendData(STOP);
        if (fWaitToTx());
        delay(1000);
    BYTE bTxStatus;
        while ( !(bTxStatus = TX8_bReadTxStatus() & TX8_TX_COMPLETE));
        return (TRUE);
    unsigned i;
        for(i = 0; i < x; i++);
----RX部分----
// C main line
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#include "RX8.h"
#define        START        0xa5
#define        X        0x41
#define Y        0x52
#define        STOP        0x5a
#define RX_OK        0x01
BOOL fWaitToRx(void);
BYTE bRxData;
int j=0;
void main(void)
    unsigned char i;
        //--------RS232_RX---------
        Counter8_Start();
        RX8_DisableInt();
        RX8_Start(0);
        M8C_EnableGInt;
        //--------PWM---------
        DigBuf1_DisableInt();
        DigBuf2_DisableInt();
            PWM8_WritePeriod(120);
        PWM8_DisableInt();
        PWM8_Start();
        DigBuf3_DisableInt();
        DigBuf4_DisableInt();
            PWM81_WritePeriod(120);
        PWM81_DisableInt();
        PWM81_Start();
        while (1)
          if (fWaitToRx())
           if(bRxData)
             if (j == 0)
                    DigBuf1_Start();
                        DigBuf2_Stop();
                        DigBuf4_Start();
                        DigBuf3_Stop();
                for (i = 7; i <= 120; i++)
                        PWM8_WritePulseWidth(i);
                                PWM81_WritePulseWidth(i);
                        delay(2500);
                        for (i = 120; i >= 7; i--)
                        delay(2500);
                else
                    DigBuf1_Stop();
                        DigBuf2_Start();
                        DigBuf4_Stop();
                        DigBuf3_Start();
                        delay(2500);
                        delay(2500);
                j = 1 - j;
    BYTE bRxStatus;
    while ( !(bRxStatus = RX8_bReadRxStatus() & RX8_RX_COMPLETE));
        if ((bRxStatus & RX8_RX_NO_ERROR) == 0)
            bRxData = RX8_bReadRxData();
                return (TRUE);
        else
            bRxData = bRxStatus;
                return (FALSE);
   unsigned i;
houcs 发表于 2019-10-20 08:26 | 显示全部楼层
可以到官网建一个case
liuzaiy 发表于 2019-10-20 08:31 | 显示全部楼层
楼主是根据接收的内容确定PWM的大小吧
pangb 发表于 2019-10-20 08:34 | 显示全部楼层
写程序吧,根据斜率进行控制,搞一个公式出来
 楼主| chuxh 发表于 2019-10-20 08:37 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈
