EVB板点亮LCD屏
本帖最后由 Cjy_JDxy 于 2019-10-27 21:09 编辑今天捣鼓了一下EVB板,点亮了屏。
删掉common组里的文件:
烧写算法选这个:
代码:
* Include files
#include "lcd.h"
#include "lpm.h"
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
* Local function prototypes ('static')
* Local variable definitions ('static') *
* Function implementation - global ('extern') and local ('static')
void App_PortCfg(void);
void App_LcdCfg(void);
** \brief主函数
** @param无
** \retval 无
int32_t main(void)
Sysctrl_ClkSourceEnable(SysctrlClkRCL,TRUE); ///< 使能RCL时钟
Sysctrl_SetRCLTrim(SysctrlRclFreq32768); ///< 配置内部低速时钟频率为32.768kHz
Sysctrl_SetPeripheralGate(SysctrlPeripheralLcd,TRUE); ///< 开启LCD时钟
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);///< 开启GPIO时钟
App_PortCfg(); ///< LCD端口配置
App_LcdCfg(); ///< LCD模块配置
Lcd_ClearDisp(); ///< 清屏
Lcd_WriteRam(0,0x0f0f0f0f);///< 赋值寄存器LCDRAM0
Lcd_WriteRam(1,0x0f0f0f0f);///< 赋值寄存器LCDRAM1
while(1)
** \brief初始化外部GPIO引脚
** \return 无
Gpio_SetAnalogMode(EVB_LCD_COM0_PORT, EVB_LCD_COM0_PIN);//COM0
Gpio_SetAnalogMode(EVB_LCD_COM1_PORT, EVB_LCD_COM1_PIN);//COM1
Gpio_SetAnalogMode(EVB_LCD_COM2_PORT, EVB_LCD_COM2_PIN);//COM2
Gpio_SetAnalogMode(EVB_LCD_COM3_PORT, EVB_LCD_COM3_PIN);//COM3
Gpio_SetAnalogMode(EVB_LCD_SEG0_PORT, EVB_LCD_SEG0_PIN);//SEG0
Gpio_SetAnalogMode(EVB_LCD_SEG1_PORT, EVB_LCD_SEG1_PIN);//SEG1
Gpio_SetAnalogMode(EVB_LCD_SEG2_PORT, EVB_LCD_SEG2_PIN);//SEG2
Gpio_SetAnalogMode(EVB_LCD_SEG3_PORT, EVB_LCD_SEG3_PIN);//SEG3
Gpio_SetAnalogMode(EVB_LCD_SEG4_PORT, EVB_LCD_SEG4_PIN);//SEG4
Gpio_SetAnalogMode(EVB_LCD_SEG5_PORT, EVB_LCD_SEG5_PIN);//SEG5
Gpio_SetAnalogMode(EVB_LCD_SEG6_PORT, EVB_LCD_SEG6_PIN);//SEG6
Gpio_SetAnalogMode(EVB_LCD_SEG7_PORT, EVB_LCD_SEG7_PIN);//SEG7
Gpio_SetAnalogMode(EVB_LCD_VLCDH_PORT, EVB_LCD_VLCDH_PIN);//VLCDH
Gpio_SetAnalogMode(EVB_LCD_VLCD3_PORT, EVB_LCD_VLCD3_PIN);//VLCD3
Gpio_SetAnalogMode(EVB_LCD_VLCD2_PORT, EVB_LCD_VLCD2_PIN);//VLCD2
Gpio_SetAnalogMode(EVB_LCD_VLCD1_PORT, EVB_LCD_VLCD1_PIN);//VLCD1
** \brief配置LCD
** \return 无
stc_lcd_cfg_t LcdInitStruct;
stc_lcd_segcom_t LcdSegCom;
LcdSegCom.u32Seg0_31 = 0xffffff00; ///< 配置LCD_POEN0寄存器 开启SEG0~SEG7
LcdSegCom.stc_seg32_51_com0_8_t.seg32_51_com0_8 = 0xffffffff; ///< 初始化LCD_POEN1寄存器 全部关闭输出端口
LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Com0_3 = 0; ///< 使能COM0~COM3
LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Mux = 0; ///< Mux=0,Seg32_35=0,BSEL=1表示:选择外部电容工作模式,内部电阻断路
LcdSegCom.stc_seg32_51_com0_8_t.segcom_bit.Seg32_35 = 0;
Lcd_SetSegCom(&LcdSegCom); ///< LCD COMSEG端口配置
LcdInitStruct.LcdBiasSrc = LcdExtCap; ///< 电容分压模式,需要外部电路配合
LcdInitStruct.LcdDuty = LcdDuty4; ///< 1/4duty
LcdInitStruct.LcdBias = LcdBias3; ///< 1/3 BIAS
LcdInitStruct.LcdCpClk = LcdClk2k; ///< 电压泵时钟频率选择2kHz
LcdInitStruct.LcdScanClk = LcdClk128hz; ///< LCD扫描频率选择128Hz
LcdInitStruct.LcdMode = LcdMode0; ///< 选择模式0
LcdInitStruct.LcdClkSrc = LcdRCL; ///< LCD时钟选择RCL
LcdInitStruct.LcdEn = LcdEnable; ///< 使能LCD模块
Lcd_Init(&LcdInitStruct);
* EOF (not truncated)
效果图:
这个板子应该是L072 的板子吧,楼主应用L07x的flash download文件比较好,用136的文件不一定完全匹配 martinhu 发表于 2019-10-28 09:55
这个板子应该是L072 的板子吧,楼主应用L07x的flash download文件比较好,用136的文件不一定完全匹配 ...
【STEP1】打开【我的电脑】 ; 【STEP2】在地址栏输入地址 ftp://HdscCustomer:HdscGuest2019!@ftp.hdsc.com.cn/ 即可直接访问进入FTP后,可以拷贝对应的SDK,里面有驱动库样例,这那里面可以找到对应的FLM文件,然后把这个文件拷贝到KEIL安装目录下的ARM内的flash文件夹内。
martinhu 发表于 2019-10-28 16:45
【STEP1】打开【我的电脑】 ; 【STEP2】在地址栏输入地址 ftp://HdscCustomer:HdscGuest2019!@ftp.hdsc.c ...
谢谢
我把FlashHC32L07X_128K.FLM拷到C:\Keil_v5\ARM\Flash文件夹内,可是烧写算法里没有对应的算法。
原来那个可能有问题,你用这个试试 martinhu 发表于 2019-10-30 20:43
原来那个可能有问题,你用这个试试
谢谢! 非常感谢楼主分享 非常感谢楼主分享 非常感谢楼主分享 点亮之后显示数字应该很简单了吧 当然啦 不错的DEMO
页:
[1]
