merry_zsp 发表于 2019-10-31 09:50
keil51的STARTUP.A51解析
STARTUP.A51原始文件:
$NOMOD51;Ax51宏汇编器控制命令,禁止预定义的8051。使编译器不使能预定义的;8051符号,避免产生重复定义的错误。
;This file is part of the C51 Compiler package
;Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
;Version 8.01
;*** <<< Use Configuration Wizard in Context Menu >>> ***
;STARTUP.A51:This code is executed after processor reset.
;To translate this file use A51 with the following invocation:
;   A51 STARTUP.A51
;To link the modified STARTUP.OBJ file to your application use the following
;Lx51 invocation:
;   Lx51 your object file list, STARTUP.OBJcontrols
;User-defined <h> Power-On Initialization of Memory
;With the following EQU statements the initialization of memory
;at processor reset can be defined:
; <o> IDATALEN: IDATA memory size <0x0-0x100>
;   <i> Note: The absolute start-address of IDATA memory is always 0
;   <i>       The IDATA space overlaps physically the DATA and BIT areas.
IDATALEN      EQU   80H
; <o> XDATASTART: XDATA memory start address <0x0-0xFFFF>
;   <i> The absolute start address of XDATA memory
XDATASTART      EQU   0
; <o> XDATALEN: XDATA memory size <0x0-0xFFFF>
;   <i> The length of XDATA memory in bytes.
XDATALEN      EQU   0
; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF>
;   <i> The absolute start address of PDATA memory
PDATASTART      EQU   0H
; <o> PDATALEN: PDATA memory size <0x0-0xFF>
;   <i> The length of PDATA memory in bytes.
PDATALEN      EQU   0H
;</h>
;<h> Reentrant Stack Initialization
;The following EQU statements define the stack pointer for reentrant
;functions and initialized it:
; <h> Stack Space for reentrant functions in the SMALL model.
;<q> IBPSTACK: Enable SMALL model reentrant stack
;   <i> Stack space for reentrant functions in the SMALL model.
IBPSTACK      EQU   0       ; set to 1 if small reentrant is used.
;<o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF>
;   <i> Set the top of the stack to the highest location.
IBPSTACKTOP   EQU   0xFF +1   ; default 0FFH+1
; </h>
; <h> Stack Space for reentrant functions in the LARGE model.
;<q> XBPSTACK: Enable LARGE model reentrant stack
;   <i> Stack space for reentrant functions in the LARGE model.
XBPSTACK      EQU   0       ; set to 1 if large reentrant is used.
;<o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF>
XBPSTACKTOP   EQU   0xFFFF +1   ; default 0FFFFH+1
; </h>
; <h> Stack Space for reentrant functions in the COMPACT model.
;<q> PBPSTACK: Enable COMPACT model reentrant stack
;   <i> Stack space for reentrant functions in the COMPACT model.
PBPSTACK      EQU   0       ; set to 1 if compact reentrant is used.
;   <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF>
PBPSTACKTOP   EQU   0xFF +1   ; default 0FFH+1
; </h>
;</h>
;Memory Page for Using the Compact Model with 64 KByte xdata RAM
;<e>Compact Model Page Definition
;<i>Define the XDATA page used for PDATA variables.
;<i>PPAGE must conform with the PPAGE set in the linker invocation.
; Enable pdata memory page initalization
PPAGEENABLE   EQU   0       ; set to 1 if pdata object are used.
; <o> PPAGE number <0x0-0xFF>
; <i> uppermost 256-byte address of the page used for PDATA variables.
PPAGE         EQU   0
; <o> SFR address which supplies uppermost address byte <0x0-0xFF>
; <i> most 8051 variants use P2 as uppermost address byte
PPAGE_SFR       DATA    0A0H
; </e>
; Standard SFR Symbols
ACC   DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL   DATA    82H
DPH   DATA    83H
                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                RSEG    ?STACK
                DS      1
                EXTRN CODE (?C_START)
                PUBLIC?C_STARTUP
                CSEG    AT      0
        ?C_STARTUP:   LJMP    STARTUP1
                RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
                MOV   R0,#IDATALEN - 1
                CLR   A
IDATALOOP:      MOV   @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
                MOV   DPTR,#XDATASTART
                MOV   R7,#LOW (XDATALEN)
IF (LOW (XDATALEN)) <> 0
                MOV   R6,#(HIGH (XDATALEN)) +1
ELSE
                MOV   R6,#HIGH (XDATALEN)
ENDIF
                CLR   A
XDATALOOP:      MOVX    @DPTR,A
                INC   DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV   PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
                MOV   R0,#LOW (PDATASTART)
                MOV   R7,#LOW (PDATALEN)
                CLR   A
PDATALOOP:      MOVX    @R0,A
                INC   R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
                MOV   ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
                MOV   ?C_XBP,#HIGH XBPSTACKTOP
                MOV   ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
                MOV   ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV   SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
;<h> Code Banking
; <q> Select Bank 0 for L51_BANK.A51 Mode 4
#if 0
;   <i> Initialize bank mechanism to code bank 0 when using L51_BANK.A51 with Banking Mode 4.
EXTRN CODE (?B_SWITCH0)
                CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
#endif
;</h>
                LJMP    ?C_START
                END
merry_zsp 发表于 2019-10-31 09:51
翻译后的STARTUP.A51:
;该文件是C51编译器包的一部分
;版权所有(c)1988-2005 Keil Elektronik GmbH 和 Keil Software, Inc.
;版本 8.01
;*** <<< 在上下文菜单中使用配置向导 >>> ***
;STARTUP.A51:此代码在处理器复位后执行。
;要编译此文件,请调用A51使用以下配置:
;   A51 STARTUP.A51
;要将修改后的STARTUP.OBJ文件链接到您的应用程序,请使用以下命令
;Lx51 invocation:
;   Lx51您的目标文件列表,STARTUP.OBJ控件
;用户定义的头文件(.h) 内存的上电初始化
;用以下EQU语句初始化内存
;在处理器重置时可以定义:
; <o> IDATALEN: IDATA内存大小<0x0-0x100>
;   <i> 注意: IDATA存储器的绝对起始地址始终为0
;   <i>       IDATA空间在物理上与DATA和BIT区域重叠。
IDATALEN      EQU   80H
; <o> XDATASTART: XDATA存储器起始地址<0x0-0xFFFF>
;   <i> XDATA 存储器的绝对起始地址(不一定为0)
XDATASTART      EQU   0 ;XDATA 起始位置
; <o> XDATALEN: XDATA 内存大小 <0x0-0xFFFF>
;   <i> XDATA 内存的长度,以字节为单位。
XDATALEN      EQU   0 ; XDATA 结束位置(不设置XDATA)
; <o> PDATASTART: PDATA 存储器起始地址<0x0-0xFFFF>
;   <i> PDATA 存储器的绝对起始地址
PDATASTART      EQU   0H    ;PDATA 设置起始地址
; <o> PDATALEN: PDATA 内存大小 <0x0-0xFF>
;   <i> PDATA 内存的长度,以字节为单位。
PDATALEN      EQU   0H   ;设置PDATA结束为止(不设置 PDATA)
;</h>
;<h> 可重入堆栈初始化
;以下EQU语句定义了可重入函数的堆栈指针并对其进行了初始化:
; <h> 用于SMALL模型中的可重入函数的堆栈空间。
;<q> IBPSTACK: 启用SMALL模型可重入堆栈
;   <i> 在SMALL模型中为可重入函数堆栈空间。
IBPSTACK      EQU   0       ; 如果使用小重载,则设置为1。
;<o> IBPSTACKTOP: SMALL模型堆栈的结束地址 <0x0-0xFF>
;   <i> 将堆栈顶部设置为最高位置.
IBPSTACKTOP   EQU   0xFF +1   ; 默认 0FFH+1
; </h>
; <h> 堆栈空间用于LARGE模型中的可重入函数.
;<q> XBPSTACK: 启用LARGE模型可重入堆栈
;   <i> Stack 在LARGE模型中为可重入函数堆栈空间.
XBPSTACK      EQU   0       ; 如果使用大的重入,则设置为1。
;<o> XBPSTACKTOP: LARGE模型堆栈的结束地址 <0x0-0xFFFF>
;   <i> 将堆栈顶部设置为最高位置.
XBPSTACKTOP   EQU   0xFFFF +1   ; 默认 0FFFFH+1
; </h>
; <h> 用于COMPACT模型中的重入函数的堆栈空间.
;<q> PBPSTACK: 启用COMPACT模型可重入堆栈
;   <i> COMPACT模型中可重入函数的空间.
PBPSTACK      EQU   0       ; 如果使用紧凑重入,则设置为1.
;   <o> PBPSTACKTOP: COMPACT模型堆栈的结束地址 <0x0-0xFFFF>
;   <i> 将堆栈顶部设置为最高位置.
PBPSTACKTOP   EQU   0xFF +1   ; 默认 0FFH+1
; </h>
;</h>
;使用64 KB xteata RAM的紧凑型号的内存页面
;<e>紧凑型模型页面定义
;<i>定义用于PDATA变量的XDATA页面.
;<i>PAGE必须符合链接器调用中设置的PAGE.
; 启用数据存储页面初始化
PPAGEENABLE   EQU   0       ; 如果使用pdata对象,则设置为1.
; <o> 页码 <0x0-0xFF>
; <i> 用于PDATA变量的页面的最高256字节地址.
PPAGE         EQU   0
; <o> 提供最高地址字节的SFR地址 <0x0-0xFF>
; <i> 大多数8051变体使用P2作为最高地址字节
PPAGE_SFR       DATA    0A0H
; </e>
; 标准SFR(特殊功能寄存器)符号(寄存器定义声称别名)(sfr特殊功能寄存器 sfr也是一种扩充数据类型,点用一个内存单元,值域为0~255。利用它可以访问51单片机内部的所有特殊功能寄存器。)
ACC   DATA    0E0H;累加器
B       DATA    0F0H;通用寄存器
SP      DATA    81H;堆栈指针
DPL   DATA    82H;数据指针低8位
DPH   DATA    83H;数据指针高8位
                NAME    ?C_STARTUP;定义一个模块名: ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE;声明(ROM)代码段
?STACK          SEGMENT   IDATA;声明(RAM)堆栈
                RSEG    ?STACK;RSEG选择一个先前声明的可重定位段
                DS      1;位堆栈预留一个低阶的储存空间
                EXTRN CODE (?C_START);当前文件的代码储存区
                PUBLIC?C_STARTUP;声明可以用于其他目标模块的全局符号?C_STARTUP,用于和 C 链接在.src文件中可以看到这个符号
                CSEG    AT      0;选择代码存储区的一个绝对段,汇编从上面命令中的地址0开始执行这个段。
                RSEG    ?C_C51STARTUP;选择代码段?C_C51STARTUP
STARTUP1:      ;代码块STARTUP1
IF IDATALEN <> 0;如果IDATALEN不为零,则将长度减1送R0
                MOV   R0,#IDATALEN - 1    ;将长度-1送R0
                CLR   A                ;清零累加器
IDATALOOP:      MOV   @R0,A            ;初始化IDATA
                DJNZ    R0,IDATALOOP    ;(DJNZ)R0减1后不为0则转移(跳转)IDATALOOP
ENDIF
IF XDATALEN <> 0;如果有外部数据储存区 XDATALEN为外部空间的长度
                MOV   DPTR,#XDATASTART;起始地址送DPTR
                MOV   R7,#LOW (XDATALEN);长度的低8位送到R7
IF (LOW (XDATALEN)) <> 0    ;长度的低8位不为零继续
                MOV   R6,#(HIGH (XDATALEN)) +1;高8位+1送R6,下面清0用
ELSE                        ;长度的低8位为零继续
                MOV   R6,#HIGH (XDATALEN);高8位直接送R6,下面清0用
ENDIF
                CLR   A    ;清零累加器
XDATALOOP:      MOVX    @DPTR,A;XDATA环节 送A(清零累加器)的数据到单片机外部(ROM)(DPTR是16位地址位)
                INC   DPTR;数据指针加 1
                DJNZ    R7,XDATALOOP;R7减1后不为0则转移XDATALOOP
                DJNZ    R6,XDATALOOP;R6减1后不为0则转移XDATALOOP
ENDIF
IF PPAGEENABLE <> 0;外部ram页面地址使能,(pdata   --->   分页寻址片外ram (MOVX @R0))
                MOV   PPAGE_SFR,#PPAGE;上面一条成立,PPAGE_SFR设置为大多数8051变体使用P2作为最高地址字节,如果不成立,说明没有使用
ENDIF
IF PDATALEN <> 0;判断外部PDATA的长度是否为0(有没有配置外部RAM),如果不为零(使用了外部RAM),则进行下面的操作。
                MOV   R0,#LOW (PDATASTART);获取外部的RAM(PDATA)起始地址的低8位
                MOV   R7,#LOW (PDATALEN);获取外部的RAM(PDATA)长度的低8位
                CLR   A;清零累加器
PDATALOOP:      MOVX    @R0,A;PDATA环节,送A(清零累加器)的数据到单片机外部(RAM)(@R0是8位地址位)
                INC   R0;数据指针加 1
                DJNZ    R7,PDATALOOP;R7减1后不为0则转移PDATALOOP
ENDIF
IF IBPSTACK <> 0;可重载的模拟栈设置:http://www.21ic.com/jichuzhishi/mcu/questions/2018-05-02/759519.html
EXTRN DATA (?C_IBP);使用其他目标模块中定义的?C_IBP(模拟栈指针)(.M51文件中)
                MOV   ?C_IBP,#LOW IBPSTACKTOP;模拟栈指针指向栈顶
ENDIF
IF XBPSTACK <> 0 ;Large模式下使能模拟栈
EXTRN DATA (?C_XBP)
               ;栈指针指向栈顶
ENDIF
IF PBPSTACK <> 0 ;COMPACT模式下的模拟栈
EXTRN DATA (?C_PBP)
                MOV   ?C_PBP,#LOW PBPSTACKTOP;指向栈顶
ENDIF
                MOV   SP,#?STACK-1;硬件栈SP赋值
; 如果您将L51_BANK.A51与Banking Mode 4一起使用,则需要此代码
;<h> 代码银行
; <q> 为L51_BANK.A51模式4选择Bank 0
#if 0
;   <i> 在银行模式4下使用L51_BANK.A51时,将银行机制初始化为代码库0.
                CALL    ?B_SWITCH0      ; 代码银行0的初始银行机制
#endif
;</h>
                LJMP    ?C_START ;执行main函数
                END
tfqi 发表于 2019-11-13 12:46
非常不错的资料
wiba 发表于 2019-11-13 12:55
非常感谢楼主分享
zljiu 发表于 2019-11-13 13:04
非常感谢楼主分享
coshi 发表于 2019-11-13 13:12
非常感谢楼主分享
页: [1]
查看完整版本: keil51的STARTUP.A51解析
