拖拉机小司机 发表于 2019-11-8 09:32
CC1101 发送数据成功, 接受不到数据,MISO一直有方波,GDO0有触发信号,
PIC16F690代+CC1101代码
* File:   main.c
* Author: sz
* Created on 2019年10月30日, 上午9:03
#include<pic.h>
#include <stdlib.h>
#include<math.h>
//#pragma config FOSC = EXTRCIO   // Oscillator Selection bits (RCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN)
//#pragma config WDTE = ON      // Watchdog Timer Enable bit (WDT enabled)
//#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
//#pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is MCLR)
//#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
//#pragma config CPD = OFF      // Data Code Protection bit (Data memory code protection is disabled)
//#pragma config BOREN = OFF       // Brown-out Reset Selection bits (BOR enabled)
//#pragma config IESO = ON      // Internal External Switchover bit (Internal External Switchover mode is enabled)
//#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
//#include <xc.h>
#pragma config FOSC = LP      // Oscillator Selection bits (LP oscillator: Low-power crystal on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN)
#pragma config WDTE = OFF      // Watchdog Timer Enable bit (WDT enabled)
#pragma config BOREN = ON       // Brown-out Reset Selection bits (BOR enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define                INT8U                unsigned char
#define                INT16U                unsigned int
INT16U ge,shi,bai,qian,count0;
#defineWRITE_BURST         0x40        //连续写入
#defineREAD_SINGLE         0x80        //读
#defineREAD_BURST          0xC0        //连续
#defineBYTES_IN_RXFIFO   0x7F        //接收缓冲区的有效字节数
#defineCRC_OK            0x80         //CRC校验通过位标志
#defineMOSI_0   RB4=0
#defineMOSI_1   RB4=1
//===================================SPI时钟端口================================
#defineSCK_0      RC2=0
#defineSCK_1      RC2=1
//==================================SPI使能端口=================================
#defineCSN_0      RC0=0
#defineCSN_1      RC0=1
//    MISO=RC1;
//    GDO0=RA2;
INT8U PaTabel = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};
void SpiInit(void);
void CpuInit(void);
void RESET_CC1100(void);
void POWER_UP_RESET_CC1100(void);
void halSpiWriteReg(INT8U addr, INT8U value);
void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
void halSpiStrobe(INT8U strobe);
INT8U halSpiReadReg(INT8U addr);
void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
INT8U halSpiReadStatus(INT8U addr);
void halRfWriteRfSettings(void);
void halRfSendPacket(INT8U *txBuffer, INT8U size);
INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
//*************************寄存器映射******************************************
#define CCxxx0_IOCFG2       0x00      // GDO2 output pin configuration
#define CCxxx0_IOCFG1       0x01      // GDO1 output pin configuration
#define CCxxx0_IOCFG0       0x02      // GDO0 output pin configuration
#define CCxxx0_FIFOTHR      0x03      // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1      0x04      // Sync word, high INT8U
#define CCxxx0_SYNC0      0x05      // Sync word, low INT8U
#define CCxxx0_PKTLEN       0x06      // Packet length
#define CCxxx0_PKTCTRL1   0x07      // Packet automation control
#define CCxxx0_PKTCTRL0   0x08      // Packet automation control
#define CCxxx0_ADDR         0x09      // Device address
#define CCxxx0_CHANNR       0x0A      // Channel number
#define CCxxx0_FSCTRL1      0x0B      // Frequency synthesizer control
#define CCxxx0_FSCTRL0      0x0C      // Frequency synthesizer control
#define CCxxx0_FREQ2      0x0D      // Frequency control word, high INT8U
#define CCxxx0_FREQ1      0x0E      // Frequency control word, middle INT8U
#define CCxxx0_FREQ0      0x0F      // Frequency control word, low INT8U
#define CCxxx0_MDMCFG4      0x10      // Modem configuration
#define CCxxx0_MDMCFG3      0x11      // Modem configuration
#define CCxxx0_MDMCFG2      0x12      // Modem configuration
#define CCxxx0_MDMCFG1      0x13      // Modem configuration
#define CCxxx0_MDMCFG0      0x14      // Modem configuration
#define CCxxx0_DEVIATN      0x15      // Modem deviation setting
#define CCxxx0_MCSM2      0x16      // Main Radio Control State Machine configuration
#define CCxxx0_MCSM1      0x17      // Main Radio Control State Machine configuration
#define CCxxx0_MCSM0      0x18      // Main Radio Control State Machine configuration
#define CCxxx0_FOCCFG       0x19      // Frequency Offset Compensation configuration
#define CCxxx0_BSCFG      0x1A      // Bit Synchronization configuration
#define CCxxx0_AGCCTRL2   0x1B      // AGC control
#define CCxxx0_AGCCTRL1   0x1C      // AGC control
#define CCxxx0_AGCCTRL0   0x1D      // AGC control
#define CCxxx0_WOREVT1      0x1E      // High INT8U Event 0 timeout
#define CCxxx0_WOREVT0      0x1F      // Low INT8U Event 0 timeout
#define CCxxx0_WORCTRL      0x20      // Wake On Radio control
#define CCxxx0_FREND1       0x21      // Front end RX configuration
#define CCxxx0_FREND0       0x22      // Front end TX configuration
#define CCxxx0_FSCAL3       0x23      // Frequency synthesizer calibration
#define CCxxx0_FSCAL2       0x24      // Frequency synthesizer calibration
#define CCxxx0_FSCAL1       0x25      // Frequency synthesizer calibration
#define CCxxx0_FSCAL0       0x26      // Frequency synthesizer calibration
#define CCxxx0_RCCTRL1      0x27      // RC oscillator configuration
#define CCxxx0_RCCTRL0      0x28      // RC oscillator configuration
#define CCxxx0_FSTEST       0x29      // Frequency synthesizer calibration control
#define CCxxx0_PTEST      0x2A      // Production test
#define CCxxx0_AGCTEST      0x2B      // AGC test
#define CCxxx0_TEST2      0x2C      // Various test settings
#define CCxxx0_TEST1      0x2D      // Various test settings
#define CCxxx0_TEST0      0x2E      // Various test settings
// Strobe commands
#define CCxxx0_SRES         0x30      // Reset chip.
#define CCxxx0_SFSTXON      0x31      // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
                                        // If in RX/TX: Go to a wait state where only the synthesizer is
                                        // running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF      0x32      // Turn off crystal oscillator.
#define CCxxx0_SCAL         0x33      // Calibrate frequency synthesizer and turn it off
                                        // (enables quick start).
#define CCxxx0_SRX          0x34      // Enable RX. Perform calibration first if coming from IDLE and
                                        // MCSM0.FS_AUTOCAL=1.
#define CCxxx0_STX          0x35      // In IDLE state: Enable TX. Perform calibration first if
                                        // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
                                        // Only go to TX if channel is clear.
#define CCxxx0_SIDLE      0x36      // Exit RX / TX, turn off frequency synthesizer and exit
                                        // Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC         0x37      // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR         0x38      // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD         0x39      // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX         0x3A      // Flush the RX FIFO buffer.
#define CCxxx0_SFTX         0x3B      // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST      0x3C      // Reset real time clock.
#define CCxxx0_SNOP         0x3D      // No operation. May be used to pad strobe commands to two
                                        // INT8Us for simpler software.
#define CCxxx0_PARTNUM      0x30
#define CCxxx0_VERSION      0x31
#define CCxxx0_FREQEST      0x32
#define CCxxx0_LQI          0x33
#define CCxxx0_RSSI         0x34
#define CCxxx0_MARCSTATE    0x35
#define CCxxx0_WORTIME1   0x36
#define CCxxx0_WORTIME0   0x37
#define CCxxx0_PKTSTATUS    0x38
#define CCxxx0_VCO_VC_DAC   0x39
#define CCxxx0_TXBYTES      0x3A
#define CCxxx0_RXBYTES      0x3B
#define CCxxx0_PATABLE      0x3E
#define CCxxx0_TXFIFO       0x3F
#define CCxxx0_RXFIFO       0x3F
//********************配置CC1101寄存器*************************
typedef struct S_RF_SETTINGS
        INT8U FSCTRL2;                //
    INT8U FSCTRL1;   // Frequency synthesizer control.
    INT8U FSCTRL0;   // Frequency synthesizer control.
    INT8U FREQ2;   // Frequency control word, high INT8U.
    INT8U FREQ1;   // Frequency control word, middle INT8U.
    INT8U FREQ0;   // Frequency control word, low INT8U.
    INT8U MDMCFG4;   // Modem configuration.
    INT8U MDMCFG3;   // Modem configuration.
    INT8U MDMCFG2;   // Modem configuration.
    INT8U MDMCFG1;   // Modem configuration.
    INT8U MDMCFG0;   // Modem configuration.
    INT8U CHANNR;    // Channel number.
    INT8U DEVIATN;   // Modem deviation setting (when FSK modulation is enabled).
    INT8U FREND1;    // Front end RX configuration.
    INT8U FREND0;    // Front end RX configuration.
    INT8U MCSM0;   // Main Radio Control State Machine configuration.
    INT8U FOCCFG;    // Frequency Offset Compensation Configuration.
    INT8U BSCFG;   // Bit synchronization Configuration.
    INT8U AGCCTRL2;// AGC control.
        INT8U AGCCTRL1;// AGC control.
    INT8U AGCCTRL0;// AGC control.
    INT8U FSCAL3;    // Frequency synthesizer calibration.
    INT8U FSCAL2;    // Frequency synthesizer calibration.
        INT8U FSCAL1;    // Frequency synthesizer calibration.
    INT8U FSCAL0;    // Frequency synthesizer calibration.
    INT8U FSTEST;    // Frequency synthesizer calibration control
    INT8U TEST2;   // Various test settings.
    INT8U TEST1;   // Various test settings.
    INT8U TEST0;   // Various test settings.
    INT8U IOCFG2;    // GDO2 output pin configuration
    INT8U IOCFG0;    // GDO0 output pin configuration
    INT8U PKTCTRL1;// Packet automation control.
    INT8U PKTCTRL0;// Packet automation control.
    INT8U ADDR;      // Device address.
    INT8U PKTLEN;    // Packet length.
} RF_SETTINGS;
const RF_SETTINGS rfSettings =
    0x00,
    0x06,   // FSCTRL1频率合成器的控制
    0x00,   // FSCTRL0频率合成器的控制
    0x10,   // FREQ2    频率控制字,高字节
    0xA7,   // FREQ1    频率控制字,中间字节
    0x62,   // FREQ0    频率控制字,低字节
    0x5B,   // MDMCFG4调制解调器配置
    0xF8,   // MDMCFG3调制解调器配置
    0x03,   // MDMCFG2调制解调器配置
    0x22,   // MDMCFG1调制解调器配置
    0xF8,   // MDMCFG0调制解调器配置
    0x00,   // CHANNR    频道号码
    0x47,   // DEVIATN   现代偏差设置(如果启用了移频键控调制)
    0x56,   // FREND1    阵线end x光或类型
    0x10,   // FREND0    阵线end x光或类型
    0x18,   // MCSM0   主要的无线电控制状态机配置
    0x16,   // FOCCFG    频率偏移补偿配置
    0x6C,   // BSCFG   比特同步配置
    0x03,   // AGCCTRL2自动增益控制
    0x40,   // AGCCTRL1自动增益控制
    0x91,   // AGCCTRL0自动增益控制
    0xEA,   // FSCAL3    频率合成器校准
    0x2A,   // FSCAL2    频率合成器校准
    0x00,   // FSCAL1    频率合成器校准
    0x1F,   // FSCAL0    频率合成器校准
    0x59,   // FSTEST    频率合成器校准
    0x88,   // TEST2   各种测试设置
    0x31,   // TEST1   各种测试设置
    0x09,   // TEST0   各种测试设置
    0x29,   // IOCFG2    GDO2输出管脚排列
    0x06,   // IOCFG0D   GDO0输出管脚排列。
            // 指SmartRF吗?工作室用户手册详细伪寄存器的解释
    0x04,   // PKTCTRL1包自动化控制
    0x05,   // PKTCTRL0包自动化控制
    0x00,   // ADDR      设备地址
    0x0c    // PKTLEN    数据包长度
static void delay(unsigned int s)
        unsigned int i;
        for(i=0; i<s; i++);
        for(i=0; i<s; i++);
void halWait(INT16U timeout) //18us
char i;
    do {
       for(i=0; i<2; i++);
    } while (--timeout);
//****************************SPI接口初始化***************************
void SpiInit(void)
   ANS4=0;      // CSN
   ANS6=0;      // SCLK
   ANS10=0;   // SI
   TRISC0=0;    // CSN   输出
   TRISC2=0;    // SCLK输出
   RC0=0;
   RC2=0;
   RC0=1;
   TRISB4=0;    //SI输出
   TRISC1=1;    // SO输入
   TRISA2=1;    // GDO0 输入
//***********************SPI初始化***********************
void CpuInit(void)
        SpiInit();
        delay(5000);
//函数名:SpisendByte(INT8U dat)
//输入:发送的数据
//输出:无
//功能描述:SPI发送一个字节
INT8U SpiTxRxByte(INT8U dat)
//----------------------以下是模拟SPI时序方式-----------------------------------
        INT8U i,temp;
        temp = 0;
        SCK_0 ;
        for(i=0; i<8; i++)
                if(dat&0x80)
              MOSI_1;
                else
                   MOSI_0;
                dat <<= 1;
                SCK_1;
         halWait(2);
                temp <<= 1;
        if(RC1==1)temp++;//读取MISO状态
                SCK_0 ;
          halWait(2);
        return temp;
//函数名:void RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:复位CC1100
        CSN_0 ;
        while (RC1==1);
    SpiTxRxByte(CCxxx0_SRES);                 //写入复位命令
        while (RC1==1);
      CSN_1;
//函数名:void POWER_UP_RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:上电复位CC1100
        CSN_1;
        halWait(1);
        CSN_0 ;
        halWait(1);
        CSN_1;
        halWait(41);
        RESET_CC1100();                   //复位CC1100
//函数名:void halSpiWriteReg(INT8U addr, INT8U value)
//输入:地址和配置字
//输出:无
//功能描述:SPI写寄存器
    CSN_0;
    while(RC1==1);
    SpiTxRxByte(addr);                //写地址
    SpiTxRxByte(value);                //写入配置
    CSN_1;
//函数名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,写入缓冲区,写入个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i, temp;
    temp = addr | WRITE_BURST;
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
    for (i = 0; i< count; i++)
      SpiTxRxByte(buffer);
    CSN_1;
// ****************************SPI写命令******************************
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(strobe);                //写入命令
    CSN_1;
//函数名:INT8U halSpiReadReg(INT8U addr)
//输入:地址
//输出:该寄存器的配置字
//功能描述:SPI读寄存器
    INT8U value,temp;
        temp = addr | READ_SINGLE;                //写入要读的状态寄存器的地址同时写入读命令
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
        value = SpiTxRxByte(0);
        CSN_1;
        return value;
//******************************SPI连续读配置寄存器***********************
    INT8U i,temp;
        temp = addr | READ_BURST;                //写入要读的配置寄存器地址和读命令
    CSN_0;
    while (RC1==1);
        SpiTxRxByte(temp);
    for (i = 0; i < count; i++)
      buffer = SpiTxRxByte(0);
    CSN_1;
//************************SPI读状态寄存器****************************
    INT8U value,temp;
        temp = addr | READ_BURST;                //写入要读的状态寄存器的地址同时写入读命令
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
        CSN_1;
        return value;
//****************配置CC1101的寄存器*******************
halSpiWriteReg(CCxxx0_FSCTRL0,rfSettings.FSCTRL2);//×???????
delay(50);
    // Write register settings
    halSpiWriteReg(CCxxx0_FSCTRL1,rfSettings.FSCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCTRL0,rfSettings.FSCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ2,    rfSettings.FREQ2);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ1,    rfSettings.FREQ1);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ0,    rfSettings.FREQ0);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG4,rfSettings.MDMCFG4);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG3,rfSettings.MDMCFG3);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG2,rfSettings.MDMCFG2);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG1,rfSettings.MDMCFG1);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG0,rfSettings.MDMCFG0);
    delay(50);
    halSpiWriteReg(CCxxx0_CHANNR,   rfSettings.CHANNR);
    delay(50);
    halSpiWriteReg(CCxxx0_DEVIATN,rfSettings.DEVIATN);
    delay(50);
    halSpiWriteReg(CCxxx0_FREND1,   rfSettings.FREND1);
    delay(50);
    halSpiWriteReg(CCxxx0_FREND0,   rfSettings.FREND0);
    delay(50);
    halSpiWriteReg(CCxxx0_MCSM0 ,   rfSettings.MCSM0 );
    delay(50);
    halSpiWriteReg(CCxxx0_FOCCFG,   rfSettings.FOCCFG);
    delay(50);
    halSpiWriteReg(CCxxx0_BSCFG,    rfSettings.BSCFG);
    delay(50);
    halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
    delay(50);
        halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCAL3,   rfSettings.FSCAL3);
    delay(50);
        halSpiWriteReg(CCxxx0_FSCAL2,   rfSettings.FSCAL2);
    delay(50);
        halSpiWriteReg(CCxxx0_FSCAL1,   rfSettings.FSCAL1);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCAL0,   rfSettings.FSCAL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FSTEST,   rfSettings.FSTEST);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST2,    rfSettings.TEST2);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST1,    rfSettings.TEST1);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST0,    rfSettings.TEST0);
    delay(50);
    halSpiWriteReg(CCxxx0_IOCFG2,   rfSettings.IOCFG2);
    halSpiWriteReg(CCxxx0_IOCFG0,   rfSettings.IOCFG0);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_ADDR,   rfSettings.ADDR);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTLEN,   rfSettings.PKTLEN);
//函数名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
//输入:发送的缓冲区,发送数据个数
//输出:无
//功能描述:CC1100发送一组数据
    halSpiWriteReg(CCxxx0_TXFIFO, size);
    halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size);        //写入要发送的数据
    halSpiStrobe(CCxxx0_STX);                //进入发送模式发送数据
    // Wait for GDO0 to be set -> sync transmitted
    //while (!(RA2==1));
    // Wait for GDO0 to be cleared -> end of packet
    //while (RA2==1);
    halWait(1500);
        halSpiStrobe(CCxxx0_SFTX);
void setRxMode(void)
    halSpiStrobe(CCxxx0_SRX);                //进入接收状态
    INT8U status;
    INT8U packetLength;
        INT8U i=(*length)*4;// ?????à?????ù??datarate??length?????¨
    halSpiStrobe(CCxxx0_SRX);                //????????×???
        //delay(5);
    //while (!GDO1);
    //while (GDO1);
        delay(2);
        while (1)
                delay(2);
                --i;
                if(i<1)
                   return 0;
    if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //????????×?????????0
      packetLength = halSpiReadReg(CCxxx0_RXFIFO);//??????????×???????×??????????????¤??
      if (packetLength <= *length)                 //?????ù???????§?????¤??????????????????????°ü???¤??
            halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //?????ù??????????????
            *length = packetLength;                                //°??????????¤???????????±?°???????¤??
            // Read the 2 appended status bytes (status = RSSI, status = LQI)
            halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2);         //????CRC???é??
                        halSpiStrobe(CCxxx0_SFRX);                //??????????????
            return (status & CRC_OK);                        //???????é????????????????
               else
            return 0;
        else
        return 0;
void IO_init()
//OSCCON = 0x75;//内部晶振选为8M
OSCCON = 0x65;//内部晶振选为4M
TRISA=0x00;
PORTA=0x01;
TRISB=0x00;
PORTB=0x00;
TRISC=0x00;
PORTC=0x00; //把所有的引脚设置为输出,低电平。
RA3=1; // MCLR引脚必须处于逻辑高电平
RC5=0; //控制CC1101供电 1关闭 0开启
RB7=1; //关闭ADC供电
void main()
    INT8U leng =0;
    count0=0;
        INT8U TxBuf={0};
        INT8U RxBuf={0};
    RA0=1;
    IO_init();
        CpuInit();
    RA0=1;
        POWER_UP_RESET_CC1100();
        halRfWriteRfSettings();
        halSpiWriteBurstReg(CCxxx0_PATABLE,PaTabel, 8);
    TxBuf = 0x01 ;
        TxBuf = 0x01 ;
    RxBuf = 0x01 ;
    while(1)
       // halRfSendPacket(TxBuf,8);
      leng =8;
      if(halRfReceivePacket(RxBuf,leng))
      //if(1)
         if(RxBuf==0x01)
            RA0=0;
                      delay(800);
                          RA0=1;
            delay(800);
            RA0=0;
                      delay(800);
                          RA0=1;
            delay(800);
            RxBuf = 0xff;
            RA0=1;
                  RxBuf = 0xff;
            halSpiStrobe(CCxxx0_SIDLE );
            delay(100);
拖拉机小司机 发表于 2019-11-8 09:35
求各位大哥指导一下,头发快挠完了
linxi6414 发表于 2019-11-13 15:10
楼主你的空中速率是多少?请看我的贴子,我的空中速率为250K的,正常,想改为2.4K的,就是改不好,你的调通了吗?
楼主你的空中速率是多少?请看我的贴子,我的空中速率为250K的,正常,想改为2.4K的,就是改不好,你的调通 ...
就是问题一直没解决
就是问题一直没解决
准备直接买一个成品的串口模块,然后把SPI协议读出来,分析一下看看。
页: [1]
查看完整版本: CC1101 发送数据成功, 接受不到数据,MISO一直有方波,GDO0有触发信号,
