llljh 发表于 2019-11-8 22:25
调用的时候发现写数据有问题
用cypress的USB通信库封装一个动态库供上层调用。小弟写了一个,可是调用的时候发现写数据有问题。
zwll 发表于 2019-11-8 22:35
cyusb.dll吗? 参考这个?http://www.cypress.com/documentation/application-notes-obsolete/an14557-introduction-cyusbdll-based-application-development
stly 发表于 2019-11-8 22:46
什么问题
llljh 发表于 2019-11-8 22:50
写两次才有一次返回
dingy 发表于 2019-11-8 22:53
正常情况应该是每次都有数据返回?
llljh 发表于 2019-11-8 22:56
是啊,请大家帮帮看看,哪里有问题,谢谢。
//打开USB端口
int CUSBPrintDLL::Open()
int i = 0;
int iDeviceNum = 0;
//获取设备数目
iDeviceNum = m_pUSBDevice->DeviceCount();
// make sure there is at lesat one device out there
if (iDeviceNum == 0)
return 1;
// search for all connected devices
for ( i = 0; i < iDeviceNum; i++)
//Only Get the Bulkloop back compatinle device
m_pUSBDevice->Open(i);
//Get config descriptor
USB_CONFIGURATION_DESCRIPTOR ConfDesc;
m_pUSBDevice->GetConfigDescriptor(&ConfDesc);
// Number of interface one
if(ConfDesc.bNumInterfaces == 1)
   //Get Interface descriptor
   USB_INTERFACE_DESCRIPTOR IntfDesc;
   m_pUSBDevice->GetIntfcDescriptor(&IntfDesc);
   if(IntfDesc.bAlternateSetting == 0)
    // Number of endpoint is 2
    if(IntfDesc.bNumEndpoints == 2)
   m_DeviceIndex = i;
   break;
}//if number
}//for
//无符合要求的设备
if (i == iDeviceNum)
return 1;
m_pUSBDevice->Open(m_DeviceIndex);
//获取所有端点
int epts = m_pUSBDevice->EndPointCount();
CCyUSBEndPoint *endpt;
for (i=1; i<epts; i++)
endpt = m_pUSBDevice->EndPoints;
if (endpt->Attributes == 2)    // Bulk
   if (endpt->Address & 0x80)
    m_pInEndPt =m_pUSBDevice->EndPoints;
   else
    m_pOutEndPt = m_pUSBDevice->EndPoints;
//设置读、写超时时间
m_pOutEndPt->TimeOut = 0;
m_pInEndPt->TimeOut = 0;
m_pOutEndPt->TimeOut = 2000;
m_pInEndPt->TimeOut = 2000;
//设置可用标记
m_bEnable = true;
return 0;
//往USB端口发送数据
LONG CUSBPrintDLL::Write( const char *buffer,LONG length )
if (!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
return 0;
LONG lBufLen = length;
if(!m_pOutEndPt->XferData((PUCHAR)buffer,lBufLen))
m_pUSBDevice->Reset();
return 0;
return lBufLen;
//从USB端口读取数据
LONG CUSBPrintDLL::Read( char *buffer,LONG length )
//未进行初始化
if(!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
return 0;
if (!m_pInEndPt->XferData((PUCHAR)buffer,length))
return 0;
return length;
页: [1]
查看完整版本: 调用的时候发现写数据有问题
