STC单片机读取DHT11在1602上面显示乱码
编译后10K#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uintunsigned int
#define DataPort P0
bit ReadTempFlag;
bit ReadRHFlag;
bit ReadVFlag;
sbit RS = P2^4;
sbit RW = P2^5;
sbit EN = P2^6;
sbit DQ=P3^3;
sbit DHT=P3^6;
char dat_t,dat_v,dat_s;
bit ReadTmpFlag,ReadRHFlag,OVERFLOWFLAG;
void Delay_Us(unsigned char t)
while(--t);
void Delay_Ms(unsigned char t)
while(t--)
Delay_Us(245);
Delay_Us(245);
bit Init_DS18B20(void)
bit dat=0;
DQ = 1;
Delay_Us(5);
DQ = 0;
Delay_Us(200);
Delay_Us(200);
DQ = 1;
Delay_Us(50);
dat=DQ;
Delay_Us(25);
return dat;
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0;
dat>>=1;
DQ = 1;
if(DQ)
dat|=0x80;
Delay_Us(25);
return(dat);
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Delay_Us(25);
DQ = 1;
dat>>=1;
Delay_Us(25);
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned int b=0;
unsigned int t=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Delay_Ms(10);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
b<<=8;
t=a+b;
return(t);
void DHT_Start()
DHT = 1;
Delay_Us(2);
DHT = 0;
Delay_Ms(30);
DHT = 1;
Delay_Us(30);
uchar DHT_rec_byte()
uchar i,dat=0;
for(i=0;i<8;i++)
while(!DHT);
Delay_Us(8);
dat<<=1;
if(DHT==1)
dat+=1;
while(DHT);
return dat;
void DHT_receive()
uchar R_H,R_L,T_H,T_L,RH,RL,TH,TL,revise;
DHT_Start();
if(DHT == 0)
while(DHT == 0);
Delay_Us(40);
R_H = DHT_rec_byte(); //?????8?
R_L = DHT_rec_byte(); //?????8?
T_H = DHT_rec_byte(); //?????8?
revise = DHT_rec_byte();
Delay_Us(25); //??
if((R_H+R_L+T_H+T_L)==revise) //??
RH = R_H;
RL = R_L;
TH = T_H;
TL = T_L;
dat_s = 0x30 + (RH/10);
dat_s = 0x30 + (RH%10);
dat_s = 0x30 + (TH/10);
dat_s = 0x30 + (TH%10);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS=0;
RW=1;
EN=0;
_nop_();
EN=1;
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
Delay_Ms(5);
RS=0;
RW=0;
EN=1;
DataPort= com;
_nop_();
EN=0;
void LCD_Write_Data(unsigned char dt)
Delay_Ms(5);
RS=1;
RW=0;
EN=1;
DataPort= dt;
_nop_();
EN=0;
void LCD_Clear(void)
LCD_Write_Com(0x01);
Delay_Ms(5);
void LCD_Write_String(uchar ad,uchar *s)
LCD_Write_Com(ad);
while (*s)
LCD_Write_Data( *s);
s ++;
void LCD_Write_Char(uchar ad,uchar Data)
LCD_Write_Com(ad);
LCD_Write_Data( Data);
void LCD_Init(void)
LCD_Write_Com(0x38); /*ÏÔʾģʽÉèÖÃ*/
Delay_Ms(5);
Delay_Ms(5);
Delay_Ms(5);
LCD_Write_Com(0x08); /*ÏÔʾ¹Ø±Õ*/
LCD_Write_Com(0x01); /*ÏÔʾÇåÆÁ*/
LCD_Write_Com(0x06); /*ÏÔʾ¹â±êÒÆ¶¯ÉèÖÃ*/
Delay_Ms(5);
LCD_Write_Com(0x0C); /*ÏÔʾ¿ª¼°¹â±êÉèÖÃ*/
void Init_Timer1(void)
TMOD |= 0x10;
EA=1;
ET1=1;
TR1=1;
void Init_Timer0(void)
TMOD= 0x10|0x04;
EA = 1;
ET0=1;
TR0 = 1;
void main()
int Tmp,v;
float Temp;
LCD_Init();
Delay_Ms(20);
LCD_Clear();
Init_Timer1();
while(1)
if(ReadTmpFlag == 1)
ReadTmpFlag = 0;
Tmp = ReadTemperature();
Temp=(float)Tmp*0.0625;
sprintf(dat_t,"%2.0f",Temp);
LCD_Write_String(0x80,dat_t);
LCD_Write_Char(0x82,0xDF);
LCD_Write_Char(0x83,'C');
if(ReadRHFlag ==1)
Init_Timer0();
ReadRHFlag = 0;
if((dat_s==dat_t)&&(dat_s==dat_t))
LCD_Write_Char(0xC0,dat_s);
LCD_Write_Char(0xC1,dat_s);
LCD_Write_Char(0xC2,'%');
else
LCD_Write_String(0x86,"Error");
LCD_Write_Char(0x8b,dat_s);
LCD_Write_Char(0x8c,dat_s);
LCD_Write_Char(0x8e,'2');
LCD_Write_Char(0x8f,'3');
if(ReadVFlag==1)
ReadVFlag = 0;
v = v*5; //1s
sprintf(dat_v,"%2.0f",dat_v);
LCD_Write_String(0xC5,dat_v);
LCD_Write_String(0xCA,"m/s");
TR0=1;
ET0=1;
void Timer0() interrupt 1
OVERFLOWFLAG;
TH0 = 0;
TL0 = 0;
void Timer1() interrupt 3
static uint counter;
counter++;
TH0 = (65536-10000)/256;
TL0 = (65536-10000)%256;
if(counter == 10)
ReadTmpFlag = 1;
if(counter == 50)
ReadRHFlag =1;
if(counter == 200)//2000ms=2s
ET0 =1;
TR0 = 1;
ReadVFlag =1;
TH0 = 0x00;
TL0 = 0x00;
if(counter == 220)
counter =0;
TR0=0;
ET0=0;
} 估计是时序问题的可能性大,先检查一下吧 自己慢慢调试,估计没人帮得了你
页:
[1]
