【东软载波ESF0654 PDS开发板活动】 -- 2、 GPIO输出点亮LED灯
熟悉开发环境后,按照SDK开发包资源创建项目文件,开始学习之路。首先,来学习下GPIO配置与使用。一、原理图相关
LED接口对应的IO口是PC8和PC9
二、程序代码
2.1、led.c
void InitLed(void)
md_gpio_set_pin_function(LED1_GPIO_PORT, LED1_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(LED1_GPIO_PORT, LED1_GPIO_PIN);
md_gpio_set_pin_mode_output(LED1_GPIO_PORT, LED1_GPIO_PIN);
md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
2.2、led.h
#ifndef __LED_H
#define __LED_H
void InitLed(void);
#define LED1_GPIO_PORT GPIOC
#define LED1_GPIO_PINMD_GPIO_PIN_8
#define LED2_GPIO_PORT GPIOC
#define LED2_GPIO_PINMD_GPIO_PIN_9
#endif
2.3 、main.c
#include "config.h"
int main()
md_init_1ms_tick();
// config_gpio();
InitLed();
while (1) {
md_delay_1ms(100);
md_gpio_toggle_pin_output(LED1_GPIO_PORT, LED1_GPIO_PIN|LED2_GPIO_PIN);
三、运行结果
页:
[1]
