【东软载波ESF0654 PDS开发板活动】+ LCD12232
今晚捣鼓了一下LCD12232串行。代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uintunsigned int
#define CS_0md_gpio_set_pin_low(CS_GPIO_PORT, CS_GPIO_PIN)
#define CS_1md_gpio_set_pin_high(CS_GPIO_PORT, CS_GPIO_PIN)
#define SCK_0 md_gpio_set_pin_low(SCK_GPIO_PORT, SCK_GPIO_PIN)
#define SCK_1 md_gpio_set_pin_high(SCK_GPIO_PORT, SCK_GPIO_PIN)
#define SID_0md_gpio_set_pin_low(SID_GPIO_PORT, SID_GPIO_PIN)
#define SID_1md_gpio_set_pin_high(SID_GPIO_PORT, SID_GPIO_PIN)
#define SID md_gpio_get_input_data(SID_GPIO_PORT, SID_GPIO_PIN)
#define KEYRE2
uchar i=0,j=0;
uchar yemiancount=0;
uchar constbmp1[]=
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x20,0x82,0x0F,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x20,0x83,0xFF,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x00,0x00,0x00,0x00,0x00,0xF8,0x3F,0x82,0x0F,0x80,0x00,0x00,0x00,0x00,0x01,
0x80,0x30,0x00,0x18,0x01,0x80,0x0C,0x00,0x18,0x60,0x0F,0x00,0x7F,0xC0,0x01,0x81,
0x80,0x18,0x00,0x18,0x00,0xC0,0x07,0xFC,0x7F,0xFC,0xF8,0x30,0x60,0xC0,0xFF,0xC1,
0x87,0xFF,0xC0,0x18,0x0F,0xFC,0x18,0x0C,0x3C,0x60,0x7B,0x60,0x60,0xC0,0xC1,0x81,
0x80,0x30,0x0F,0xFF,0x80,0x18,0x1B,0xEC,0x19,0xF8,0x36,0xC0,0x7F,0xC0,0xFF,0x81,
0x80,0x30,0x00,0x18,0x00,0x30,0x1B,0x6C,0x7E,0x60,0x18,0x18,0x66,0x00,0xC1,0x81,
0x80,0x3F,0x03,0x18,0x00,0x60,0x1B,0x6C,0x1B,0xFC,0xFF,0xB0,0x63,0x00,0xFF,0x81,
0x80,0x33,0x01,0x98,0x00,0xC0,0x1B,0xEC,0x3D,0x98,0x18,0x60,0x79,0x80,0x36,0x01,
0x80,0x63,0x00,0xD8,0x01,0x80,0x1B,0x6C,0x3F,0xF8,0x3D,0xD8,0x6C,0xC1,0xB6,0xC1,
0x80,0x63,0x00,0x18,0x03,0x00,0x1B,0xEC,0x79,0x98,0x7E,0x30,0xC6,0x70,0xF7,0x81,
0x80,0xC3,0x00,0x18,0x07,0x00,0x1B,0x6C,0x79,0xF8,0xDB,0x61,0xB8,0x00,0x77,0x01,
0x81,0x9E,0x00,0x18,0x1D,0xC0,0x18,0x0C,0x19,0x98,0x18,0xC0,0x0E,0x00,0x36,0xC1,
0x83,0x0C,0x00,0x38,0x00,0x7F,0x18,0x1C,0x19,0xB8,0x1B,0x80,0x03,0x03,0xFF,0xE1,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
uchar const bmp2[]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x05,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xC0,0x00,0x00,0x00,0x00,0x1C,0x00,0x07,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xF1,0xFF,0xFF,0xFC,0x00,0xFE,0x00,0x0D,0xE1,0xFF,0xFF,0xE0,0x00,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xC3,0xFF,0x00,0x0C,0x7F,0xFF,0xBF,0xFC,0x00,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x0C,0x00,0x00,0x00,0x1F,0x80,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x0C,0x00,0x00,0x00,0x03,0xE0,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x1C,0x00,0x00,0x00,0x00,0xF8,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x36,0x00,0x00,0x00,0x00,0x3C,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x62,0x00,0x00,0x00,0x00,0x0E,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0xC3,0x00,0x00,0x00,0x00,0x07,0x00,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x80,0x00,0x00,0x00,0x00,0x03,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x01,0x80,0x00,0x00,0x00,0x00,0x01,0x80,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x7F,0xE3,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xC1,0xFF,0xFF,0xFF,0x83,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xE1,0xF8,0x00,0x0F,0x83,0xFE,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xE3,0xF0,0x00,0x03,0x87,0xFF,0x80,0x18,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0x40,0x81,0xFF,0xFF,0x00,0x7C,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0xE1,0xC1,0xFF,0xFF,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0x7F,0xFF,0xE0,0xC1,0xC1,0xFF,0xFF,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0x7F,0xFF,0xE0,0x00,0x81,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0xFF,0xFF,0xF0,0x00,0x03,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
0xFF,0xFF,0xFC,0x00,0x0F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0xFF,0xFF,0xFF,0x81,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x80,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0x60,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x1B,0x60,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x19,0xE0,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x80,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,
0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x01,0x80,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0xC0,0x00,0x00,0x00,0x00,0x01,0x80,0x00,
0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x60,0x00,0x00,0x00,0x00,0x03,0x80,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x70,0x00,0x00,0x00,0x00,0x03,0x00,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x38,0x00,0x00,0x00,0x00,0x06,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x18,0x1F,0x7F,0xFB,0xFE,0x0E,0x00,0x00,
0x07,0xFF,0xFF,0xFF,0xFF,0xE7,0xF8,0x00,0x0C,0x3F,0xFF,0xFF,0xFE,0x18,0x00,0x00,
0x07,0xF8,0x0E,0x00,0x08,0x03,0xF0,0x00,0x0C,0x60,0x00,0x00,0x06,0x30,0x00,0x00,
0x03,0xF8,0x00,0x00,0x00,0x03,0xF0,0x00,0x0E,0x60,0x00,0x00,0x03,0xF0,0x00,0x00,
0x01,0xF0,0x00,0x00,0x00,0x01,0x80,0x00,0x03,0xC0,0x00,0x00,0x01,0xC0,0x00,0x00,
0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar const bmp3[]=
0x00,0x7F,0x0F,0xC0,0x01,0x81,0xF0,0xF8,0x3C,0x06,0x00,0x0F,0x9E,0xF0,0x00,0x00,
0x00,0x31,0x98,0xC0,0x07,0x83,0x19,0x8C,0x6C,0x0E,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x36,0x18,0xC0,0x01,0x83,0x19,0x8C,0xC0,0x1E,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x83,0x19,0x8C,0xC0,0x36,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x3E,0x30,0x00,0x01,0x80,0x30,0xD8,0xF8,0x36,0x00,0x01,0x8C,0x60,0x00,0x00,
0x00,0x36,0x30,0x0F,0xF1,0x80,0x30,0x70,0xEC,0x66,0x3F,0xC1,0x8F,0xE0,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x80,0x60,0xD8,0xC6,0x66,0x00,0x03,0x0C,0x60,0x00,0x00,
0x00,0x30,0x30,0x00,0x01,0x80,0xC1,0x8C,0xC6,0x7F,0x00,0x06,0x0C,0x60,0x00,0x00,
0x00,0x30,0x18,0xC0,0x01,0x81,0x81,0x8C,0xC6,0x06,0x00,0x0C,0x0C,0x60,0x00,0x00,
0x00,0x30,0x19,0x80,0x01,0x83,0x19,0x8C,0x6C,0x06,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x78,0x0F,0x00,0x07,0xE3,0xF8,0xF8,0x38,0x1F,0x00,0x1F,0xDE,0xF0,0x00,0x00,
0x00,0x00,0x03,0x66,0x00,0x60,0x00,0x18,0x03,0x06,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x00,0x30,0x00,0x0C,0x01,0x83,0x00,0x7F,0xF0,0x00,0x00,0x00,
0x00,0x00,0x1F,0xFF,0xC7,0xFF,0xC3,0xFF,0xF1,0xBF,0xF8,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x06,0x00,0xC3,0x18,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0x66,0x0C,0x01,0x83,0x18,0x06,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x1F,0xFF,0xC3,0xFE,0x03,0xFF,0xE3,0xC3,0x01,0xFF,0xFC,0x00,0x00,0x00,
0x00,0x00,0x18,0x61,0x80,0x0C,0x03,0x36,0x00,0xDF,0xE0,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x30,0x63,0x00,0x18,0x03,0x66,0x01,0x9B,0x60,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0x30,0x03,0xFF,0xE1,0x9F,0xE0,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x0F,0xFF,0xE3,0x66,0x01,0x9B,0x60,0x66,0x60,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0x30,0x03,0x06,0x07,0x1B,0x60,0xC6,0x30,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0x30,0x03,0xFF,0xF3,0x1F,0xE1,0x86,0x38,0x00,0x00,0x00,
0x00,0x00,0x06,0x7E,0x00,0x30,0x03,0x06,0x03,0x00,0x03,0x06,0x18,0x00,0x00,0x00,
0x00,0x00,0x06,0x6C,0x00,0x30,0x06,0x06,0x03,0x0C,0xC0,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0xF0,0x06,0x06,0x03,0x0C,0x60,0x1E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0x60,0x0C,0x06,0x03,0x18,0x60,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x03,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x01,0x83,0x80,0x00,0x03,0xFF,0xF8,0xCD,0x80,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0xE3,0x03,0xFF,0xC0,0x00,0x60,0x6D,0x80,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x00,0xC6,0x03,0x00,0xC0,0x00,0x60,0x6F,0xF0,0x00,0x00,0x00,
0x00,0x00,0x06,0x66,0x0F,0xFF,0xC3,0x00,0xC0,0xFE,0x60,0x19,0x80,0x00,0x00,0x00,
0x00,0x00,0x07,0xFE,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x01,0x80,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x63,0xFF,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0xFF,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x0F,0xFF,0xE3,0x00,0xC0,0xC6,0x60,0x66,0xC0,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x00,0xC6,0x03,0x00,0xC0,0xFE,0x60,0x6C,0xD8,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x00,0xC6,0x03,0x00,0xC0,0xC6,0x60,0x6C,0xD8,0x00,0x00,0x00,
0x00,0x00,0x0F,0xFF,0x00,0xC6,0x03,0xFF,0xC0,0x00,0x60,0x78,0x78,0x00,0x00,0x00,
0x00,0x00,0x0C,0x63,0x01,0x86,0x03,0x00,0xC0,0x03,0x60,0x60,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x01,0x86,0x03,0x00,0xC0,0x01,0xE0,0xF0,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x03,0x06,0x00,0x00,0x00,0x00,0xC1,0x9F,0xFC,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x06,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar const bmp4[]=
0x00,0x36,0x30,0x00,0x01,0x83,0x19,0x8C,0xC0,0x36,0x00,0x01,0x8C,0x60,0x00,0x00,
0x00,0x3E,0x30,0x00,0x01,0x80,0x30,0xD8,0xF8,0x36,0x00,0x07,0x0C,0x60,0x00,0x00,
0x00,0x36,0x30,0x00,0x01,0x80,0x60,0xD8,0xC6,0x66,0x00,0x00,0xCC,0x60,0x00,0x00,
0x00,0x30,0x30,0x00,0x01,0x80,0xC1,0x8C,0xC6,0x7F,0x00,0x00,0xCC,0x60,0x00,0x00,
0x00,0x30,0x18,0xC0,0x01,0x81,0x81,0x8C,0xC6,0x06,0x00,0x18,0xCC,0x60,0x00,0x00,
0x00,0x30,0x19,0x80,0x01,0x83,0x19,0x8C,0x6C,0x06,0x00,0x19,0x8C,0x60,0x00,0x00,
0x00,0x78,0x0F,0x00,0x07,0xE3,0xF8,0xF8,0x38,0x1F,0x00,0x0F,0x1E,0xF0,0x00,0x00,
void delayus(void)
uchar i;
for(i=0;i<5;i++);
void SID_Input(void)
md_gpio_set_pin_function(SID_GPIO_PORT, SID_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(SID_GPIO_PORT, SID_GPIO_PIN);
md_gpio_set_pin_mode_input(SID_GPIO_PORT, SID_GPIO_PIN);
void SID_Output(void)
md_gpio_set_pin_mode_output(SID_GPIO_PORT, SID_GPIO_PIN);
void SendByte(uchar Dbyte)
uchar i;
for(i=0;i<8;i++)
SCK_0;
delayus();
if((Dbyte&0x80)==0x80)
SID_1;
else
SID_0;
Dbyte=Dbyte<<1;
delayus();
SCK_1;
delayus();
uchar ReceiveByte()
uchar i,temp1,temp2;
temp1=temp2=0;
//TRISD=0X40;
SID_Input();
for(i=0;i<20;i++);
for(i=0;i<8;i++)
temp1=temp1<<1;
SCK_0;
delayus();
SCK_1;
delayus();
if(SID==1) temp1++;
delayus();
for(i=0;i<8;i++)
temp2=temp2<<1;
SCK_0;
delayus();
SCK_1;
delayus();
if(SID==1) temp2++;
delayus();
SID_Output();
for(i=0;i<20;i++);
return ((0xf0&temp1)+(0x0f&temp2));
void busy( )
do SendByte(0xfc); //11111,RW(1),RS(0),0
while(0x80&ReceiveByte());
void write_cmd( uchar Cbyte )
CS_1;
delayus();
busy();
SendByte(0xf8); //11111,RW(0),RS(0),0
SendByte(0xf0&Cbyte);
SendByte(0xf0&Cbyte<<4);
CS_0;
delayus();
void write_data( uchar Dbyte )
CS_1;
delayus();
busy();
SendByte(0xfa); //11111,RW(0),RS(1),0
SendByte(0xf0&Dbyte);
SendByte(0xf0&Dbyte<<4);
CS_0;
delayus();
uchar ReadData( )
busy();
SendByte(0xfe); //11111,RW(1),RS(1),0
return ReceiveByte();
void delay(uint MS)
uint i,j;
for (i=0;i<MS;i++)
for(j=0;j<10;j++);
void LcmInit( )
write_cmd(0x30);
delay(100);
write_cmd(0x03);
delay(100);
write_cmd(0x0C);
delay(100);
write_cmd(0x01);
delay(100);
write_cmd(0x06);
delay(100);
void LcmClearTXT( )
uchar i;
write_cmd(0x30);
write_cmd(0x80);
for(i=0;i<64;i++)
write_data(0x20);
void LcmClearBMP()
uchar i,j;
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<32;i++)
write_cmd(0x80+i);
write_cmd(0x80);
for(j=0;j<32;j++)
write_data(0);
void PUTstring(uchar row,uchar col,uchar *puts)
write_cmd(0x30);
switch(row)
case 0: write_cmd(0x80+col);break;
case 1: write_cmd(0x90+col);break;
case 2: write_cmd(0x88+col);break;
case 3: write_cmd(0x98+col);break;
while(*puts != '\0')
write_data(*puts);
puts++;
void PUTZIZAO(uchar row,uchar col,uchar *puts)
uchar i=0,j=0,k=0;
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<16;i++)
write_cmd(0x80+i+row);
write_data(puts);
write_data(puts);
k++;
void PUTBMP(uchar *puts)
uint x=0,y=0;
uchar i,j;
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<32;i++)
write_cmd(0x80+i);
write_cmd(0x80);
for(j=0;j<8;j++)
write_data(puts);
write_data(puts);
x++;
write_cmd(0x80+i);
write_cmd(0x88);
for(j=0;j<8;j++)
write_data(puts);
write_data(puts);
y++;
voidoshuxian()
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<32;i++)
{//write_cmd(0x36);
write_cmd(0x80+i);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)
write_data(0xCC);
write_cmd(0x32);
void jishuxian()
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<32;i++)
//write_cmd(0x36);
write_cmd(i+0x80);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)
write_data(0x33);
write_cmd(0x32);
voidohengxian()
LcmClearTXT();
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<16;i++)
//write_cmd(0x36);
write_cmd(0x80+2*i);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)write_data(0xFF);
//write_cmd(0x36);
write_cmd(0x80+2*i+1);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)write_data(0);
write_cmd(0x32);
voiddianxian()
LcmClearTXT();
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<16;i++)
{ //write_cmd(0x36);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)write_data(0XAA);
//write_cmd(0x36);
write_cmd(0x80);
//write_cmd(0x30);
for(j=0;j<32;j++)write_data(0x55);
write_cmd(0x32);
void hanzi()
LcmClearBMP();
write_cmd(0x30);
PUTstring(0,0,"ÉîÛÚ·½´çµç×ÓÓÐÏÞ");
PUTstring(1,0,"¹«Ë¾ÄÏÉ½ÇøÎ÷ÀöÄÏ");
PUTstring(2,0,"Íå¹¤ÒµÇø10¶°4 Â¥");
PUTstring(3,0,"·½´çÖ®¼ä¾«²Ê¾¡ÏÔ");
voidjihengxian()
write_cmd(0x34);
write_cmd(0x36);
for(i=0;i<16;i++)
//write_cmd(0x36);
write_cmd(0x80);
//write_cmd(0x30);
//write_cmd(0x36);
write_cmd(0x80);
//write_cmd(0x30);
write_cmd(0x32);
* @briefThis function configures GPIO
* @paramNone
* @retval None
void config_gpio(void)
md_gpio_set_pin_function(SCK_GPIO_PORT, SCK_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(SCK_GPIO_PORT, SCK_GPIO_PIN);
md_gpio_set_pin_mode_output(SCK_GPIO_PORT, SCK_GPIO_PIN);
md_gpio_set_pin_function(CS_GPIO_PORT, CS_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(CS_GPIO_PORT, CS_GPIO_PIN);
md_gpio_set_pin_mode_output(CS_GPIO_PORT, CS_GPIO_PIN);
md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
* @briefTest main function
* @retval Status.
int main()
md_init_1ms_tick();
config_gpio();
LcmInit();
LcmClearTXT();
LcmClearBMP();
hanzi();
while (1)
md_delay_1ms(1000);
//md_gpio_set_pin_low(LOAD_GPIO_PORT,LOAD_GPIO_PIN);
md_gpio_toggle_pin_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
// WriteWord (DisplayTest,TextEnd);// ????????
// WriteWord (Digit0,0);
// WriteWord (Digit1,1);
// WriteWord (Digit2,2);
// WriteWord (Digit3,3);
//SendChar (0X55);
效果图:
页:
[1]
