HC32L15xx开发板的UART问题
本帖最后由 crystal001 于 2020-3-3 15:30 编辑求助大神们
问题描述:
串口收发测试,中断接收,轮询发送,测试过程中,接收正常,但是发送不出数据。单收和单发都正常。
原理图:串口使用PIN59和PIN60
代码如下:
#include "uart.h"
#include "gpio.h"
#include "clk.h"
uint8_t u8TxData = {1,2,3,4,5,6,7,8,9,10};//"HUADA MCU!";
uint8_t u8RxData;
uint8_t u8TxCnt = 0, u8RxCnt = 0;
uint8_t u8Cnt = 0;
#define UARTRXUARTCH6
#define UARTTXUARTCH6
static void UartIoConfig(void)
Gpio_SetFunc_SIN6_0(x);
Gpio_SetFunc_SOT6_0(x);
M0P_GPIO->FN_SEL08_f.SCS60B= 1;
void RxIntCallback(void)
u8RxData = Uart_ReceiveData(UARTRX);
u8RxCnt++;
Uart_DisableIrq(UARTRX, UartRxIrq);
Uart_SendData(UARTTX, u8TxData);
if(u8Cnt<10)
u8Cnt++;
else u8Cnt=0;
delay1ms(1);
Uart_EnableIrq(UARTRX, UartRxIrq);
int32_t main(void)
stc_uart_config_t stcUartTxConfig;
stc_uart_config_t stcUartRxConfig;
stc_uart_irq_cb_tstcUartRxIrqCb;
DDL_ZERO_STRUCT(stcUartTxConfig);
DDL_ZERO_STRUCT(stcUartRxConfig);
DDL_ZERO_STRUCT(stcUartRxIrqCb);
/* Config the UART IO */
UartIoConfig();
/* Init the UART */
stcUartRxIrqCb.pfnRxIrqCb = RxIntCallback;
/* Config the UARTTX */
stcUartTxConfig.bCarryEnable = FALSE;
stcUartTxConfig.bCarryPolarity = TRUE;
stcUartTxConfig.bCompensation = TRUE;
stcUartTxConfig.bCtsWu = FALSE;
stcUartTxConfig.bHwFlow = FALSE;
stcUartTxConfig.bInvertData = FALSE;
stcUartTxConfig.bTouchNvic = FALSE;
stcUartTxConfig.bUseExtClk = FALSE;
stcUartTxConfig.enBitDirection = UartDataLsbFirst;
stcUartTxConfig.enDataLength = UartEightBits;
stcUartTxConfig.enMode = UartNormal;
stcUartTxConfig.enParity = UartParityNone;
stcUartTxConfig.enStopBit = UartOneStopBit;
stcUartTxConfig.u32BaudRate = 115200;
Uart_Init(UARTTX, &stcUartTxConfig);
Uart_EnableFunc(UARTTX, UartTx);
/* Config the UARTRX */
stcUartRxConfig.bCarryEnable = FALSE;
stcUartRxConfig.bCarryPolarity = FALSE;
stcUartRxConfig.bCompensation = FALSE;
stcUartRxConfig.bCtsWu = FALSE;
stcUartRxConfig.bHwFlow = FALSE;
stcUartRxConfig.bInvertData = FALSE;
stcUartRxConfig.bTouchNvic = TRUE;
stcUartRxConfig.bUseExtClk = FALSE;
stcUartRxConfig.enBitDirection = UartDataLsbFirst;
stcUartRxConfig.enDataLength = UartEightBits;
stcUartRxConfig.enMode = UartNormal;
stcUartRxConfig.enParity = UartParityNone;
stcUartRxConfig.enStopBit = UartOneStopBit;
stcUartRxConfig.u32BaudRate = 115200;
stcUartRxConfig.pstcIrqCb = &stcUartRxIrqCb;
Uart_Init(UARTRX, &stcUartRxConfig);
Uart_EnableFunc(UARTRX, UartRx);
/* Configure interrupt */
while(1)
if(u8Cnt<10)
u8Cnt++;
else u8Cnt=0;
delay1ms(1);
页:
[1]
