keer_zu 发表于 2020-4-14 10:26
【原创】基于简单的内存数据库实现一个异步回调的通信...
前面实现了一个简单的内存数据库,接下来就基于这个简单的内存数据库实现一个异步回调的通信框架。
zxcom
@紫剑
@dirtwillfly @海中水
@icecut @yyy71cj
参看之前帖子:
【原创】一个超简单的key-value内存数据库
库的使用实例:
main.c
#include <sys/types.h>
#include <unistd.h>
#include "ucomlib.h"
#include <stdio.h>
#include <sys/socket.h>
#include <sys/un.h>
#include <string.h>
#include "zxcom.h"
#include <pthread.h>
#include <errno.h>
#include <arpa/inet.h>
#include <stdlib.h>
pthread_mutex_t g_mutex;
int server_fd = -1;
int client_fd = -1;
char * server_filename = "/tmp/socket-server";
char * client_filename = "/tmp/socket-client";
void ENTER_CRITICAL()
      pthread_mutex_lock(&g_mutex);
void EXIT_CRITICAL()
      pthread_mutex_unlock(&g_mutex);
int CRITICAL_INIT()
      pthread_mutex_init(&g_mutex, NULL);
int CRITICAL_DEINIT()
      pthread_mutex_destroy(&g_mutex);
void *thread_timer(void* arg)
      //printf("new thread,thread is :%u,pid:%d\n",pthread_self(),getpid());
      while(1) {
                sleep(2);
                OnTimer();
struct sockaddr_un srv_un_s = {0};
struct sockaddr_un srv_un_c = {0};
void *thread_run_c(void* arg)
      int ret;
      char packet,buf;
      socklen_t addre_len;
      int socketfd = *(int *)arg;
      char *param = "hello";
      //struct sockaddr_un srv_un = {0};
      struct sockaddr_un remote_un = {0};
      while (1) {
                sleep(2);
                ZxcomOnSendMsg(1,param,strlen(param),packet);
                if (sendto(socketfd,packet,strlen(param) + 4, 0,
                        (struct sockaddr *)&srv_un_s, sizeof(srv_un_s)) == -1) {
                        perror("send");
                        close(socketfd);
                        socketfd = -1;
                        pthread_exit(NULL);
                memset(buf, 0, sizeof(buf));
                ret = recvfrom(socketfd, buf, sizeof(buf), 0,
                        (struct sockaddr*)&remote_un, &addre_len);
                if (ret == -1) {
                        perror("error when recvfrom, ");
                        continue;
                ZxcomOnPacket(buf,ret);
                buf = 0;
                printf("cli ret:%d, contrl:0x%x    %s\n", ret,*(int*)buf,buf+4);
void *thread_run_s(void* arg)
      int ret;
      int i =0;
      char buf = {0};
      int server_fd = *(int *)arg;
      for(;;) {
                ++i;
                ret = recvfrom(server_fd, buf, sizeof(buf), 0,
                if (ret == -1) {
                        continue;
                buf = 0;
                printf("ret:%d, contrl:0x%x    %s\n", ret,*(int*)buf,buf+4);
                usleep(500000);
      //close(server_fd);
      //server_fd = -1;
int cmd1_handler(void *param)   //server
      printf("handler param: %s\n",(char*)param);
      char *res = "go away";
      char packet;
      ZxcomOnSendResponse(1,res, strlen(res), packet);
      if(server_fd < 0) {
                return -1;
      if (sendto(server_fd,packet,strlen(res) + 4, 0,
                        (struct sockaddr *)&srv_un_c, sizeof(srv_un_c)) == -1) {
                        perror("send");
                        close(server_fd);
                        server_fd = -1;
                        pthread_exit(NULL);
int response1_handler(void *param)
      printf("response handler param: %s\n",(char*)param);
int main(int argc, char **argv)
      int ret;
      pthread_t tid_timer,tid_run1,tid_run2;
      char obuf;
      //struct sockaddr_un srv_un_c = { 0 };
      ZxcomInit();
      ZxcomAddCommand(1,cmd1_handler);
      ZxcomAddResponse(1,response1_handler);
      srv_un_c.sun_family = AF_UNIX;
      strncpy(srv_un_c.sun_path, client_filename, sizeof(srv_un_c.sun_path));
      srv_un_s.sun_family = AF_UNIX;
      strncpy(srv_un_s.sun_path, server_filename, sizeof(srv_un_s.sun_path));
      char mode = 's';
      if (argc > 1)
                mode = argv;
      if (mode == 's'){
                server_fd = socket(AF_UNIX, SOCK_DGRAM, 0);
                if (server_fd < 0) {
                        printf("socket error %s errno: %d\n", strerror(errno), errno);
                unlink(srv_un_s.sun_path);
                if (bind(server_fd, (struct sockaddr *)&srv_un_s, sizeof(srv_un_s)) == -1) {
                        printf("bind server err");
                        exit(1);
                pthread_create(&tid_run2,NULL,thread_run_s,&server_fd);
      } else {
                client_fd = socket(AF_UNIX, SOCK_DGRAM, 0);
                if (client_fd < 0) {
                unlink(srv_un_c.sun_path);
                if (bind(client_fd, (struct sockaddr *)&srv_un_c, sizeof(srv_un_c)) == -1) {
                        perror("bind client");
                        exit(1);
                pthread_create(&tid_run1,NULL,thread_run_c,&client_fd);
      pthread_create(&tid_timer,NULL,thread_timer,NULL);
      while(1){
                sleep(10);
      return 0;
debug已经完成,可以直接从github上拉去代码,编译,运行在linux上面。
@dirtwillfly @icecut @yyy71cj
在linux下:
git clone https://github.com/KevinZu/zxcom.git
cd zxcom
checkout -b develop
git pull origin develop
mkdir build
cd build
cmake ..
make
然后执行服务端:
./main
再执行客户端:
./main c
服务端:
https://bbs.21ic.com/data/attachment/forum/202004/16/103920dc5sfffktf5dgd5t.png.thumb.jpg
客户端:
https://bbs.21ic.com/data/attachment/forum/202004/16/103946rl67736llydi3rdr.png.thumb.jpg
icecut 发表于 2020-4-14 17:22
哈哈哈。浓浓的互联网味道。 用邮箱不能实现么?或者消息队列?
要mcu也能用才行。
keer_zu 发表于 2020-4-15 10:23
yyy71cj 发表于 2020-4-15 10:05
我想请教一个问题:给安卓手机编程,你用什么编程环境和工具?我正想转战手机编程,但是一直在选择用什么而 ...
你要做哪一层开发?
内核也是linux,开发当然用C语言。
如果做APP,那就是java,java我之前用eclipse或者myeclipse。
java是跨平台的,不必过多考虑平台的差异。
要mcu也能用才行。
ucos里面有吧
ucos里面有吧
ucos不管通信吧
keer_zu 发表于 2020-4-19 13:24
yyy71cj 发表于 2020-4-18 12:08
有没有类似VS这种的工具软件?
eclipse就是类似VS啊,用的人挺多的。
keer_zu 发表于 2020-4-20 09:57
yyy71cj 发表于 2020-4-19 20:17
我试试。记得以前装过,需要配置不少东西,蛮繁琐的。
像eclipse,sublime这样的工具通常支持很多语言,针对特定语言和功能需要安装若干插件,通常安装很方便。
页: [1]
查看完整版本: 【原创】基于简单的内存数据库实现一个异步回调的通信...
