【MM32 eMiniBoard测评报告】+ 3、TN9
今晚搞了一下TN9,红外体温计模块。Data:PC13
CLK:PC14
ACK:PC15
代码:
#include "delay.h"
#include "sys.h"
#include "led.h"
#define uchar unsigned char
#define uint unsigned int
void ACK_0() { GPIO_ResetBits(GPIOC,GPIO_Pin_15);}//
void ACK_1() { GPIO_SetBits(GPIOC,GPIO_Pin_15);}
#define DATA GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)
#define CLOCK GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_14)
float Temp;
float Temp1,Temp2;
unsigned char ReadData;
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us)//5,7,9
while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
unsigned int i,j;
for(i=0;i<ims;i++)
for(j=0;j<65;j++) { Delay(1); }
void TN_IRACK_EN(void)
ACK_0();
Delay(1);
void TN_IRACK_UN(void)
ACK_1();
Delay(1);
void InitIO(void)
GPIO_InitTypeDefGPIO_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA|RCC_AHBPeriph_GPIOB|RCC_AHBPeriph_GPIOC, ENABLE);//¿ªÆôGPIOA,GPIOBʱÖÓ
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_13 | GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
void TN_ReadData(unsigned char Flag)
unsigned char i,j,k,BitState=0;
for(k=0;k<7;k++)
for(j=0;j<5;j++)
for(i=0;i<8;i++)
while(1)
if(CLOCK==0)
break;
Delay(1);
Delay(1);
if(DATA==1)
BitState=1;
else
BitState=0;
ReadData= ReadData<<1;
ReadData= ReadData|BitState;
Delay(1);
while(1)
if(CLOCK==1)
break;
Delay(1);
if(ReadData==Flag)
k=8;
TN_IRACK_UN();
float TN_GetData(unsigned char X)
//Ack_Clk_Data_init;
InitIO();
TN_ReadData(X);
Temp=(ReadData<<8)|ReadData;
Temp=(float)Temp/16.00-273.15;
return Temp;
float TN_GetTemp(unsigned char mode)
float T;
TN_IRACK_UN();
TN_IRACK_EN();
if(mode==0)
T=TN_GetData(0x4c);
else
T=TN_GetData(0x66);
return T;
**º¯ÊýÐÅÏ¢ £ºmain(void)
**¹¦ÄÜÃèÊö £º
**ÊäÈë²ÎÊý £ºÎÞ
**Êä³ö²ÎÊý £ºÎÞ
int main(void)
delay_init();
LED_Init();
while(1) //ÎÞÏÞÑ»·
Temp1=TN_GetTemp(0);
Temp2=TN_GetTemp(1);
a=((unsigned int)(Temp1*10));
b=((unsigned int)(Temp2*10));
delay_ms(500);
效果图:
a是体温,b是环境温度
332表示33.2度,214表示21.4度。
工程:
页:
[1]
