wangji12 发表于 2020-5-29 10:44
【RTOS】+ RT-Thread + 雅特力AT_START_F403A_V1开发板-sht3x温湿度
1、将sht3x连接到开发板上,SCL、SDA分别连接PB8,PB9.2、通过menuconfig使能IIC1接口配置IIC的SDA、SCL到引脚PB9,PB10上。#define BSP_I2C1_SCL_PIN 24#define BSP_I2C1_SDA_PIN 253、通过menuconfig使能sht3x将sht3x挂载到i2c1上。dev = sht3x_init("i2c1", SHT3X_ADDR_PD);4、移植sht3x驱动到sensor中在工程中新建一个sht3xTemp.c文件,在文件里完成sht3x设备的初始化、注册sensor。static int rt_hw_sht3xTemp_port(void){    struct rt_sensor_config cfg;     rt_hw_sht3xTemp_init("sh3x", &cfg);    return RT_EOK;}INIT_COMPONENT_EXPORT(rt_hw_sht3xTemp_port);将rt_hw_sht3xTemp_port作为组件自动调用。int rt_hw_sht3xTemp_init(const char *name, struct rt_sensor_config *cfg)函数将sht3x设备注册到senseor中。提供shr3x_temp_fetch_data,shr3x_temp_control供sensor框架调用。 static struct rt_sensor_ops sensor_ops ={    shr3x_temp_fetch_data,    shr3x_temp_control};
到此为止已经将sht3x注册到了sensor框架中,以后就可以通过sensor框架进行操作。void readSht3x(void){   rt_device_t dev3 = RT_NULL;    struct rt_sensor_data sensor_data;    rt_size_t res;    dev3 = rt_device_find("temp_sh3x");    if (dev3 == RT_NULL)    {      rt_kprintf("Can't find device:sh3x\n");    }else    {      if (rt_device_open(dev3, RT_DEVICE_FLAG_RDWR) != RT_EOK)      {            rt_kprintf("open device failed!\n");      }      rt_device_control(dev3, RT_SENSOR_CTRL_SET_ODR, (void *)100);    }    if (dev3 != RT_NULL)    {      res = rt_device_read(dev3, 0, &sensor_data, 2);      if (res != 1)      {            rt_kprintf("read data failed!size is %d\n", res);            rt_device_close(dev3);      }      else      {            freData.RealTimeData.enviromentParam.ambientTemp         = (sensor_data.data.temp>>16)*MULTIPLE/10;            freData.RealTimeData.enviromentParam.ambientHumidity   = (sensor_data.data.temp&0xFFFF)*MULTIPLE/10;            rt_kprintf("sht3x temperature:%d.%dC humidity:%d.%d% timestamp:%5d\n",freData.RealTimeData.enviromentParam.ambientTemp / 100, freData.RealTimeData.enviromentParam.ambientTemp % 100,\            freData.RealTimeData.enviromentParam.ambientHumidity / 100, freData.RealTimeData.enviromentParam.ambientHumidity % 100, sensor_data.timestamp);             freData.timeStamp         = sensor_data.timestamp;            //时间戳         }       }   }
5、编译工程,测试读取sht温湿度数据获取情况如下图:
页: [1]
查看完整版本: 【RTOS】+ RT-Thread + 雅特力AT_START_F403A_V1开发板-sht3x温湿度
