keer_zu 发表于 2020-6-15 16:01
命令参数的解析
刚写了一个命令参数解析的程序,使用getopt。
主要代码如下:
#include <stdio.h>
#include <string>
#include <map>
#include <stdlib.h>
#include "operation.h"
using namespace std;
std::map<char,operation_context_t> operation_contexts;
#define no_argument 0
#define required_argument 1
#define optional_argument 2
struct option *options = NULL;
static int operation_p(char *arg)
    TestItemManager &tm = (TestItemManager&)TestItemManager::GetInstance();
    tm.TestItemPrint();
static int operation_test(char *arg)
    tm.TestSpecific(arg);
static int operation_a(char *arg)
    tm.TestAll();
void operation_contexts_init()
      int i = 0;
      char opt;
      opt = 'p';
      operation_contexts.insert(pair<char,operation_context_t>(opt,{.m_option={.name = "p",.has_arg=no_argument,.flag=NULL,.val=opt},.operation=operation_p}));
      opt = 't';
      operation_contexts.insert(pair<char,operation_context_t>(opt,{.m_option={.name = "test",.has_arg=required_argument,.flag=NULL,.val=opt},.operation=operation_test}));
      opt = 'n';
      operation_contexts.insert(pair<char,operation_context_t>(opt,{.m_option={.name = NULL,.has_arg= 0,.flag=NULL,.val=opt},.operation=operation_null}));
      options = (struct option *)malloc(sizeof(struct option) * operation_contexts.size());
      if(options != NULL) {
                map<char,operation_context_t>::reverse_iterator iter;
                for(iter = operation_contexts.rbegin(); iter != operation_contexts.rend(); iter++) {
                        options.name = ((operation_context_t)(iter->second)).m_option.name;
                        options.has_arg = ((operation_context_t)(iter->second)).m_option.has_arg;
                        options.flag = ((operation_context_t)(iter->second)).m_option.flag;
                        options.val = ((operation_context_t)(iter->second)).m_option.val;
                        i ++;
int run_operation(char opt,char *arg)
      map<char,operation_context_t>::iterator iter;
    iter = operation_contexts.find(opt);
    if(iter != operation_contexts.end()){
                return operation_contexts.operation(arg);
使用用例:
#include <string>
#include <stdio.h>
#include <unistd.h>
#include <getopt.h>
extern struct option *options;
int main(int argc, char *argv[])
    int opt;
    int digit_optind = 0;
    int option_index = 0;
    std::string str = "a::b:c:d";
      operation_contexts_init();
                while((opt = getopt_long_only(argc,argv,str.c_str(),options,&option_index))!= -1) {
                run_operation(opt,optarg);
@yyy71cj @dirtwillfly
keer_zu 发表于 2020-6-16 09:20
测试项:
头文件
#ifndef __TEST_ITEM_H__
#define __TEST_ITEM_H__
#include <string>
#include <map>
///////////////////////////////////////// test item /////////////////////////////////////////
class TestItem
public:
        virtual int Test() = 0;
protected:
        std::string m_itemName;
///////////////////////////// ublox ///////////////////////////////
class TestUblox : public TestItem
public:
        TestUblox(std::string itemName);
        int Test();
///////////////////////////// emmc ///////////////////////////////
class TestEmmc : public TestItem
public:
        TestEmmc(std::string itemName);
        int Test();
///////////////////////////// can ///////////////////////////////
class TestCan : public TestItem
public:
        TestCan(std::string itemName);
        int Test();
////////////////////////////////////////// item manager ///////////////////////////////////////
class TestItemManager {
public:
        static TestItemManager& GetInstance();
        TestItemManager();
        int TestAll();
        int TestSpecific(std::string itemName);
        int TestItemPrint();
private:
        std::map<std::string,TestItem*> m_testItems;
#endif
.cpp文件:
#include <iostream>
#include "test_item.h"
///////////////////////////////////////// TestUblox ///////////////////////////////////////////////
TestUblox::TestUblox(string itemName)
        m_itemName = itemName;
int TestUblox::Test()
        cout << "== ublox test" << endl;
///////////////////////////////////////// TestEmmc ////////////////////////////////////////////////
TestEmmc::TestEmmc(string itemName)
int TestEmmc::Test()
        cout << "== emmc test" << endl;
///////////////////////////////////////// TestCan ////////////////////////////////////////////////
TestCan::TestCan(string itemName)
int TestCan::Test()
        cout << "== can test" << endl;
TestItemManager::TestItemManager()
        string itemName;
        itemName = "ublox";
        m_testItems.insert(pair<string,TestItem*>(itemName,new TestUblox(itemName)));
        itemName = "emmc";
        m_testItems.insert(pair<string,TestItem*>(itemName,new TestEmmc(itemName)));
        itemName = "can";
        m_testItems.insert(pair<string,TestItem*>(itemName,new TestCan(itemName)));
TestItemManager& TestItemManager::GetInstance()
        static TestItemManager t_inst;
        return t_inst;
int TestItemManager::TestAll()
        map<string,TestItem*>::iterator iter;
        for(iter = m_testItems.begin(); iter != m_testItems.end(); iter++) {
                ((TestItem*)(iter->second))->Test();
int TestItemManager::TestSpecific(string itemName)
    iter = m_testItems.find(itemName);
    if(iter != m_testItems.end()){
                return m_testItems->Test();
int TestItemManager::TestItemPrint()
                cout << iter->first << " ";
        cout << endl;
页: [1]
查看完整版本: 命令参数的解析
