ningling_21 发表于 2020-6-29 08:20
灵动芯片32L373移植了RT-THREAD后,建多个任务为何死机?
如题:
有main任务,又新建2个任务,只是闪灯,运行2秒就进入rt_hw_hard_fault_exception
zhu^zhu 发表于 2020-6-29 08:39
这应该是纯软件的问题。最好是把代码贴出来,应该很容易分析问题所在。
ningling_21 发表于 2020-6-29 10:24
#include <rtthread.h>
#include <rtdevice.h>
#include "HAL_device.h"
#include "drv_uart.h"
//#include "can.h"
#include "HAL_can.h"
/* defined the LED pin: PA15 */
#define LED_PIN    38
#define LED2_PIN   39
#define LED3_PIN   40
#define LED4_PIN   41
static rt_uint8_t led_1_stack;
static struct rt_thread led_1_thread;
static rt_uint8_t led_2_stack;
static struct rt_thread led_2_thread;
static void led_1_thread_entry(void * parameter)//线程1入口
        u8led_stat_led=0;
        //rt_hw_led_init();
        //rt_hw_usart_init();
        rt_pin_mode(LED4_PIN, PIN_MODE_OUTPUT);
        while(1)
                if(led_stat_led==0)
                        led_stat_led=1;
                        rt_pin_write(LED4_PIN, PIN_LOW);
                else
                        led_stat_led=0;
                        rt_pin_write(LED4_PIN, PIN_HIGH);
                        //mm32_uart_putc(UART1,0x55);
      rt_thread_delay( 200 );
static void led_2_thread_entry(void * parameter)//线程2入口
        u8led_stat_led=0;
        //rt_hw_led_init();
        rt_pin_mode(LED3_PIN, PIN_MODE_OUTPUT);
        while(1)
                if(led_stat_led==0)
                        led_stat_led=1;
                        rt_pin_write(LED3_PIN, PIN_LOW);
                else
                        led_stat_led=0;
                        rt_pin_write(LED3_PIN, PIN_HIGH);
      rt_thread_delay( 100 );
int main(void)
        u16run_cnt=0;
        u8led_stat_led=0;
        u8flag_rt_thread=0;
        rt_err_t result;
    int count = 1;
    /* set LED4 pin mode to output */
    rt_pin_mode(LED_PIN,PIN_MODE_OUTPUT);
        rt_pin_mode(LED2_PIN, PIN_MODE_OUTPUT);
        //rt_pin_mode(LED3_PIN, PIN_MODE_OUTPUT);
        rt_hw_uart_init();
    while (count)
      run_cnt++;
                if(led_stat_led==0)
                        led_stat_led=1;
                        rt_pin_write(LED_PIN, PIN_HIGH);
                        rt_pin_write(LED2_PIN, PIN_LOW);
                        //rt_pin_write(LED3_PIN, PIN_HIGH);
                        //rt_pin_write(LED4_PIN, PIN_LOW);
                else
                        led_stat_led=0;
                        rt_pin_write(LED_PIN, PIN_LOW);
                        rt_pin_write(LED2_PIN, PIN_HIGH);
                        //rt_pin_write(LED3_PIN, PIN_LOW);
                        //rt_pin_write(LED4_PIN, PIN_HIGH);
                rt_thread_mdelay(100);
                //rt_kprintf("run_count=%d\r\n",run_cnt);
                if(run_cnt>=20)
                        run_cnt=0;
                        if(flag_rt_thread==0)
                                flag_rt_thread=1;
                                //rt_thread_create()
                                result = rt_thread_init(&led_1_thread,
                            "led",
                            led_1_thread_entry,
                            RT_NULL,
                            (rt_uint8_t*)&led_1_stack,                //堆栈起始
                            sizeof(led_1_stack),                                //堆栈大小
                            21,        //线程优先级
                            10);        //时间片数
                                if (result == RT_EOK)
                                        rt_thread_startup(&led_1_thread);
                                rt_kprintf("led1_thread ok.\n");
                                result = rt_thread_init(&led_2_thread,
                            "led",
                            led_2_thread_entry,
                            RT_NULL,
                            (rt_uint8_t*)&led_2_stack,                //堆栈起始
                            sizeof(led_2_stack),                                //堆栈大小
                            22,        //线程优先级
                            5);        //时间片数
                                        rt_thread_startup(&led_2_thread);
    return RT_EOK;
解决了吗
解决了吗
qjp1988113 发表于 2020-6-30 08:21
很混乱,你不觉得你的所谓的MAIN任务很奇怪么。一个程序必须有一个main函数,作为主程序的入口。既然用到了RT-THREAD,最好就把所以动作都做成TASK子程序。main函数的while里面就不要放东西了。
这个建立任务应该在while的外面,确保只运行一次;不然的话,可能会建立任务很多次;
具体使用请参考:
https://www.rt-thread.org/document/site/um4003-rtthread-programming-manual.pdf
https://www.rt-thread.org/document/site/tutorial/iot_board_tutorial.pdf
这个建立任务应该在while ...
确实只建立一次,有标志位控制,在建立的时就异常
mian函数里面的循环能不能作为一个独立的任务,,,一般系统下的mian函数不放循环的吧
mian函数里面的循环能不能作为一个独立的任务,,,一般系统下的mian函数不放循环的吧 ...
这里的main 也是一个任务
suncl110 发表于 2020-7-2 09:21
rt_hw_hard_fault_exception 一般是寻址失败,栈溢出的可能性比较大.
晓伍 发表于 2020-7-7 15:53
知道是死在哪里了吗
八层楼 发表于 2020-7-7 15:53
真是看不太好
观海 发表于 2020-7-7 16:00
单个任务不死机吗
guanjiaer 发表于 2020-7-7 16:00
帮楼主顶一下
heimaojingzhang 发表于 2020-7-7 16:00
楼主问题解决了吗
楼主问题解决了吗
删除第3个任务就可以
单个任务不死机吗
单个任务不会
知道是死在哪里了吗
创建第3个任务时
页: [1]
查看完整版本: 灵动芯片32L373移植了RT-THREAD后,建多个任务为何死机?
