MM32F003 非DMA 多路ADC采集
官方资料太少,手册和参考代码都没有关于一次采集多路的介绍,又不想用DMA,我就自己摸索了一个办法和大家分享,简单粗暴了点,有更好的办法请赐教!初始化代码(局部)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); //开GPIO时钟
//端口配置这里只贴一个通道
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4; //pin,
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //Output speed
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //GPIO mode
GPIO_Init(GPIOA, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); //启用ADC时钟
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_PRESCARE = ADC_PCLK2_PRESCARE_16; //ADC prescale factor ADC预分频系数
ADC_InitStructure.ADC_Mode = ADC_Mode_Single_Period ; //将ADC模式设置为连续转换模式/或单周期
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //AD data right-justified 数据右对齐
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1; // ADC外部触发源,用于常规通道转换
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 4, ADC_SampleTime_239_5Cycles);//通道注入组规则
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 5, ADC_SampleTime_239_5Cycles);//
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 9, ADC_SampleTime_239_5Cycles);//
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 14, ADC_SampleTime_239_5Cycles);//
ADC_TempSensorCmd(ENABLE);//内置温度,14通道
ADC_Cmd(ADC1, ENABLE);
手动软件启动
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
定期查询方式获取4路AD值
if(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) != 0)
ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
puiADData = (*(volatile unsigned int *)0x40012428)&0xFFF;//直接取地址
puiADData = (*(volatile unsigned int *)0x4001242C)&0xFFF;
puiADData = (*(volatile unsigned int *)0x4001243C)&0XFFF;
puiADData = (*(volatile unsigned int *)0x40012450)&0xFFF;
ADC_SoftwareStartConvCmd(ADC1, ENABLE);//再次启动转换
printf("=%d,=%d,=%d,=%d\r\n",puiADData,puiADData,puiADData,puiADData);//打印结果
楼主不错,这个方法也很实用,能不能把你的Printf()函数共享一下,我用官方的例程不能用,STM32,51的程序放进来也不能用。不知道哪根筋不对。 callhgd 发表于 2020-8-16 20:16
楼主不错,这个方法也很实用,能不能把你的Printf()函数共享一下,我用官方的例程不能用,STM32,51的程序 ...
//添加printf,需要在项目里的Target里勾选Use MicroLIB
//再添加如下代码
int fputc(int ch, FILE *f)
UART_SendData(UART, (unsigned char) ch);
while (!(UART->CSR & UART_FLAG_TXEMPTY));
return (ch);
//再添加如下代码
好的,谢谢! callhgd 发表于 2020-8-17 08:20
好的,谢谢!
兄弟,刚才用你的函数试了一下,还是不行,不知道为什么。{:dizzy:}发送16进制数据是正常的,printf()使用没有输出。你改了底层串口驱动函数吗? callhgd 发表于 2020-8-17 09:33
兄弟,刚才用你的函数试了一下,还是不行,不知道为什么。发送16进制数据是正常的,printf() ...
抱歉,有几天没看了,回帖晚了,我没改底层,你不会忘了#include <string.h>吧,没声明头文件编译不会报错,就是没打印输出, 直接寻址的方式,确实是一个不错的想法,方法用的很巧妙,适合使用。 非常感谢楼主分享 代码很详细 楼主的想法不错的,感谢楼主的分享。谢谢。
这个帖子很棒帮,顶起来。不错的。 感谢分享 楼主,请问一下你这个直接取址的地址在哪里可以查到?数据手册上没有讲到吧? 为什么不用DMA方式呢?不理解。 为什么楼主不用DMA操作呢?DMA多快,还省事。
每日要进步,要加油 十分感谢楼主的分享,确实是不错的资料。 DMA的ADC还是很棒的。一直使用。 这个操作很强 感谢分享,其实用DMA的话 能更快更简单一些
页:
[1]
