HC32L136开发板测评+OLED驱动及应用
奋斗多日,开发板的串口程序下载终于搞定了,再看时间已是凌晨4点了!在HC32L136开发板上配有一个笔段式的液晶屏,但无奈的是厂家却没提供一个能直接调用的显示函数。在没解决该显示屏的显示函数前,先以轻车熟路的OLED屏来实现显示的问题。由于手头的OLED屏是一款I2C接口的单色显示屏,故另其与MCU的连接关系为:PA11:SCL PA12:SDA使这2个引脚输出高低电平的语句定义为:#define OLED_SCLK_Set() Gpio_SetIO(GpioPortA, GpioPin11)#define OLED_SCLK_Clr() Gpio_ClrIO(GpioPortA, GpioPin11); #define OLED_SDIN_Set() Gpio_SetIO(GpioPortA, GpioPin12)#define OLED_SDIN_Clr() Gpio_ClrIO(GpioPortA, GpioPin12); 分配2个引脚为输出功能的函数为:void App_OledInit(void)
stc_gpio_cfg_t stcGpioCfg;
///< 打开GPIO外设时钟门控
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
///< 端口方向配置->输出(其它参数与以上(输入)配置参数一致)
stcGpioCfg.enDir = GpioDirOut;
///< 端口上下拉配置->下拉
stcGpioCfg.enPu = GpioPuDisable;
stcGpioCfg.enPd = GpioPdEnable;
///< GPIO IO OLED端口初始化
Gpio_Init(GpioPortA, GpioPin11, &stcGpioCfg);
Gpio_Init(GpioPortA, GpioPin12, &stcGpioCfg);
实现图1显示效果的主程序为:int32_t main(void)
stc_rtc_time_t readtime;
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);//GPIO外设时钟打开
Sysctrl_SetPeripheralGate(SysctrlPeripheralRtc,TRUE); //RTC模块时钟打开
Sysctrl_ClkSourceEnable(SysctrlClkRCL, TRUE);
RTC_Cfg(); //配置RTC
EnableNvic(RTC_IRQn, IrqLevel3, TRUE);//使能RTC中断向量
Rtc_Cmd(TRUE); //使能RTC开始计数
App_OledInit();
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"HC32L136 TEST",16);
OLED_ShowString(0,2,"OLED DISPLAY",16);
while (1);
图1OLED屏显示效果 实现RTC时间设置的函数为:void RTC_Cfg(void)
stc_rtc_initstruct_t RtcInitStruct;
RtcInitStruct.rtcAmpm = RtcPm; //12小时制
RtcInitStruct.rtcClksrc = RtcClkRcl; //内部低速时钟
RtcInitStruct.rtcPrdsel.rtcPrdsel = RtcPrds;//周期中断类型PRDS
RtcInitStruct.rtcPrdsel.rtcPrds = Rtc1S; //周期中断事件间隔
RtcInitStruct.rtcTime.u8Second = 0x55;
RtcInitStruct.rtcTime.u8Minute = 0x55;
RtcInitStruct.rtcTime.u8Hour = 0x10;
RtcInitStruct.rtcTime.u8Day = 0x06;
RtcInitStruct.rtcTime.u8DayOfWeek = 0x04;
RtcInitStruct.rtcTime.u8Month= 0x10;
RtcInitStruct.rtcTime.u8Year = 0x20;
RtcInitStruct.rtcCompen = RtcCompenEnable;
RtcInitStruct.rtcCompValue = 0;//补偿值根据实际情况进行补偿
Rtc_Init(&RtcInitStruct);
Rtc_AlmIeCmd(TRUE); //使能闹钟中断
实现图3RTC计时效果的主程序为:int32_t main(void)
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE); //GPIO外设时钟打开
RTC_Cfg(); //配置RTC
EnableNvic(RTC_IRQn, IrqLevel3, TRUE); //使能RTC中断向量
App_OledInit();
OLED_Init();
OLED_Clear();
OLED_ShowString(0,2,"OLED&RTC",16);
delay1ms(2000);
OLED_Clear();
OLED_ShowString(0,0,"20--",16);
OLED_ShowString(0,2," ::",16);
while (1)
if(flag == 1)
flag = 0;
Rtc_ReadDateTime(&readtime);
second = readtime.u8Second;
minute = readtime.u8Minute;
hour = readtime.u8Hour;
day = readtime.u8Day;
week = readtime.u8DayOfWeek;
month= readtime.u8Month;
year = readtime.u8Year;
OLED_ShowNum(16,0,year/16*10+year%16,2,16);
OLED_ShowNum(40,0,month/16*10+month%16,2,16);
OLED_ShowNum(64,0,day/16*10+day%16,2,16);
OLED_ShowNum(16,2,hour/16*10+hour%16,2,16);
OLED_ShowNum(40,2,minute/16*10+minute%16,2,16);
OLED_ShowNum(64,2,second/16*10+second%16,2,16);
图2RTC起始界面
图3RTC计时效果
多谢楼主测试我们的开发板,非常感谢! rickluo 发表于 2020-10-7 08:55
多谢楼主测试我们的开发板,非常感谢!
期待有新的开发板推出活动,一贯地给与支持!!! jinglixixi 发表于 2020-10-7 15:41
AT32F421 节后会弄! rickluo 发表于 2020-10-7 22:32
AT32F421 节后会弄!
大家值得期待,望大家积极参与! 能共享下代码,我折腾好几天,还是没点亮oled baiyunping333 发表于 2023-12-31 22:45
https://pan.baidu.com/s/1jZKWGmQdRcsto-OdbnPmbg 提取码:386h jinglixixi 发表于 2023-12-31 23:21
https://pan.baidu.com/s/1jZKWGmQdRcsto-OdbnPmbg 提取码 ...
压缩包没有hc32L30X,有hc32L13X的例子吗,文章就中的代码 能分享下文章中HC32L13X的代码吗 能贴一下i2c通信部分吗,找了很多教程都没点亮 大哥,能分享一下针对HC32L136的完整代码吗
页:
[1]
