Edge-X 设备服务开发(转)
Edge-X 设备服务开发一,设备驱动(device driver) 核心接口protocoldriver.go/ ProtocolDriver is a low-level device-specific interface used by
// by other components of an EdgeX Device Service to interact with
// a specific class of devices.
type ProtocolDriver interface {
// Initialize performs protocol-specific initialization for the device
// service. The given *AsyncValues channel can be used to push asynchronous
// events and readings to Core Data.
Initialize(lc logger.LoggingClient, asyncCh chan<- *AsyncValues) error
// HandleReadCommands passes a slice of CommandRequest struct each representing
// a ResourceOperation for a specific device resource.
HandleReadCommands(deviceName string, protocols mapcontract.ProtocolProperties, reqs []CommandRequest) ([]*CommandValue, error)
// HandleWriteCommands passes a slice of CommandRequest struct each representing
// Since the commands are actuation commands, params provide parameters for the individual
// command.
HandleWriteCommands(deviceName string, protocols mapcontract.ProtocolProperties, reqs []CommandRequest, params []*CommandValue) error
// Stop instructs the protocol-specific DS code to shutdown gracefully, or
// if the force parameter is 'true', immediately. The driver is responsible
// for closing any in-use channels, including the channel used to send async
// readings (if supported).
Stop(force bool) error
// AddDevice is a callback function that is invoked
// when a new Device associated with this Device Service is added
AddDevice(deviceName string, protocols mapcontract.ProtocolProperties, adminState contract.AdminState) error
// UpdateDevice is a callback function that is invoked
// when a Device associated with this Device Service is updated
UpdateDevice(deviceName string, protocols mapcontract.ProtocolProperties, adminState contract.AdminState) error
// RemoveDevice is a callback function that is invoked
// when a Device associated with this Device Service is removed
RemoveDevice(deviceName string, protocols mapcontract.ProtocolProperties) error
1、初始化函数:// AsyncValues : 异步通道,用来做异步事件发送
2、写函数HandleWriteCommands(deviceName string, protocols mapcontract.ProtocolProperties, reqs []CommandRequest, params []*CommandValue) error
入参:
在另外一个工程:github.com/edgexfoundry/go-mod-core-contracts/models/device.go
3、读函数// HandleReadCommands passes a slice of CommandRequest struct each representing
4、停止函数// Stop instructs the protocol-specific DS code to shutdown gracefully, or
5、添加设备回调函数 // AddDevice is a callback function that is invoked
6、更新设备回调函数// UpdateDevice is a callback function that is invoked
7、移除设备回调函数// RemoveDevice is a callback function that is invoked
页:
[1]
