jx_207 发表于 2020-10-19 21:03
玄宇芯-HC32L136板子 串口接收数据串问题
我在使用玄宇芯的HC32L136的DEMO板,在一直官方的SDK uart_int例子,自发自收,第一个字节能正常收到,后面的就不对了,请问有人碰到过吗?
jx_207 发表于 2020-10-19 21:04
void TxIntCallback(void)
void uart_send_byte(uint8_t by);
void RxIntCallback(void)
        uint8_t d;
        uint8_t rxBuffer ={0};
        //Uart_ClrStatus(UARTCH1,UartRC);
        d=Uart_ReceiveData(UARTCH1);
        uart_send_byte(d);
void ErrIntCallback(void)
void PErrIntCallBack(void)
void CtsIntCallBack(void)
void Uart_PortInit(void)
    stc_gpio_config_t stcGpioCfg;
    DDL_ZERO_STRUCT(stcGpioCfg);
    stcGpioCfg.enDir = GpioDirOut;
    Gpio_Init(GpioPortA,GpioPin2,&stcGpioCfg);
    Gpio_SetAfMode(GpioPortA,GpioPin2,GpioAf1);//TX
    stcGpioCfg.enDir = GpioDirIn;
    Gpio_Init(GpioPortA,GpioPin3,&stcGpioCfg);
    Gpio_SetAfMode(GpioPortA,GpioPin3,GpioAf1);//RX
void uart_init(void)
        uint16_t u16Scnt = 0;
        stc_uart_config_tstcConfig;
        stc_uart_irq_cb_t stcUartIrqCb;
        stc_uart_multimode_t stcMulti;
        stc_uart_baud_t stcBaud;
        en_uart_mmdorck_t enTb8;
        DDL_ZERO_STRUCT(stcConfig);
        DDL_ZERO_STRUCT(stcUartIrqCb);
        DDL_ZERO_STRUCT(stcMulti);
        DDL_ZERO_STRUCT(stcBaud);
            Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);//使能GPIO模块时钟
            Sysctrl_SetPeripheralGate(SysctrlPeripheralUart1,TRUE);//使能uart1模块时钟
        Uart_PortInit();
        stcUartIrqCb.pfnRxIrqCb   = RxIntCallback;//中断入口地址
        stcUartIrqCb.pfnTxIrqCb   = TxIntCallback;
        stcUartIrqCb.pfnRxFEIrqCb = ErrIntCallback;
        stcUartIrqCb.pfnPEIrqCb   = PErrIntCallBack;
        stcUartIrqCb.pfnCtsIrqCb= CtsIntCallBack;
        stcConfig.pstcIrqCb = &stcUartIrqCb;
        stcConfig.bTouchNvic = TRUE;
        if(TRUE == stcConfig.bTouchNvic)
                EnableNvic(UART1_IRQn,IrqLevel3,TRUE);
        stcConfig.enRunMode = UartMode3;//模式3
        stcConfig.enStopBit = Uart1bit;//1bit停止位
        stcMulti.enMulti_mode = UartNormal;//正常工作模式
        Uart_SetMultiMode(UARTCH1,&stcMulti);//多主机单独配置
        enTb8 = UartDataOrAddr;//偶校验
        Uart_SetMMDOrCk(UARTCH1,enTb8);
        Uart_Init(UARTCH1, &stcConfig);//串口初始化
        Uart_SetClkDiv(UARTCH1,Uart8Or16Div);//采样分频
        stcBaud.u32Pclk = Sysctrl_GetPClkFreq();
        stcBaud.enRunMode = UartMode3;
        stcBaud.u32Baud = 9600;
        u16Scnt = Uart_CalScnt(UARTCH1,&stcBaud);//波特率计算
        Uart_SetBaud(UARTCH1,u16Scnt);//波特率设置
        Uart_ClrStatus(UARTCH1,UartRC);//清接收请求
        Uart_EnableIrq(UARTCH1,UartRxIrq);//使能串口中断
        Uart_EnableFunc(UARTCH1,UartRx);//使能收发
        Uart_SendData(UARTCH1, by);
jinglixixi 发表于 2020-10-21 10:38
是否是因为接收后没释放,或没加一个小的延时使其相应有误。
jx_207 发表于 2020-10-31 16:57
换了个SDK,莫名好了
lxs0026 发表于 2020-10-31 21:34
sdk的问题吗?
lxs0026 发表于 2020-10-31 21:36
六年级 发表于 2020-11-1 21:42
我这边测试时候也是的,发送字符串的时候,中间总有几个字节是丢失的
页: [1]
查看完整版本: 玄宇芯-HC32L136板子 串口接收数据串问题
