34af9uc 发表于 2020-11-24 22:56
应广8核心测试FPC886/MF520
/*************FPC886/MF520***************/
/*************8核心测试******************/
/*************20201124*******************/
/*************qq:774145445***************/
/*************快手:共同学习stm8**********/
//                        _______@________
//                   led1--|1 pa2   pa1 20|--led5
//                   led2--|2 pa3ppa0 19|--led6
//                   led3--|3 pa4fpa7 18|--led7
//                   led4--|4 pa5cpa6 17|--led8
//                  _____|5 nc   8   nc 16|_____
//    烧录时与nc相连 |-----|6 gnd8vdd 15|-----| 烧录时与nc相连
//                     k1--|7 pb06pb7 14|
//                     k2--|8 pb1   pb6 13|
//                     k3--|9 pb2   pb5 12|
//                     k4--|10pb3_____pb4 11|
#include        "extern.h"
led1                bit                pa.2;
led2                bit                pa.3;
led3                bit                pa.4;
led4                bit                pa.5;
led5                bit                pa.1;
led6                bit                pa.0;
led7                bit                pa.7;
led8                bit                pa.6;
k1                        bit                pb.0;
k2                        bit                pb.1;
k3                        bit                pb.2;
k4                        bit                pb.3;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
pmode                31;                        ///8/8/8/8/8/8/8/8带宽共享
fppen        =        0xFF;                //8核全开
//有8个核心可以分时全部运行,可以分别干8件事.
//8核真爽!
$                led1                out,low;
$                led2                out,low;
$                led3                out,low;
$                led4                out,low;
$                led5                out,low;
$                led6                out,low;
$                led7                out,low;
$                led8                out,low;
$                k1                        in,pull;
$                k2                        in,pull;
$                k3                        in,pull;
$                k4                        in,pull;
while(1)
if(k1==1){led1        =0;}
nop;
if(k1==0){led1        =1;}
nop;
void        FPPA1 (void)
while(1)
if(k2==1){led2        =0;}
nop;
if(k2==0){led2        =1;}
nop;
//        goto        $;
void        FPPA2 (void)
while(1)
if(k3==1){led3        =0;}
nop;
if(k3==0){led3        =1;}
nop;
//        goto        $;
void        FPPA3 (void)
while(1)
if(k4==1){led4        =0;}
nop;
if(k4==0){led4        =1;}
nop;
//        goto        $;
void        FPPA4 (void)
while (1)
led5                =1;
.delay                10000;
led5                =0;
.delay                10000;
//        goto        $;
void        FPPA5 (void)
while (1)
        led6                =1;
        .delay                20000;
        led6                =0;
        .delay                20000;
//        goto        $;
void        FPPA6 (void)
while(1)
        led7                =1;
        .delay                20000;
        led7                =0;
        .delay                80000;
//        goto        $;
void        FPPA7 (void)
while(1)
        led8                =1;
        .delay                80000;
        led8                =0;
        .delay                20000;
//        goto        $;
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
页: [1]
查看完整版本: 应广8核心测试FPC886/MF520
