1129539617 发表于 2020-12-1 15:16
KF32LS201
为什么程序执行到 case100 后不会跳到case200 检测不到关机按键按下 求大佬讲解
void POWER_ON_OFF(void)
        static uint8_t POWER_ON_OFF_STATUS = 0;
        static uint32_t DET_COUNT = 0;
        while(1)
                switch(POWER_ON_OFF_STATUS)
                        case 0:        // 开机检测
                                if(ONOFF_DET == 0)DET_COUNT ++;
                                else DET_COUNT = 0;
                                if(DET_COUNT > 10000)
                                        GPIO_Set_Output_Data_Bits(POWER_LOCK_PORT,POWER_LOCK,Bit_SET);
                                        GPIO_Set_Output_Data_Bits(LED1_PORT,LED1,Bit_RESET);
                                        POWER_ON_OFF_STATUS =100;
                                        DET_COUNT = 0;
                        break;
                        case 100:
                                if(ONOFF_DET == 0)DET_COUNT=0 ;
                                else DET_COUNT++;
                                        POWER_ON_OFF_STATUS = 200;
                                        DET_COUNT = 0;
                                break;
                        case 200: //关机检测
                                if(ONOFF_DET == 0)DET_COUNT++;
                                else DET_COUNT=0;
                                if(DET_COUNT > 1000000)
                                        POWER_ON_OFF_STATUS = 250;
                                        DET_COUNT = 0;
                        break;
                        case 250:
                                if(ONOFF_DET == 0)DET_COUNT = 0;
                                else DET_COUNT ++;
                                if(DET_COUNT > 100000)
                                        DET_COUNT = 0;
                        break;
                        default:break;
搜索
复制
串联烧烤 发表于 2020-12-1 23:50
你不是自己加了break?
你不是自己加了break?
看清楚点啊楼主问的是条件判断不会跳
伊桑黑 发表于 2020-12-1 23:55
0会跳100 没道理100不会跳200吧 有空我拿电脑帮你看看
1129539617 发表于 2020-12-2 13:15
KF32LS201
#define       LED1       GPIO_PIN_MASK_2   //PB2
#define       LED1_PORT       GPIOB_SFR
#define       POWER_LOCK       GPIO_PIN_MASK_0   //PF0
#define       POWER_LOCK_PORTGPIOF_SFR
#define       POWER_DET       GPIO_PIN_MASK_4   //PF4
#define       POWER_DET_PORT       GPIOF_SFR
#define              ONOFF_DET              GPIO_Read_Input_Data_Bit(POWER_DET_PORT,POWER_DET)//读取PF4的输入电平
管脚定义
搜索
复制
页: [1]
查看完整版本: KF32LS201
