陈炼大雕萌妹 发表于 2021-1-1 14:23
window下基于vscode编译下载AT32工程备忘录
window环境搭建
1、window下需要提前安装vscode,然后收索插件iotlink,这个插件是华为开发的。感觉挺好用的。
2、安装完成之后重启vscode。
3、gcc编译的重点在于makefile,本项目工程的makefile是基于STM32cubemx生成的STM32 makefile工程,但是并不适用于雅特力的芯片,所以自己在基于这个上更改了一些.
makefile内容######################################
# target   //生成的hex文件名。
TARGET = Socket
# building variables
# debug build?
DEBUG = 1
# optimization   优化等级
OPT = -Og
# paths   生成编译文件的目录
# Build path
BUILD_DIR = build
# source用到的.c文件的路径\是makefile的换行符
# C sources
C_SOURCES =\
USER/main.c \
USER/system_at32f4xx.c \
USER/at32f4xx_it.c \
SYSTEM/delay/delay.c \
SYSTEM/sys/sys.c \
SYSTEM/usart/usart.c \
AT32F4xx_StdPeriph_Driver/src/at32f4xx_gpio_ex.c \
AT32F4xx_StdPeriph_Driver/src/at32f4xx_rcc.c \
AT32F4xx_StdPeriph_Driver/src/at32f4xx_usart.c \
AT32F4xx_StdPeriph_Driver/src/at32f4xx_tim.c \
AT32F4xx_StdPeriph_Driver/src/misc.c
# ASM sources   汇编文件,gcc的汇编文件与MDK的汇编文件不同,不要引用错了
ASM_SOURCES =\
CMSIS/CM4/DeviceSupport/startup/gcc/startup_at32f421k8t7.s
# binaries
PREFIX = arm-none-eabi-
# The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
# either it can be added to the PATH environment variable.
ifdef GCC_PATH
CC = $(GCC_PATH)/$(PREFIX)gcc
AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
CP = $(GCC_PATH)/$(PREFIX)objcopy
SZ = $(GCC_PATH)/$(PREFIX)size
else
CC = $(PREFIX)gcc
AS = $(PREFIX)gcc -x assembler-with-cpp
CP = $(PREFIX)objcopy
SZ = $(PREFIX)size
endif
HEX = $(CP) -O ihex
BIN = $(CP) -O binary -S
# CFLAGS   CPU的架构,AT32F4都是M4的芯片,所以都是cortex-m4
# cpu
CPU = -mcpu=cortex-m4
# fpu    开启硬件浮点类型
FPU = -mfpu=fpv4-sp-d16
# CFLAGS
# fpu
# NONE for Cortex-M0/M0+/M3
# float-abi
# mcu
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
# macros for gcc
# AS defines
AS_DEFS =
# C defines   类似MDK的C/C++里面的define配置
C_DEFS =\
-DAT_START_F421_V1_0 \
-DAT32F421K8T7 \
-DUSE_FULL_ASSERT
# AS includes
AS_INCLUDES =
# C includes头文件目录
C_INCLUDES =\
-ISYSTEM/delay \
-ISYSTEM/sys \
-ISYSTEM/usart \
-IAT32F4xx_StdPeriph_Driver/inc \
-IUSER \
-ICMSIS/CM4/DeviceSupport \
-ICMSIS/CM4/CoreSupport \
# compile gcc flags
ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
CFLAGS = $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
# LDFLAGS   链接ld文件的目录
# link script
LDSCRIPT = CMSIS/CM4/DeviceSupport/startup/gcc/linker/AT32F421x8_FLASH.ld
# libraries
LIBS = -lc -lm -lnosys
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# build the application
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
        $(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) [        DISCUZ_CODE_2        ]lt; -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
        $(AS) -c $(CFLAGS) [        DISCUZ_CODE_2        ]lt; -o $@
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
        $(CC) $(OBJECTS) $(LDFLAGS) -o $@
        $(SZ) $@
$(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(HEX) [        DISCUZ_CODE_2        ]lt; $@
$(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
        $(BIN) [        DISCUZ_CODE_2        ]lt; $@
$(BUILD_DIR):
        mkdir $@
# clean up
clean:
        del $(BUILD_DIR)
# dependencies
-include $(wildcard $(BUILD_DIR)/*.d)
# *** EOF ***
#库文件需要的往里面添加
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_adc.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_bkp.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_can.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_comp.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_crc.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_dac.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_dbgmcu.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_dma.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_ertc.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_eth.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_exti.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_flash.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_gpio_ex.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_iwdg.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_pwr.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_rcc.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_rtc.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_sdio.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_spi.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_syscfg.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_wwdg.c \
# AT32F4xx_StdPeriph_Driver/src/Src/at32f4xx_xmc.c
4、有了makefile工程,就可以导入vscode。
5、iotlink的使用教程 https://flyfishzy.github.io/iotstudio-doc/zh/,里面可以用openocd,调试debug,编写代码。iotlink的依赖项需要C/C++,大家记得安装。
c_cpp_properties.json配置文件,可以写,也可以直接勇敢C/C++插件配置{
    "env": {
      "sdkPath": "iot_link"
    "configurations": [
            "name": "Win32",
            "includePath": [
                "C:/Users/admin/.iotlink/tools/gcc-arm-none-eabi/arm-none-eabi/include",
                "C:/Users/admin/.iotlink/tools/gcc-arm-none-eabi/lib/gcc/arm-none-eabi/9.2.1/include",
                "${workspaceFolder}/**",
                "${workspaceFolder}/SYSTEM/delay",
                "${workspaceFolder}/AT32F4xx_StdPeriph_Driver/inc",
                "${workspaceFolder}/CMSIS/CM4/DeviceSupport",
                "${workspaceFolder}/CMSIS/CM4/CoreSupport",
                "${workspaceFolder}/SYSTEM/sys",
                "${workspaceFolder}/SYSTEM/usart",
                "${workspaceFolder}/USER",
                "${sdkPath}/**"
            "browse": {
                "limitSymbolsToIncludedHeaders": true
            "defines": [
                "_DEBUG",
                "__CC_ARM",
                "AT_START_F421_V1_0",
                "AT32F421K8T7",
                "USE_FULL_ASSERT",
                "USE_STDPERIPH_DRIVER"
            "intelliSenseMode": "msvc-arm",
            "cStandard": "c99",
            "cppStandard": "c++14",
            "compilerPath": ""
    "version": 4
gitee工程:https://gitee.com/elec123/socket
如果有想了解雅特力芯片的可以加群 1121757020
如果有想了解如何搭建换记得可以加群 274407988
muyichuan2012 发表于 2021-1-1 14:29
不错哦感谢楼主分享
发呆二极管 发表于 2021-1-2 17:57
给力,支持一下!vs系列天下第一!
单片小菜 发表于 2021-1-4 11:24
学习了,不错的帖子,学到了一些编程的规范等等。
nullptr 发表于 2021-1-20 22:35
vscode 的插件太多了,比如 eide, keil-assistant, platformio ... 都可以来开发单片机
不用自己写 makefile,c/c++ 插件也不用自己手写配置
页: [1]
查看完整版本: window下基于vscode编译下载AT32工程备忘录
