DMA 传输测试
// DMA传输源地址static uint32_t aSRC_Const_Buffer =
0x01020304, 0x05060708, 0x090A0B0C, 0x0D0E0F10,
0x11121314, 0x15161718, 0x191A1B1C, 0x1D1E1F20,
0x21222324, 0x25262728, 0x292A2B2C, 0x2D2E2F30,
0x31323334, 0x35363738, 0x393A3B3C, 0x3D3E3F40,
0x41424344, 0x45464748, 0x494A4B4C, 0x4D4E4F50,
0x51525354, 0x55565758, 0x595A5B5C, 0x5D5E5F60,
0x61626364, 0x65666768, 0x696A6B6C, 0x6D6E6F70,
0x71727374, 0x75767778, 0x797A7B7C, 0x7D7E7F80
// DMA传输目标地址
static uint32_t aDST_Buffer; // DMA通道配置,通过软件触发的方式,把aSRC_Const_Buffer数组的值传输到aDST_Buffer数组中
void App_Dma1Cfg(void)
stc_dma_cfg_t stcDmaCfg;
Sysctrl_SetPeripheralGate(SysctrlPeripheralDma,TRUE); //打开DMA时钟
DDL_ZERO_STRUCT(stcDmaCfg); //结构体变量值清零
DDL_ZERO_STRUCT(aDST_Buffer); //数组值清零
stcDmaCfg.enMode =DmaMskBlock; //选择块传输
stcDmaCfg.u16BlockSize = 0x01; //块传输个数
stcDmaCfg.u16TransferCnt = BUFFER_SIZE; //块传输次数,一次传输数据大小为 块传输个数*BUFFER_SIZE
stcDmaCfg.enTransferWidth = DmaMsk32Bit; //传输数据的宽度,此处选择字(32Bit)宽度
stcDmaCfg.enSrcAddrMode = DmaMskSrcAddrInc; //源地址自增
stcDmaCfg.enDstAddrMode = DmaMskDstAddrInc; //目的地址自增
stcDmaCfg.enDestAddrReloadCtl = DmaMskDstAddrReloadDisable;//禁止重新加载传输目的地址
stcDmaCfg.enSrcAddrReloadCtl = DmaMskSrcAddrReloadDisable; //禁止重新加载传输源地址
stcDmaCfg.enSrcBcTcReloadCtl = DmaMskBcTcReloadDisable; //禁止重新加载BC/TC值
stcDmaCfg.u32SrcAddress = (uint32_t)&aSRC_Const_Buffer; //指定传输源地址
stcDmaCfg.u32DstAddress = (uint32_t)&aDST_Buffer; //指定传输目的地址
stcDmaCfg.enRequestNum = DmaSWTrig; //设置为软件触发
stcDmaCfg.enTransferMode = DmaMskOneTransfer; //dma传输一次,DMAC传输完成时清除CONFA:ENS位
stcDmaCfg.enPriority = DmaMskPriorityFix; //各通道固定优先级,CH0优先级 > CH1优先级
Dma_InitChannel(DmaCh1,&stcDmaCfg);
Dma_EnableChannelIrq(DmaCh1); //传输成功完成时产生中断
EnableNvic(DMAC_IRQn,IrqLevel3,TRUE); //NVIC对应DMAC中断位使能
Dma_Enable(); //使能DMA
Dma_EnableChannel(DmaCh1); //使能DmaCh1
} //内存数据比较
static int32_t myMemcmp(uint8_t *mem1,uint8_t *mem2,uint32_t bytesize)
int i = 0;
uint8_t *p = mem1;
uint8_t *q = mem2;
if(p == NULL|| q == NULL)
return -1;
for(i = 0;i < bytesize;i++,p++,q++)
if(*p != *q)
return -1;
return 0;
// DMA中断
void Dmac_IRQHandler(void)
if(DmaTransferComplete == Dma_GetStat(DmaCh1))
//等待传输完成
if(myMemcmp((uint8_t *)&aDST_Buffer,(uint8_t *)&aSRC_Const_Buffer,BUFFER_SIZE) == -1)
Error_Handle();
Dma_ClrStat(DmaCh1);
} 感谢楼主分享经验 学习了,感谢楼主分享。 很不错的经验贴,支持一下楼主 Thank you.
页:
[1]
