11066 发表于 2021-1-24 19:57
基于Proteus学习单片机系列(十一)——LCD12864
#申请原创# #技术资源#
回复本贴,获取更多单片机资料
https://pan.baidu.com/s/15Z8WdZUz2XXd7slChW6NAA原文地址:https://blog.csdn.net/qq_39020934/article/details/80051715
提取码:lgmh
1、电路图
2、驱动代码
#include <intrins.h>
#include<ziku.c>
#define uchar unsigned char
#define uint unsigned int
uchar num[] = "0123456789";
sbit REST = P2^0;        //Reset signal, active"L"
sbit C_D = P2^1;        //L:data   H:code
sbit C_E = P2^2;        //Chip enable signal, active"L"
sbit R_D = P2^3;        //read signal, active"L"
sbit W_R = P2^4;        //write signal, active"L"
#define width                                       15        //显示区宽度
#define Graphic                     1
#define TXT                              0
#define LcmLengthDots            128
#define LcmWidthDots             64
/**************************12864液晶的相关函数**********************/
void delay_nms(uint i)
      while(i)
      i--;
void write_commond(uchar com)        //对液晶写一个指令
      C_E = 0;
      C_D = 1;
      R_D = 1;
      P0 = com;
      W_R = 0;        // write
      _nop_();
      W_R = 1;        // disable write
      C_E = 1;
      C_D = 0;
void write_date(uchar dat)        //对液晶写一个数据
      C_E = 0;
      C_D = 0;
      R_D = 1;
      P0 = dat;
      W_R = 0;
      _nop_();
      W_R = 1;
      C_E = 1;
      C_D = 1;
void write_dc(uchar com,uchar dat)        //写一个指令和一个数据
      write_date(dat);
      write_commond(com);
//写一个指令和两个数据
void write_ddc(uchar com,uchar dat1,uchar dat2)
      write_date(dat1);
      write_date(dat2);
      write_commond(com);
//LCD初始化函数
void F12864_init(void)
      REST = 0;
      delay_nms(2000);
      REST = 1;
      write_ddc(0x40,0x00,0x00);        //设置文本显示区首地址
      write_ddc(0x41,128/8,0x00);        //设置文本显示区宽度
      write_ddc(0x42,0x00,0x08);        //设置图形显示区首地址0x0800
      write_ddc(0x43,128/8,0x00);        //设置图形显示区宽度
      write_commond(0xA0);        //设置光标形状 8x8方块
      write_commond(0x80);        //显示方式设置 文本and图形(异或)
      write_commond(0x92);        //设置光标
      write_commond(0x9F);        //显示开关设置 文本开,图形开,光标闪烁关
//**************************//清显示存储器函数
void F12864_clear(void)
      unsigned int i;
      write_ddc(0x24,0x00,0x00);        //置地址指针为从零开始
         write_commond(0xb0);        //自动写
      for(i = 0;i < 128 * 64 ;i++)write_date(0x00);                                                         //清一屏
      write_commond(0xb2);        //自动写结束
      write_ddc(0x24,0x00,0x00);        //重置地址指针
//设定显示的地址
void goto_xy(uchar x,uchar y,uchar mode)
   uinttemp;
   temp = 128 / 8 * y + x;
   if(mode)        //mode = 1为Graphic
   {        //如果图形模式要加上图形区首地址0x0800
         temp = temp + 0x0100;
   write_ddc(0x24,temp & 0xff,temp / 256);        //地址指针位置
//显示一个ASCII码函数
void Putchar(uchar x,uchar y,uchar Charbyte)
   goto_xy(x,y,TXT);
   write_dc(0xC4,Charbyte-32);        //数据一次读写方式//查字符rom
void display_string(uchar x,uchar y,uchar *p)
      while(*p != 0)
                if(x > 15 )        //自动换行         128*64
                        x = 0;
                        y++;
                Putchar(x,y,*p);
                ++x;
                ++p;
void display_num(uchar x,uchar y,uchar z)
      uchar z1,z2;
      z1 = num;
      z2 = num;
      Putchar(x,y,z1);
      Putchar(x+1,y,z2);
//显示一串汉字,j = k + n为(n为要显示的字的个数),k为选择从哪个字开始
void dprintf_hanzi_string_1(struct typFNT_GB16 code *GB_16,uint X_pos,uint Y_pos,uchar j,uchar k)
      unsigned int address;
      unsigned char m,n;
      while(k < j)
                m = 0;
                address = LcmLengthDots / 8 * Y_pos + X_pos + 0x0800;
                for(n = 0;n < 16;n++)        //计数值16
                   write_ddc(0x24,(uchar)(address),(uchar)(address>>8));                        //设置显示存储器地址
                   write_dc(0xc0,GB_16.Mask);                                          //写入汉字字模左部
                   write_dc(0xc0,GB_16.Mask);                                             //写入汉字字模右部
                   address = address + 128/8;                                                   //修改显示存储器地址,显示下一列(共16列)
                X_pos += 2;
                k++;
caizhiwei 发表于 2021-1-26 21:45
还有人玩这个嗯
lindeijun 发表于 2021-4-16 10:15
初学,赞一个,谢谢啦!!
2669020082 发表于 2024-8-15 18:09
学习学习
dyx8899 发表于 2024-8-17 19:59
感谢分享
zhp7607 发表于 2024-11-28 11:20
初学,赞一个,谢谢啦!感谢分享
夜雨依丁 发表于 2024-12-10 14:53
初学,赞一个,谢谢分享
STCMCUNT018 发表于 2024-12-10 16:26
页: [1]
查看完整版本: 基于Proteus学习单片机系列(十一)——LCD12864
