junpeng324 发表于 2021-1-28 19:47
F407 网口配置
uint32_t System_Setup(void)
uint32_t ETH_Status;
RCC_ClockType RCC_Clocks;
/* Enable ETHERNET clock*/
RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_ETHMAC | RCC_AHBPERIPH_ETHMACTX |
                        RCC_AHBPERIPH_ETHMACRX, ENABLE);
/* Enable GPIOs and ADC1 clocks */
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOA | RCC_APB2PERIPH_GPIOB | RCC_APB2PERIPH_GPIOC |
                         RCC_APB2PERIPH_GPIOD | RCC_APB2PERIPH_GPIOE | RCC_APB2PERIPH_AFIO, ENABLE);
/* NVIC configuration */
NVIC_Configuration();
/* Configure the GPIO ports */
GPIO_Configuration();
/* Configure the Ethernet peripheral */
ETH_Status = Ethernet_Configuration();
/* SystTick configuration: an interrupt every 10ms */
RCC_GetClocksFreq(&RCC_Clocks);
SysTick_Config(RCC_Clocks.SYSCLK_Freq / 100);
/* Update the SysTick IRQ priority should be higher than the Ethernet IRQ */
/* The Localtime should be updated during the Ethernet packets processing */
NVIC_SetPriority (SysTick_IRQn, 1);
return ETH_Status;
junpeng324 发表于 2021-1-28 19:48
* @briefConfigure NVIC for ISR
* @paramNone
* @retval None
void NVIC_Configuration(void)
NVIC_InitType   NVIC_InitStructure;
/* 2 bit for pre-emption priority, 2 bits for subpriority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* Enable the Ethernet global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = ETH_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
junpeng324 发表于 2021-1-28 19:49
* @briefConfigure GPIO for ethernet
* @paramNone
* @retval None
void GPIO_Configuration(void)
GPIO_InitType GPIO_InitStructure;
#if MII_RX_REMAP
GPIO_PinsRemapConfig(GPIO_Remap_ETH, ENABLE);
#endif
/* ETHERNET pins configuration */
/* AF Output Push Pull:
    ETH_MII_MDIO / ETH_RMII_MDIO: PA2
    ETH_MII_MDC / ETH_RMII_MDC: PC1
/* Configure PA2 as alternate function push-pull MDIO*/
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_2;
GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
        /*PC1-->MDC*/
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_1;
GPIO_Init(GPIOC, &GPIO_InitStructure);
        /*MII Mode GPIO configuration*/
#ifdef MII_MODE
/**********************MII Tx Pin Define****************************/
          ETH_MII_TX0-->PB12 AF-PP
          ETH_MII_TX1-->PB13 AF-PP
                ETH_MII_TX2-->PC2AF-PP
                ETH_MII_TX3-->PB8AF-PP
                ETH_MII_TX_EN-->PB11 AF-PP
                ETH_MII_TX_CLK-->PC3
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_8 | GPIO_Pins_11 | GPIO_Pins_12 | GPIO_Pins_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_2 | GPIO_Pins_3;
        /**********************MII Rx Pin Define****************************/
#if MII_RX_REMAP/*IO PIN remaped*/
   ETH_MII_RX_DV-->PD8
   ETH_MII_RXD0-->PD9
   ETH_MII_RXD1-->PD10
   ETH_MII_RXD2-->PD11
   ETH_MII_RXD3-->PD12
       ETH_MII_RXCLK-->PA1
       ETH_MII_CRS-->PA0
       ETH_MII_COL-->PA3
       ETH_MII_RX_ER-->PB10
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_8 | GPIO_Pins_9 | GPIO_Pins_10 | GPIO_Pins_11 | GPIO_Pins_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0 | GPIO_Pins_1 | GPIO_Pins_3;
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_10;
#else
   ETH_MII_RX_DV-->PA7
   ETH_MII_RXD0-->PC4
   ETH_MII_RXD1-->PC5
   ETH_MII_RXD2-->PB0
   ETH_MII_RXD3-->PB1
       ETH_MII_RXCLK-->PA1
       ETH_MII_CRS-->PA0
       ETH_MII_COL-->PA3
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0 | GPIO_Pins_1 | GPIO_Pins_3 | GPIO_Pins_7;
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_4 | GPIO_Pins_5;
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0 | GPIO_Pins_1 | GPIO_Pins_10;
#endif//End MII RX REMAP
#endif //End MII mode
#ifdef RMII_MODE
/**********************RMII Tx Pin Define****************************/
          ETH_RMII_TX0-->PB12 AF-PP
          ETH_RMII_TX1-->PB13 AF-PP
                ETH_RMII_TX_EN-->PB11 AF-PP
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_11 | GPIO_Pins_12 | GPIO_Pins_13;
        /**********************RMII Rx Pin Define****************************/
   ETH_RMII_RX_DV-->PD8
   ETH_RMII_RXD0-->PD9
   ETH_RMII_RXD1-->PD10
       ETH_RMII_REF_CLK-->PA1
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_8 | GPIO_Pins_9 | GPIO_Pins_10;
        GPIO_InitStructure.GPIO_Pins =GPIO_Pins_1;
#else
   ETH_RMII_RX_DV-->PA7
   ETH_RMII_RXD0-->PC4
   ETH_RMII_RXD1-->PC5
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_1 | GPIO_Pins_7;
#endif//End RMII RX REMAP
#endif //End RMII mode
/* ADC Channel4 config --------------------------------------------------------*/
/* Configure PA4(ADC Channel4) as analog input -------------------------*/
#ifdef ADC_NECESSARY
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_ANALOG;
#endif
/* MCO pin configuration------------------------------------------------- */
/* Configure MCO (PA8) as alternate function push-pull */
#ifndef CRYSTAL_ON_PHY
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_8;
#endif
junpeng324 发表于 2021-1-28 20:01
uint32_t Ethernet_Configuration(void)
ETH_InitType ETH_InitStructure;
/* MII/RMII Media interface selection ------------------------------------------*/
#ifdef MII_MODE /* Mode MII with AT32F407-EVAL*/
GPIO_ETH_MediaInterfaceConfig(GPIO_ETH_MediaInterface_MII);
/* Get 25MHz from system clock 200MHz on PA8 pin (MCO) */
RCC_CLKOUTConfig(RCC_CLKOUT_SYSCLK, RCC_MCOPRE_8);
#endif
#elif defined RMII_MODE/* Mode RMII with AT32F407-EVAL */
GPIO_ETH_MediaInterfaceConfig(GPIO_ETH_MediaInterface_RMII);
        RCC_CLKOUTConfig(RCC_CLKOUT_SYSCLK, RCC_MCOPRE_8); /*25M to RMII Mode*/
#endif
#endif
        /*Reset phy*/
Reset_Phy();
/* Reset ETHERNET on AHB Bus */
ETH_DeInit();
/* Software reset */
ETH_SoftwareReset();
/* Wait for software reset */
while (ETH_GetSoftwareResetStatus() == SET);
/* ETHERNET Configuration ------------------------------------------------------*/
/* Call ETH_StructInit if you don't like to configure all ETH_InitStructure parameter */
ETH_StructInit(&ETH_InitStructure);
/* Fill ETH_InitStructure parametrs */
/*------------------------   MAC   -----------------------------------*/
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;//ETH_AutoNegotiation_Enable;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Enable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;//ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
#ifdef CHECKSUM_BY_HARDWARE
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
#endif
/*------------------------   DMA   -----------------------------------*/
/* When we use the Checksum offload feature, we need to enable the Store and Forward mode:
the store and forward guarantee that a whole frame is stored in the FIFO, so the MAC can insert/verify the checksum,
if the checksum is OK the DMA can handle the frame otherwise the frame is dropped */
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;//ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/* Configure Ethernet */
ETH_Status = ETH_Init(&ETH_InitStructure, PHY_ADDRESS);
/* Enable the Ethernet Rx Interrupt */
if(ETH_Status == ETH_DRIVER_SUCCESS) {
    ETH_DMAITConfig(ETH_DMA_INT_NIS | ETH_DMA_INT_R, ENABLE);
return ETH_Status;
junpeng324 发表于 2021-1-28 20:08
void static Reset_Phy(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT_PP;
        GPIO_ResetBits(GPIOC, GPIO_Pins_8);
        Delay_ms(2);
        GPIO_SetBits(GPIOC, GPIO_Pins_8);
        Delay_us(2);
junpeng324 发表于 2021-1-28 20:09
void LwIP_Init(void)
ip_addr_t ipaddr;
ip_addr_t netmask;
ip_addr_t gw;
uint8_t macaddress={0,0,0x44,0x45,0x56,1};
/* Initializes the dynamic memory heap defined by MEM_SIZE.*/
mem_init();
/* Initializes the memory pools defined by MEMP_NUM_x.*/
memp_init();
#if LWIP_DHCP//need DHCP server
ipaddr.addr = 0;
netmask.addr = 0;
gw.addr = 0;
#else
IP4_ADDR(&ipaddr, G_IP, G_IP, G_IP, G_IP);
IP4_ADDR(&netmask, G_MASK, G_MASK, G_MASK, G_MASK);
IP4_ADDR(&gw, G_GW, G_GW, G_GW, G_GW);
#endif
Set_MAC_Address(macaddress);
/* - netif_add(struct netif *netif, struct ip_addr *ipaddr,
            struct ip_addr *netmask, struct ip_addr *gw,
            void *state, err_t (* init)(struct netif *netif),
            err_t (* input)(struct pbuf *p, struct netif *netif))
   Adds your network interface to the netif_list. Allocate a struct
netif and pass a pointer to this structure as the first argument.
Give pointers to cleared ip_addr structures when using DHCP,
or fill them with sane numbers otherwise. The state pointer may be NULL.
The init function pointer must point to a initialization function for
your ethernet netif interface. The following code illustrates it's use.*/
netif_add(&netif, &ipaddr, &netmask, &gw, NULL, &ethernetif_init, &netif_input);
/*Registers the default network interface.*/
netif_set_default(&netif);
#if LWIP_DHCP
/*Creates a new DHCP client for this interface on the first call.
Note: you must call dhcp_fine_tmr() and dhcp_coarse_tmr() at
the predefined regular intervals after starting the client.
You can peek in the netif->dhcp struct for the actual DHCP status.*/
dhcp_start(&netif);
#endif
/*When the netif is fully configured this function must be called.*/
netif_set_up(&netif);
junpeng324 发表于 2021-1-28 20:12
void LwIP_Periodic_Handle(__IO uint32_t localtime)
/* TCP periodic process every 250 ms */
if (localtime - TCPTimer >= TCP_TMR_INTERVAL)
    TCPTimer =localtime;
    tcp_tmr();
/* ARP periodic process every 5s */
if (localtime - ARPTimer >= ARP_TMR_INTERVAL)
    ARPTimer =localtime;
    etharp_tmr();
#if LWIP_DHCP
/* Fine DHCP periodic process every 500ms */
if (localtime - DHCPfineTimer >= DHCP_FINE_TIMER_MSECS)
    DHCPfineTimer =localtime;
    dhcp_fine_tmr();
/* DHCP Coarse periodic process every 60s */
if (localtime - DHCPcoarseTimer >= DHCP_COARSE_TIMER_MSECS)
    DHCPcoarseTimer =localtime;
    dhcp_coarse_tmr();
#endif
页: [1]
查看完整版本: F407 网口配置
