比神乐 发表于 2021-1-29 12:56
【AT-START-F407测评】+ 串口收发
今天搞了一下串口
串口2
代码:
#include "at32f4xx.h"
#include "at32_board.h"
/** @addtogroup AT32F407_StdPeriph_Examples
/** @addtogroup USART_Interrupt
/* Private typedef -----------------------------------------------------------*/
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
/* Private define ------------------------------------------------------------*/
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define TxBufferSize2   (countof(TxBuffer2) - 1)
#define RxBufferSize1   TxBufferSize2
#define RxBufferSize2   TxBufferSize1
/* Private macro -------------------------------------------------------------*/
#define countof(a)   (sizeof(a) / sizeof(*(a)))
/* Private variables ---------------------------------------------------------*/
USART_InitType USART_InitStructure;
uint8_t TxBuffer1[] = "USART Interrupt Example: USART2 -> USART3 using Interrupt";
uint8_t TxBuffer2[] = "USART Interrupt Example: USART3 -> USART2 using Interrupt";
uint8_t RxBuffer1;
uint8_t RxBuffer2;
__IO uint8_t TxCounter1 = 0x00;
__IO uint8_t TxCounter2 = 0x00;
__IO uint8_t RxCounter1 = 0x00;
__IO uint8_t RxCounter2 = 0x00;
uint8_t NbrOfDataToTransfer1 = TxBufferSize1;
uint8_t NbrOfDataToTransfer2 = TxBufferSize2;
uint8_t NbrOfDataToRead1 = RxBufferSize1;
uint8_t NbrOfDataToRead2 = RxBufferSize2;
__IO TestStatus TransferStatus1 = FAILED;
__IO TestStatus TransferStatus2 = FAILED;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
/* Private functions ---------------------------------------------------------*/
* @brief   Main program
* @paramNone
* @retval None
int main(void)
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC configuration */
NVIC_Configuration();
/* Configure the GPIO ports */
GPIO_Configuration();
/* Initialize Leds mounted on board */
AT32_Board_Init();
/* USART2 and USART3 configuration ------------------------------------------------------*/
/* USART2 and USART3 configured as follow:
      - BaudRate = 9600 baud
      - Word Length = 8 Bits
      - One Stop Bit
      - No parity
      - Hardware flow control disabled (RTS and CTS signals)
      - Receive and transmit enabled
USART_StructInit(&USART_InitStructure);
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
/* Configure USART2 */
USART_Init(USART2, &USART_InitStructure);
/* Enable USART2 Receive and Transmit interrupts */
USART_INTConfig(USART2, USART_INT_RDNE, ENABLE);
//USART_INTConfig(USART2, USART_INT_TDE, ENABLE);
/* Enable the USART2 */
USART_Cmd(USART2, ENABLE);
while(1)
* @briefConfigures the different system clocks.
* @paramNone
* @retval None
/* Enable GPIO clock */
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOA | RCC_APB2PERIPH_GPIOD | RCC_APB2PERIPH_GPIOC | RCC_APB2PERIPH_AFIO, ENABLE);
/* Enable USART2 Clock */
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_USART2, ENABLE);
/* Enable USART3 Clock */
//RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_USART3, ENABLE);
* @briefConfigures the different GPIO ports.
* @paramNone
* @retval None
GPIO_InitType GPIO_InitStructure;
/* Enable the USART3 Pins Software Remapping */
//GPIO_PinsRemapConfig(GPIO_PartialRemap_USART3, ENABLE);
/* Enable the USART2 Pins Software Remapping */
//GPIO_PinsRemapConfig(GPIO_Remap_USART2, ENABLE);
/* Configure USART2 Rx as input floating */
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART3 Rx as input floating */
//GPIO_InitStructure.GPIO_Pins = GPIO_Pins_11;
//GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure USART2 Tx as alternate function push-pull */
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_2;
GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
///* Configure USART3 Tx as alternate function push-pull */
//GPIO_InitStructure.GPIO_Pins = GPIO_Pins_10;
* @briefConfigures the nested vectored interrupt controller.
* @paramNone
* @retval None
NVIC_InitType NVIC_InitStructure;
/* Configure the NVIC Preemption Priority Bits */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
/* Enable the USART2 Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* Enable the USART3 Interrupt */
//NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
//NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
//NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
//NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//NVIC_Init(&NVIC_InitStructure);
* @briefCompares two buffers.
* @parampBuffer1, pBuffer2: buffers to be compared.
* @paramBufferLength: buffer's length
* @retval PASSED: pBuffer1 identical to pBuffer2
*         FAILED: pBuffer1 differs from pBuffer2
while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
return PASSED;
#ifdefUSE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
   ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
void USART2_IRQHandler(void)
if(USART_GetITStatus(USART2, USART_INT_RDNE) != RESET)
    /* Read one byte from the receive data register */
    RxBuffer1 = USART_ReceiveData(USART2);
                /* Write one byte to the transmit data register */
    USART_SendData(USART2, RxBuffer1);
//if(USART_GetITStatus(USART2, USART_INT_TDE) != RESET)
//    /* Write one byte to the transmit data register */
//    USART_SendData(USART2, TxBuffer1);
//    if(TxCounter1 == NbrOfDataToTransfer1)
//      /* Disable the USART2 Transmit interrupt */
//      USART_INTConfig(USART2, USART_INT_TDE, DISABLE);
}效果图:
页: [1]
查看完整版本: 【AT-START-F407测评】+ 串口收发
