HK32F030K6Tx 硬件I2C 从机问题
源码如下void I2C1_Init(void)
I2C_InitTypeDef I2C_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_I2CCLKConfig(RCC_I2C1CLK_SYSCLK);
RCC_APB1PeriphClockCmd(RCC_APB1ENR_I2C1EN, ENABLE);
GPIO_InitSet(PI_DSI_HW_I2C_SCL_PIN, GPIO_Mode_AF, GPIO_OType_OD, GPIO_PuPd_UP);
GPIO_InitSet(PI_DSI_HW_I2C_SDA_PIN, GPIO_Mode_AF, GPIO_OType_OD, GPIO_PuPd_UP);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_1);
I2C_DeInit(I2C1);
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Disable;
I2C_InitStructure.I2C_DigitalFilter = 0; // disable
I2C_InitStructure.I2C_Timing = 0x002105070; // 0x30E32E44
I2C_InitStructure.I2C_OwnAddress1 = 0x70;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress= I2C_AcknowledgedAddress_7bit;
I2C_Init(I2C1, &I2C_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = I2C1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
I2C_ITConfig(I2C1, I2C_IT_TXIS
| I2C_IT_RXNE
| I2C_IT_ADDR
| I2C_IT_NACKF
| I2C_IT_STOPF
| I2C_IT_TC
| I2C_IT_BERR
| I2C_IT_ARLO
| I2C_IT_OVR
| I2C_IT_PECERR
| I2C_IT_TIMEOUT, ENABLE);
I2C_Cmd(I2C1, ENABLE);
void I2C1_IRQHandler(void)
volatile uint32_t ISR_Status = I2C1->ISR;
volatile uint8_t addr = (ISR_Status >> 16) & 0xFE;
I2C1->ICR = 0x3F38;// clear all interrupt flag
if((ISR_Status & I2C_ISR_ADDR) != 0) // Slave address matched
else
if (addr == 0x70)
if((ISR_Status & I2C_ISR_RXNE) != 0) // Data register not empt
else if(( ISR_Status & I2C_ISR_STOPF) != 0) // Stop detected
I2C1->CR1 |= 0x0001;
else if( (( ISR_Status & I2C_ISR_NACKF) != 0)
|| (( ISR_Status & I2C_ISR_TC) != 0)
|| (( ISR_Status & I2C_ISR_BERR) != 0)
|| (( ISR_Status & I2C_ISR_ARLO) != 0)
|| (( ISR_Status & I2C_ISR_OVR) != 0)
|| (( ISR_Status & I2C_ISR_PECERR) != 0)
|| (( ISR_Status & I2C_ISR_TIMEOUT) != 0)
|| (( ISR_Status & I2C_ISR_TXIS) != 0)
if(((ISR_Status & I2C_ISR_DIR) != 0))
I2C1->TXDR = I2C1->RXDR;
问题现象:
程序里面设置的是在中断中直接把 RXDR中的数据发送出去,但是实际上总是有一字节的的延迟,如图中所示,
0x70是从机地址,0x03是HK32从机I2C接收的数据,直接发出去的却是0x02(之前一个字节的数据),下一个字节才变成正常的0x03,然后又接收到 0x09的数据,第一次发送的却还是之前的0x03,下一个字节才变成 0x09
file:///C:/Users/Administrator/Desktop/2.bmp
是有什么地方配置的不正确吗? 我一般很少用硬件的I2C 没软件的来的更容易。我是真不会配置。 我一般不用硬件的I2C操作,每个芯片的都不一样的,还是习惯于使用软件的I2C来进行模拟的。
强烈建议楼主使用软件的I2C进行模拟的,硬件的不好用的。
你参考我这个例程看看
谢谢大家,用的是从机,软件模拟很麻烦,所以不得已才用硬件的。找了原厂的技术支持提供的demo例程换上能正常使用了。 ifxz0123 发表于 2021-2-24 11:50
你参考我这个例程看看
请问,有没有主机的例程? msq001 发表于 2021-3-2 11:00
谢谢大家,用的是从机,软件模拟很麻烦,所以不得已才用硬件的。找了原厂的技术支持提供的demo例程换上能 ...
原厂的例程能否分享一下? 使用I2C通讯的话,一直会出现问题的,这个是必然的。一定会有的问题。 老哥 可否分享下原厂的硬件IIc历程例程 可否提供一下硬件IIc例程{:smile:} 从机好像只能用硬件IIC, 请问下这个调试时序的软件是什么 msq001 发表于 2021-3-2 11:00
你好 原厂的demo可以提供嘛 先用IO模拟把功能调通 硬件IIC不通?先用IO模拟看看。 硬件I2C有问题吗? I2c总线一般拿来实现什么功能? 硬件I2C能与软件I2C一起用一个I2C通道么 硬件I2C 到底怎么样?
页:
[1]
