lxz600408 发表于 2021-2-15 20:20
MM32F0010 GPIO直观简单设置
由应用手册,分柝该芯片配置寄存器。实际仅是7种配置。我是如下定义:
#define GPIO_IN_AIN      0x00UL //模拟输入模式
#define GPIO_IN_FLOATING   0x04UL//浮空输入模式
#define GPIO_IN_UpDown   0x08UL //上拉/下拉输入模式 PxODR=1 上拉PxODR=0 下拉
#define GPIO_OUT_PP      0x01UL//通用推挽输出模式
#define GPIO_OUT_OD      0x05UL//通用开漏输出模式
#define GPIO_AF_PP         0x09UL//复用推挽输出模式
#define GPIO_AF_OD         0x0DUL//复用开漏输出模式
#define CNF_MODE_MASK      0x0FUL
//脚定义
#define CNF_MODE_Pin0       0
#define CNF_MODE_Pin1       4
#define CNF_MODE_Pin2       8
#define CNF_MODE_Pin3       12
#define CNF_MODE_Pin4       16
#define CNF_MODE_Pin5       20
#define CNF_MODE_Pin6       24
#define CNF_MODE_Pin7       28
#define CNF_MODE_Pin8       0
#define CNF_MODE_Pin9       4
#define CNF_MODE_Pin10      8
#define CNF_MODE_Pin11      12
#define CNF_MODE_Pin12      16
#define CNF_MODE_Pin13      20
#define CNF_MODE_Pin14      24
#define CNF_MODE_Pin15      28
本人实际应用全部脚位配置就如下:
GPIOA->CRL = 0; //GPIOA->CRL复位值: 0x4444 4444浮空输入模式
GPIOA->CRL |= ((GPIO_AF_PP << CNF_MODE_Pin7)|(GPIO_OUT_PP << CNF_MODE_Pin6)|
               (GPIO_OUT_PP << CNF_MODE_Pin5)|(GPIO_OUT_PP << CNF_MODE_Pin4)|
                   (GPIO_IN_UpDown << CNF_MODE_Pin3)|(GPIO_IN_AIN << CNF_MODE_Pin2)|
                     (GPIO_OUT_PP << CNF_MODE_Pin1)|(GPIO_AF_PP << CNF_MODE_Pin0));
GPIOA->CRH =0X04400000;////复位值: 0x4444 4444 不改变PA13/PA14
GPIOA->CRH |= ((GPIO_IN_AIN << CNF_MODE_Pin15)|(GPIO_AF_PP << CNF_MODE_Pin12)|
               (GPIO_OUT_PP << CNF_MODE_Pin11)|(GPIO_OUT_PP << CNF_MODE_Pin10)|
                   (GPIO_AF_PP << CNF_MODE_Pin9)|(GPIO_AF_PP << CNF_MODE_Pin8));
GPIOB->CRL &= ~((CNF_MODE_MASK << CNF_MODE_Pin1)|(CNF_MODE_MASK << CNF_MODE_Pin0));
GPIOB->CRL |= ((GPIO_OUT_PP << CNF_MODE_Pin1)|(GPIO_OUT_PP << CNF_MODE_Pin0));
里面有晴雨 发表于 2021-2-19 11:24
这样看,很直观的了。
页: [1]
查看完整版本: MM32F0010 GPIO直观简单设置
