请教AT34F403 串口4配置问题
请教大神,调了好久的串口4一直没调好,我跟串口5一样的配置,串口5可以,4 死活不行,感觉跟那个引脚有关,就是不知道在哪配置/*U4复用*/
void UART4__Init(void)
GPIO_InitType GPIO_InitStructure;
USART_InitType USART_InitStructure;
/*Enable the UART Clock*/
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_UART4, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_AFIO, ENABLE);
GPIO_PinsRemapConfig(AFIO_MAP6_UART4_0001, ENABLE);
/* Configure the UART4 TX pin */
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0;
GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure the UART4 RX pin */
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/*Configure UART param*/
USART_StructInit(&USART_InitStructure);
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(UART4, &USART_InitStructure);
USART_Cmd(UART4, ENABLE);
/*U5复用*/
void UART5__Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOB, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_UART5, ENABLE);
GPIO_PinsRemapConfig(AFIO_MAP5_USART5_0001, ENABLE);
/* Configure the UART5 TX pin */
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_9;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure the UART5 RX pin */
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_8;
USART_Init(UART5, &USART_InitStructure);
USART_Cmd(UART5, ENABLE);
你的芯片应该是403A吧,所以工程的配置(芯片选择、C\C++ define选择)要选403A,这样的话你会看到403A uart4 的 remap 应该是:AFIO_MAP6_UART4_0010,而不是 AFIO_MAP6_UART4_0001 ArterySW 发表于 2021-4-1 13:14
你的芯片应该是403A吧,所以工程的配置(芯片选择、C\C++ define选择)要选403A,这样的话你会看到403A uar ...
我用的是keil 5.24,在官方开发板例程的基础上改的,找了下at32f4xx_gpio.h,不管1.1.9还是1.2.4版里面都找不到AFIO_MAP6_UART4_0010 这一条,跟UART4有关的有且只有 AFIO_MAP6_UART4_0001这个{:mad:} fyp5593 发表于 2021-4-1 13:35
我用的是keil 5.24,在官方开发板例程的基础上改的,找了下at32f4xx_gpio.h,不管1.1.9还是1.2.4版里面都 ...
这两个版本都是老的,请下最新的1.3.0版本的BSP吧 ArterySW 发表于 2021-4-1 14:22
在哪里下?我之前下的库都忘了在哪下的了,官网好像找不到
页:
[1]
