hwhcgx 发表于 2021-4-7 11:02
GD32F450IIC没有波形
求助大佬们。板子IIC接的是PB8和PB9,配置也是照抄官方的,系统时钟也调好了,不知道为啥就是没波形,SDL和SDA一直是低电平。发从机地址也就超时了。这个是配置代码
i2c.h
#ifndef I2C_H
#define I2C_H
#include "gd32f4xx.h"
#define I2C0_SPEED            400000
#define I2C0_SLAVE_ADDRESS7   0xA0
#define I2C_TIMEOUT                                                 100000
enum I2C_ErrNum
      I2C_ERROR = 0,
      I2C_OK,
      I2C_START_TIMEOUT,
      I2C_SLAVEADDR_TIMEOUT,
      I2C_BUFEMPTY_TIMEOUT,
      I2C_REGADDR_TIMEOUT,
      I2C_DATA_TIMEOUT,
      I2C_STOP_TIMEOUT
void i2c0_init(void);
/* configure the GPIO ports */
void i2c0_gpio_config(void);
/* configure the I2C0 interfaces */
void i2c0_config(void);
enum I2C_ErrNum i2c0_codec_byte_write(uint8_t data, uint8_t regaddr,uint8_t slaveaddr);
#endif/* I2C_H */
i2c.c
      i2c0_gpio_config();
      i2c0_config();
    \brief      configure the GPIO ports
    \paramnone
    \param none
    \retval   none
    /* enable GPIOB clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    /* connect PB8 to I2C0_SCL */
    gpio_af_set(GPIOB, GPIO_AF_4, GPIO_PIN_8);
    /* connect PB9 to I2C0_SDA */
    gpio_af_set(GPIOB, GPIO_AF_4, GPIO_PIN_9);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_8);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_8);
    gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_9);
    gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_9);
    \brief      configure the I2C0 interfaces
    \paramnone
    \param none
    \retval   none
    /* enable I2C clock */
    rcu_periph_clock_enable(RCU_I2C0);
    /* configure I2C clock */
    i2c_clock_config(I2C0,I2C0_SPEED,I2C_DTCY_2);
    /* configure I2C address */
    i2c_mode_addr_config(I2C0,I2C_I2CMODE_ENABLE,I2C_ADDFORMAT_7BITS,I2C0_SLAVE_ADDRESS7);
    /* enable I2C0 */
    i2c_enable(I2C0);
    /* enable acknowledge */
    i2c_ack_config(I2C0,I2C_ACK_ENABLE);
    \brief      write one byte to the I2C slave
    \paramdata
    \paramregister address/only wrte data if NULL
    \param none
    \retval   none
                uint32_t timeout = I2C_TIMEOUT;
    /* wait until I2C bus is idle */
    while(i2c_flag_get(I2C0, I2C_FLAG_I2CBSY));
    /* send a start condition to I2C bus */
    i2c_start_on_bus(I2C0);
    /* wait until SBSEND bit is set */
    while(!i2c_flag_get(I2C0, I2C_FLAG_SBSEND))
                        if(0 == timeout--)
                              return I2C_START_TIMEOUT;
    /* send slave address to I2C bus */
    i2c_master_addressing(I2C0, slaveaddr, I2C_TRANSMITTER);
    /* wait until ADDSEND bit is set */
    while(!i2c_flag_get(I2C0, I2C_FLAG_ADDSEND))
                        if(0 == timeout--)
                              return I2C_SLAVEADDR_TIMEOUT;
    /* clear the ADDSEND bit */
    i2c_flag_clear(I2C0,I2C_FLAG_ADDSEND);
    /* wait until the transmit data buffer is empty */
    while(SET != i2c_flag_get(I2C0, I2C_FLAG_TBE))
                        if(0 == timeout--)
                              return I2C_BUFEMPTY_TIMEOUT;
    if(NULL != regaddr)
                        i2c_data_transmit(I2C0, regaddr);
                        /* wait until BTC bit is set */
                        while(!i2c_flag_get(I2C0, I2C_FLAG_BTC))
                        if(0 == timeout--)
                              return I2C_REGADDR_TIMEOUT;
    /* send the byte to be written */
    i2c_data_transmit(I2C0, data);
                        if(0 == timeout--)
                              return I2C_DATA_TIMEOUT;
    /* send a stop condition to I2C bus */
    i2c_stop_on_bus(I2C0);
    /* wait until the stop condition is finished */
    while(I2C_CTL0(I2C0)&0x0200)
                        if(0 == timeout--)
                              return I2C_STOP_TIMEOUT;
                return I2C_OK;
main.c
void initialization(void)
      led_gpio_config();
      systick_config();
      i2c0_init();
int main(void)
                enum I2C_ErrNum err = I2C_ERROR;
                initialization();
               /* turn on LED5*/
               gpio_bit_reset(GPIOB, GPIO_PIN_11);
                err = i2c0_codec_byte_write(1,NULL,0x18);
edyd 发表于 2021-4-7 11:31
你这while(1)死循环没有,执行一次就结束了。
elephant00 发表于 2025-5-30 15:43
IIC总线为开漏输出,必须外接上拉电阻。若未接上拉电阻,SDA和SCL线可能因浮空而被拉低。
jcky001 发表于 2025-5-30 15:43
在SDA(PB8)和SCL(PB9)引脚上分别添加4.7KΩ上拉电阻至VCC。
cr315 发表于 2025-5-30 15:44
硬件连接错误?
elephant00 发表于 2025-5-30 15:44
引脚可能存在虚焊、短路或与其他信号线干扰,导致信号异常。
页: [1]
查看完整版本: GD32F450IIC没有波形
