nongfuxu 发表于 2021-5-6 16:09
同样是做设计,他们的差别,不仅仅体现在技术水平上!
下面代码来自芯片厂家的驱动库函数
*                  Supported STM32F40xxx/41xxx devices
*      System Clock source                  | PLL (HSE)
*      SYSCLK(Hz)                           | 168000000
*      HCLK(Hz)                               | 168000000
*      AHB Prescaler                        | 1
*      APB1 Prescaler                         | 4
*      APB2 Prescaler                         | 2
*      HSE Frequency(Hz)                      | 25000000
*      PLL_M                                  | 25
*      PLL_N                                  | 336
*      PLL_P                                  | 2
*      PLL_Q                                  | 7
*      PLLI2S_N                               | NA
*      PLLI2S_R                               | NA
*      I2S input clock                        | NA
*      VDD(V)                                 | 3.3
*      Main regulator output voltage          | Scale1 mode
*      Flash Latency(WS)                      | 5
上面是给出设置“ 系统频率函数 ” void SetSysClock(void)之前的注释。
nongfuxu 发表于 2021-5-6 16:13
static void SetSysClock(void)
/*            PLL (clocked by HSE) used as System clock source                */
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* Enable HSE */
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
/* Wait till HSE is ready and if Time out is reached exit */
do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
else
    HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
#if defined (STM32F40_41xxx) || defined (STM32F427_437xx) || defined (STM32F429_439xx)
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
    /* PCLK1 = HCLK / 4*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV4;
#endif /* STM32F40_41xxx || STM32F427_437x || STM32F429_439xx */
#if defined (STM32F401xx)
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV1;
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;
#endif /* STM32F401xx */
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |
                   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till the main PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
#if defined (STM32F427_437xx) || defined (STM32F429_439xx)
    /* Enable the Over-drive to extend the clock frequency to 180 Mhz */
    PWR->CR |= PWR_CR_ODEN;
    while((PWR->CSR & PWR_CSR_ODRDY) == 0)
    PWR->CR |= PWR_CR_ODSWEN;
    while((PWR->CSR & PWR_CSR_ODSWRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_5WS;
#endif /* STM32F427_437x || STM32F429_439xx*/
#endif /* STM32F40_41xxx*/
    FLASH->ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_2WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= RCC_CFGR_SW_PLL;
    /* Wait till the main PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
else
{ /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
nongfuxu 发表于 2021-5-6 16:19
再看另外一家公司给出的驱动函数,注解能省则省。
======***前面没有注释***=======
nongfuxu 发表于 2021-5-6 16:22
static void SysClkConfig(void)
    stc_clk_sysclk_cfg_t    stcSysClkCfg;
    stc_clk_xtal_cfg_t      stcXtalCfg;
    stc_clk_mpll_cfg_t      stcMpllCfg;
    MEM_ZERO_STRUCT(stcSysClkCfg);
    MEM_ZERO_STRUCT(stcXtalCfg);
    MEM_ZERO_STRUCT(stcMpllCfg);
    /* Set bus clk div. */
    stcSysClkCfg.enHclkDiv= ClkSysclkDiv1;// 100MHz
    stcSysClkCfg.enExclkDiv = ClkSysclkDiv2;// 50MHz
    stcSysClkCfg.enPclk0Div = ClkSysclkDiv1;// 100MHz
    stcSysClkCfg.enPclk1Div = ClkSysclkDiv2;// 50MHz
    stcSysClkCfg.enPclk2Div = ClkSysclkDiv4;// 25MHz
    stcSysClkCfg.enPclk3Div = ClkSysclkDiv4;// 25MHz
    stcSysClkCfg.enPclk4Div = ClkSysclkDiv2;// 50MHz
    CLK_SysClkConfig(&stcSysClkCfg);
    /* Switch system clock source to MPLL. */
    /* Use Xtal as MPLL source. */
    stcXtalCfg.enMode      = ClkXtalModeOsc;
    stcXtalCfg.enDrv         = ClkXtalLowDrv;
    stcXtalCfg.enFastStartup = Enable;
    CLK_XtalConfig(&stcXtalCfg);
    CLK_XtalCmd(Enable);
    /* MPLL config. */
    stcMpllCfg.pllmDiv = 1ul;
    stcMpllCfg.plln    =50ul;
    stcMpllCfg.PllpDiv = 4ul;
    stcMpllCfg.PllqDiv = 4ul;
    stcMpllCfg.PllrDiv = 4ul;
    CLK_SetPllSource(ClkPllSrcXTAL);
    CLK_MpllConfig(&stcMpllCfg);
    /* flash read wait cycle setting */
    EFM_Unlock();
    EFM_SetLatency(5ul);
    EFM_Lock();
    /* Enable MPLL. */
    CLK_MpllCmd(Enable);
    /* Wait MPLL ready. */
    while(Set != CLK_GetFlagStatus(ClkFlagMPLLRdy))
    CLK_SetSysClkSource(CLKSysSrcMPLL);
nongfuxu 发表于 2021-5-6 17:00
再看下面一段代码,摘自驱动库串口例子程序
    //初始化串口用端口 Initialize USART IO */
    PORT_SetFunc(USART_RX_PORT, USART_RX_PIN, USART_RX_FUNC, Disable);//PortE
    PORT_SetFunc(USART_TX_PORT, USART_TX_PIN, USART_TX_FUNC, Disable);
这是使用(使能),还是不用(禁止)呀?
nongfuxu 发表于 2021-5-6 17:01
PORT_SetFunc 函数原型
** \brief   Set Port Pin function
** \param   enPort               GPIO port index, This parameter can be
**                                     any value of @ref en_port_t
** \param   u16Pin               GPIO pin index, This parameter can be
**                                     any value of @ref en_pin_t
** \param   enFuncSel            Function selection, This parameter can be
**                                     any value of @ref en_port_func_t
** \param    enSubFunc             The new state of the gpio sub-function.
** \arg   Enable                     Enable.
** \arg   Disable                  Disable.
** \retvalOk                         Set successful to corresponding pins
en_result_t PORT_SetFunc(en_port_t enPort, uint16_t u16Pin, en_port_func_t enFuncSel,\
                  en_functional_state_t enSubFunc)
fcccc 发表于 2021-5-6 20:51
这个代码是GD32吗?
            /* main function setting */
            PFSRx->FSEL = enFuncSel;//功能选择寄存器:各端口的主功能配置
            /* sub function enable setting */
            PFSRx->BFE = (Enable == enSubFunc ? Enable : Disable); //功能选择寄存器:各端口的副功能配置
nongfuxu 发表于 2021-5-6 22:13
en_result_t PORT_SetFunc (...)
    for (u8PinPos = 0u; u8PinPos < 16u; u8PinPos ++)
      if (u16Pin & (uint16_t)(1ul<<u8PinPos))
            PFSRx = (stc_port_pfsr_field_t *)((uint32_t)(&M4_PORT->PFSRA0) \
                  + 0x40ul * enPort + 0x4ul * u8PinPos);
            PFSRx->FSEL = enFuncSel;//功能选择寄存器(PFSRxy)
其中功能选择寄存器:各端口的副功能配置,是不是用于在 “有些应用 情 况,需要将一个端口同时设成两种功能”场合?
其中功能选择寄存器:各端口的副功能配置,是不是用于在 “有些应用 情 况,需要将一个端口同时设成两种功 ...
文档是可以省略的,写文档成本太高了。呵呵!
caizhiwei 发表于 2021-5-7 09:39
华大的库吗?
wuwei888 发表于 2021-5-7 10:05
你觉得谁好,学谁的就完了
825cow 发表于 2021-5-7 13:40
没有对比就没有伤害
fcccc 发表于 2021-5-7 16:39
现在代码大部分流行自注释了吧.
不过下面这写法个别地方有点容易产生歧义.
单片小菜 发表于 2021-5-7 22:56
感谢楼主的分享,不错的想法。
忘了停止 发表于 2021-5-27 21:20
感觉象是水文,如果真是水文,值"二毛五分钱",如果不是水文,请楼主海涵.要比较就要和更好的比较,和不如你的比较有什么意思?
页: [1]
查看完整版本: 同样是做设计,他们的差别,不仅仅体现在技术水平上!
