[公司承接] FIL挖矿系统开发(APP案例)
1753|0
 楼主| qqq232021 发表于 2021-5-25 14:41 | 显示全部楼层 |阅读模式
价格:1 元
App, TE, TI, AC, ni, ck
FIL挖矿系统开发(APP案例)▋T_l59_源2O92_码9783▋FIL挖矿软件开发,FIL挖矿模式开发,FIL挖矿APP开发,FIL挖矿源码开发 该**收集于互联网,如有违-规及侵·权请联·系作者删·除!仅作为开发需求者的模式案例参考作用,不是要做系统的玩家不懂勿扰!!!(看清楚再加)
FIL是存储挖矿,矿工根据其实际封装了多少数据并向链上提交了复制证明从而获得有效算力(有效存力),有效算力越高,矿工获得区块奖励的概率越大。算力越大的矿工,获得区块打包的权利或者概率越大,这里就有赢票率和出块率的参数。赢票率就是赢得选票的概率,出块率就是获得区块奖励的概率。
  我们做个对比,BTC挖矿购买的矿机算力是不变的,买了矿机接入互联网之后,每天产生多少币是个固定的值;而FIL是存储挖矿,FIL的算力是根据封装了多少有效数据来计算的,今天封装了1 T,算力就是1 T,而且算力还在不断积累。
Fil is storage mining. According to how much data it actually encapsulates, miners submit replication proof to the chain, so as to obtain effective computing power (effective memory). The higher the effective computing power, the greater the probability of miners getting block rewards. The greater the calculation power, the greater the right or probability of getting block packing. Here are the parameters of winning ticket rate and block out rate. The winning rate is the probability of winning votes, and the block rate is the probability of winning block awards.
Let's make a comparison. The computing power of mining machines purchased by BTC mining is unchanged. After the mining machines are connected to the Internet, the amount of money generated each day is a fixed value; Fil is used to store and mine. The calculation power of fil is calculated according to how much effective data is encapsulated. Today, with 1 t encapsulated, the calculation power is 1 T, and the calculation power is still accumulating.
