9dome猫 发表于 2021-6-28 23:23
MM32F013x芯片学习-TIM1发互补PWM波形
调试过程中因为疏忽了一个位的操作,导致无输出,一番检查后发现MOE位必须要使能,否则,无波形输出.使能BDTR的MOE位后,波形正常输出,总体操作还是比较简单的,除了MOE没有使能外,其他寄存器的配置很顺利。
9dome猫 发表于 2021-6-28 23:24
该模块优点是操作简单,可互补输出,插入死区,通道极性可修改,灵活关闭通道,
缺点是当通道被关闭后,无法修改被关闭通道的电平,只能是默认的低电平,这里还不够灵活。
9dome猫 发表于 2021-6-28 23:27
void TIM1_pwm_init(void)
    //pin mux
    RCC->AHBENR |= RCC_AHBENR_GPIOB; //enable GPIOB clock
    //B14->TIM1_CH1
    GPIOB->CRH &=  ~(GPIO_CNF_MODE_MASK << GPIO_CRH_CNF_MODE_14_Pos);
    GPIOB->CRH |= GPIO_CNF_MODE_AF_PP<< GPIO_CRH_CNF_MODE_14_Pos;
    GPIOB->AFRH &= ~GPIO_AFRH_AFR14;
    GPIOB->AFRH |= (GPIO_AF_MODE7 << GPIO_AFRH_AFR14_Pos);
    //B13->TIM1_CH1N
    GPIOB->CRH &=  ~(GPIO_CNF_MODE_MASK << GPIO_CRH_CNF_MODE_13_Pos);
    GPIOB->CRH |= GPIO_CNF_MODE_AF_PP<< GPIO_CRH_CNF_MODE_13_Pos;
    GPIOB->AFRH &= ~GPIO_AFRH_AFR13;
    GPIOB->AFRH |= (GPIO_AF_MODE2 << GPIO_AFRH_AFR13_Pos);
    //init timer1
    RCC->APB2ENR |= RCC_APB2ENR_TIM1;//enable clock
    TIM1->PSC = 71;// 71+1
    TIM1->ARR = 50;// 50us
    TIM1->DIER |= TIM_DIER_UIEN;//enable update interrupt
    TIM1->CCR1 = 25;//duty
    //oc1 configure
    TIM1->CCMR1 &= ~TIM_CCMR1_CC1S;//output
    TIM1->CCMR1 |= TIM_CCMR1_OC1FE;
    TIM1->CCMR1 |= TIM_CCMR1_OC1PE;
    TIM1->CCMR1 |= TIM_CCMR1_OC1M_PWM1;
    //output control
    TIM1->CCER |= TIM_CCER_CC1EN;
    TIM1->CCER &= ~TIM_CCER_CC1P;
    TIM1->CCER |= TIM_CCER_CC1NEN;
    TIM1->CCER &= ~TIM_CCER_CC1NP;
    //TIM1->CCER |= TIM_CCER_CC1NP;
    //set dead time
    TIM1->CR1 |= TIM_CR1_CKD_DIV4;
    TIM1->BDTR |= 36;// 2us
    TIM3->CR1 |= TIM_CR1_ARPE;   //ARPEenable
    TIM1->CR1 |= TIM_CR1_CEN;//counter enable
    TIM1->BDTR |= TIM_BDTR_MOEN;//主输出使能
    NVIC_SetPriority(TIM1_BRK_UP_TRG_COM_IRQn,1);
    NVIC_EnableIRQ(TIM1_BRK_UP_TRG_COM_IRQn);
void TIM1_BRK_UP_TRG_COM_IRQHandler(void)
    if(TIM1->SR & TIM_SR_UIF)
        TIM1->SR &= ~TIM_SR_UIF;
        LED1_TOGGLE;
chenjun89 发表于 2021-7-3 08:22
谢谢分享经验
页: [1]
查看完整版本: MM32F013x芯片学习-TIM1发互补PWM波形
