【NuMaker-M471测评】OLED屏显示驱动
前面我们介绍了驱动SPI接口LCD5110显示屏的方法,这次介绍一下如何驱动I2C接口的OLED屏,该OLED屏为0.91寸单色屏。相对于LCD5110屏来讲,OLED屏更节省GPIO口。为了更便于使用,这里直接使用Arduino接口来控制OLED屏,相应的引脚连接关系为:SDA ---PC1SCL ---PC0具体的实物连接如下图所示: 实物连接与显示效果 为实现高低电平的输出其语句定义为:#define OLED_SCLK_Clr()PC0=0#define OLED_SCLK_Set()PC0=1#define OLED_SDIN_Clr()PC1=0#define OLED_SDIN_Set()PC1=1 相应的OLED屏初始化函数为:void OLED_Init(void){
Write_IIC_Command(0xAE); //display off
Write_IIC_Command(0x40);//--set start line address
Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
Write_IIC_Command(0xc8);//Set COM Output Scan Direction
Write_IIC_Command(0x81);//--set contrast control register
Write_IIC_Command(0xff);
Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
Write_IIC_Command(0xa6);//--set normal display
Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
Write_IIC_Command(0x1F);
Write_IIC_Command(0xd3);//-set display offset
Write_IIC_Command(0x00);//-not offset
Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
Write_IIC_Command(0xf0);//--set divide ratio
Write_IIC_Command(0xd9);//--set pre-charge period
Write_IIC_Command(0x22);
Write_IIC_Command(0xda);//--set com pins hardware configuration
Write_IIC_Command(0x02);
Write_IIC_Command(0x8d);//--set DC-DC enable
Write_IIC_Command(0x14);
Write_IIC_Command(0xdb);//--set vcomh
Write_IIC_Command(0x49);//0x20,0.77xVcc
Write_IIC_Command(0xaf);//--turn on oled panel
模拟I2C的启动与停止的函数为:void IIC_Start()
OLED_SCLK_Set();
TIMER_Delay(TIMER0, 2);
OLED_SDIN_Set();
OLED_SDIN_Clr();
OLED_SCLK_Clr();
void IIC_Stop()
OLED_SCLK_Set();
OLED_SDIN_Clr();
OLED_SDIN_Set();
模拟I2C方式字节数据的函数为:void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
unsigned char m,da;
da=IIC_Byte;
OLED_SCLK_Clr();
for(i=0;i<8;i++)
m=da;
m=m&0x80;
if(m==0x80)
相应的清屏函数为:void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD);
OLED_WR_Byte (0x00,OLED_CMD);
OLED_WR_Byte (0x10,OLED_CMD);
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
OLED屏的字符显示函数为:void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
unsigned char c=0,i=0;
c=chr-' ';
if(x>Max_Column-1){x=0;y=y+2;}
if(Char_Size ==16)
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16,OLED_DATA);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
else {
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WR_Byte(F6x8,OLED_DATA);
实现显示效果的主程序为:int main()
uint32_t i,j;
SYS_Init();
GPIO_SetMode(PB, BIT14, GPIO_MODE_OUTPUT);
GPIO_SetMode(PC, BIT1, GPIO_MODE_OUTPUT);
GPIO_SetMode(PC, BIT0, GPIO_MODE_OUTPUT);
GPIO_SetMode(PH, BIT4, GPIO_MODE_INPUT);
PB14 = 1;
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"M471 TEST",16);
OLED_ShowString(0,2,"OLED DISPLAY",16);
while(1)
PB14 = 1;
TIMER_Delay(TIMER0, 500000);
PB14 = 0;
工程打包分享分享啊 测评很顺利啊 laocuo1142 发表于 2021-8-18 15:26
测评很顺利啊
哈,抓空弄一点。 建议尝试一下硬件收发器的,不要GPIO 非常好用的屏幕,价格还不贵。 mintspring 发表于 2023-2-19 17:31
非常好用的屏幕,价格还不贵。
是,挺实用的。 这个使用的硬件iic的吗、 lzbf 发表于 2023-3-11 22:01
这个使用的硬件iic的吗、
向来不用硬件I2C “梦幻显示器”,有机发光显示器 看着刷屏还有横线呢 SPI的通信速度是多大 belindagraham 发表于 2023-3-14 14:04
看着刷屏还有横线呢
试一试适当减小发送数据时的延时值 olivem55arlowe 发表于 2023-3-14 15:34
SPI的通信速度是多大
是采用I2C接口控制 在编写驱动程序时,需要考虑图像处理算法、字模库、字符绘制等问题。 OLED屏幕通常有SPI和I2C两种接口方式,需要根据具体情况选择合适的接口方式。 为了简化程序开发和降低硬件成本,可以选用内置OLED控制器的OLED屏幕。 可以采用逐行逐点的方式来检查显示效果。 olivem55arlowe 发表于 2023-3-14 15:34
SPI的通信速度是多大
这是IIC吧
页:
[1]
