关于HR31型湿敏电阻程序问题
#include"def.h"void DelayXus(U8 k);//延时子程序
S16 GetTemp(U16 i);//温度转化子程序
U16 Tansfom(U16 HumAD,S16 Tem);//湿度转化子程序
void HumTemTrans(U16 *Hum,S16 *tem)
U8 i = 0,k = 0;
U16 GETADCT,GETADCH = 0;
U16 SumHum,SumTem,AvgHum,AvgTem,ResultHu;
S16 ResultTem;//温度
CLK_Init();//对时钟进行初始化
IO_Init();//IO口初始化,使IO1与IO2置为强推拉模式
//初始化AD0与AD1
while(1)
CLRIO2();
SETIO1();
DelayXus(250);
GETADCH += GetADCResult(CHRH);//湿度ADC值
DelayXus(210);//减去大概的AD采样时间
CLRIO1();
SETIO2();
DelayXus(250);
GETADCT += GetADCResult(CHRT);//温度ADC采样
DelayXus(210);
if((++i)>=30)//一次采样30个周期
AvgTem = GETADCT/30;
AvgHum = GETADCH/30;
if((++k)>=5)
CLRIO2();//让IO1与IO2同时置为低电平,减小直流时间段
CLRIO1();
//由于开始一次采样误差较大,去掉AvgTem
SumTem = AvgTem+AvgTem+AvgTem+AvgTem;
SumTem = SumTem/4;
SumHum = AvgHum+AvgHum+AvgHum+AvgHum;
SumHum = SumHum/4;
ResultTem = GetTemp(SumTem);//得到温度
//通过函数查表得到对应湿度值
//可以将阻值全部转化成对应AD值,通过快速查表,省去很大的内存空间
ResultHu = Tansfom(SumHum,ResultTem);
*Hum = (uint)ResultHu;
*tem = (int)ResultTem;
break;//退出
GETADCH = 0;
GETADCT = 0;
i=0;
说明:湿度转化必须根据温度查表算出对应湿度。如温度在25℃,湿度在60%时对应阻抗为25.5K,则对应AD1口的AD值为625≈1024*39K/(39K+25.5K//1M) (假定单片机为10位ADC)。
//湿度转化子程序
参数:Tem 温度10倍结果 如25.2℃ 则Tem输入为252
HumAD湿度采样ADC值当前为10bitADC
返回:湿度值10倍结果
const unsigned int TAD[]={
//HR31
// 90%-80%-70%-60%-50%-40%-30%-20%-10% (RH)
879,798,634,424,238,113, 55, 41, 39, //0℃
898,820,676,468,273,128, 59, 42, 39, //5℃
912,849,711,507,307,148, 64, 43, 39, //10℃
925,873,745,552,339,164, 69, 44, 39, //15℃
933,888,773,586,366,182, 74, 45, 39, //20℃
942,903,804,625,399,200, 81, 47, 40, //25℃
949,912,824,655,424,218, 89, 49, 40, //30℃
953,921,842,684,452,241, 98, 50, 40, //35℃
959,929,858,711,483,258,106, 52, 40, //40℃
963,938,873,731,504,266,114, 54, 41, //45℃
967,944,884,749,525,281,121, 56, 41 //50℃
unsigned int CurAD;
u16 Trana(s16 Tem,u16 HumAD)
u16 Rehum,k;
u8 num;
if(Tem<=0)//0摄氏度的使用0的
for(num=0;num<9;num++)
CurAD = TAD;
Rehum = 0 - Tem;
CurAD = TAD-(TAD-TAD)*Rehum/50;
else if(Tem>=500)//超过50摄氏度的
Rehum = Tem - 500;
CurAD = TAD+(TAD-TAD)*Rehum/50;
else
for(k=1;k<11;k++)//从1开始
if(Tem<(k*50)) //温度有做10倍数
Rehum = k*50-Tem;
k = 9*k;
CurAD = TAD - (TAD-TAD)*Rehum/50;//
break;
if(HumAD<CurAD)//10%--
Rehum =100-(CurAD-HumAD)*100/(CurAD-CurAD);
if(Rehum>100)Rehum=0;
// else
// if(HumAD>=CurAD)//--90%
// Rehum = (HumAD-CurAD)*105/(CurAD-CurAD)+900;
else
for(k=1;k<9;k++)//从1开始,也就是 90%>HumAD>80%
if(HumAD>=CurAD) //湿度在90%-80%-70%-60%-50%-40%
Rehum =(HumAD-CurAD)*100/(CurAD-CurAD)+900-k*100;//
break;
if(Rehum>=999)Rehum=999;
return Rehum;
这是厂家提供的demo ,前面AD转换 以及温度补偿算法能看懂,到最后转化成实际湿度的程序是怎么转换的,看不明白。求大神提点提点,小弟不胜感激!{:lol:} 用的是查表法吧?
页:
[1]
