chenjunt 发表于 2021-11-14 22:35
关于光电编码器测速问题
基于STM32单片机,利用光电编码器测速,光电编码器转动但是串口上显示脉冲数一直是0.
代码如下:
#include "stm32f10x.h"
#include <stdio.h>
void delay(uint32_t);
void COM_Config(void);
void GPIO_Configuration(void);
void TIM2_Configuration(void);
int fputc(int ch, FILE *f);
int fgetc( FILE *f);
int ActualSpeed=0;
int Times=1;
int main(void)
      COM_Config();
      GPIO_Configuration();
      TIM2_Configuration();
    while (1)
             delay(10000000);
               ActualSpeed=TIM_GetCounter(TIM2);
               printf(" 实际转速=%d%d \n\r",ActualSpeed,Times++);
    USART_InitTypeDef USART_InitStructure;
      /*使能GPIOD端口时钟、复用功能时钟*/
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO, ENABLE);
      /*使能USART2时钟*/
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
      /*串口2重映射*/
      GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART2, &USART_InitStructure);
    USART_Cmd(USART2, ENABLE);
/*外部脉冲输入管脚         PC6 */
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
/*TIM2对脉冲计数*/
voidTIM2_Configuration(void)
      TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);
    TIM_DeInit(TIM2);
    TIM_TimeBaseStructure.TIM_Period = 0xFFFF;      //?自动重装载值,值越小频率越大,值越大频率越小
    TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
    TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
    TIM_ETRClockMode2Config(TIM2, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);          //外部时钟模式2,计数器在选定输入端的每个上升沿计数
    TIM_SetCounter(TIM2, 0);         //设置寄存器寄存值
    TIM_Cmd(TIM2, ENABLE);
void delay(__IO uint32_t nCount)
for (; nCount != 0; nCount--);
#ifndef MicroLIB
//#pragma import(__use_no_semihosting)             //没有实现fgetc时需要声明该参数
/* 标准库需要的支持函数 使用printf()调试打印不需要实现该函数 */
struct __FILE
      int handle;
    /* Whatever you require here. If the only file you are using is */
    /* standard output using printf() for debugging, no file handling */
    /* is required. */
FILE __stdout;
//定义_sys_exit()以避免使用半主机模式
_sys_exit(int x)
      x = x;
/* 重定义fputc函数 如果使用MicroLIB只需要重定义fputc函数即可 */
    /* Place your implementation of fputc here */
         /* e.g. write a character to the USART */
    USART_SendData(USART2, (uint8_t) ch);
    /* Loop until the end of transmission */
    while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET)
    return ch;
可以直接使用putchar
不需要再定义 int putchar(int ch),因为stdio.h中有如下定义
#define putchar(c) putc(c, stdout)
int ferror(FILE *f) {
    /* Your implementation of ferror */
    return EOF;
#endif
FILE __stdin;
int fgetc(FILE *fp)
      int ch = 0;
    while(USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET)
    ch = (int)USART2->DR & 0xFF;
    putchar(ch); //回显
      return ch;
不知道哪里出错了,请各位大神指教。
jiajs 发表于 2021-11-14 22:36
用示波器看看编码器的输出
chenho 发表于 2021-11-14 22:39
用示波器看编码器输出,编码器需要与电机连接吗?
juventus9554 发表于 2021-11-14 22:41
用手转动编码器即可,速度低更容易观察
renyaq 发表于 2021-11-14 22:42
能够显示脉冲波形就证明编码器是正常的对吗?
heweibig 发表于 2021-11-14 22:44
参照器件手册看波形,波形正常则编码器就没问题
zwll 发表于 2021-11-14 22:47
可能要上拉电阻
dengdc 发表于 2021-11-14 22:49
你这个编码器应该是正交编码器的吧
zwll 发表于 2021-11-14 22:53
一般电机的测速都用到带光栅的正交编码器哦
juventus9554 发表于 2021-11-14 22:56
是串口的问题吗?
renyaq 发表于 2021-11-14 22:58
光电编码器有信号吗?
zhanghqi 发表于 2021-11-14 23:00
光电编码器的分辨率为?
chenho 发表于 2021-11-14 23:02
有干扰了
pengf 发表于 2021-11-14 23:05
采用定时中断读取是最合理的
songqian17 发表于 2021-11-14 23:07
有数据信号吗?
jiaxw 发表于 2021-11-14 23:09
反转计数异常?
jiajs 发表于 2021-11-14 23:12
查看一下光电脉冲编码器的结构和工作原理
yszong 发表于 2021-11-14 23:14
先查看一下硬件吧。
zwll 发表于 2021-11-14 23:19
你的代码发送呢?》
stly 发表于 2021-11-14 23:22
是不是输出的数据不正确呢?
页: [1] 2
查看完整版本: 关于光电编码器测速问题
