AD数码管显示异常
#include <pic.h>#include <math.h>
//#include <myfuncs1.h>
//#include <seg74.h>
#include <htc.h>
#define SEG_BITSEL_PORT PORTD //位选端口
#define SEG_BITSEL_PORT_DIR TRISD //位选端口的方向寄存器
#define SEG_FONT_PORT PORTC //字形输出端口
#define SEG_FONT_PORT_DIR TRISC //字形输出端口的方向寄存器
#define DLY_MS 67
const char Seg7TableN[]={0b11000000,0b11111001,0b10100100,0b10110000,0b10011001,0b10010010,0b10000010,0b11111000,0b10000000,0b10010000};
__CONFIG(FOSC_HS & WDTE_ON & PWRTE_OFF & BOREN_ON & LVP_ON & CPD_OFF & WRT_OFF & CP_OFF);
unsigned int g_ADRTable = {0};
unsigned char g_Count=0;
bit OverFlag = 0;//12位转换次数完成标志位清零;
void delayms (int ms);
void DisplayData (unsigned int iData);
interrupt ISR (void)
if ( ADIE && ADIF)
ADIF = 0;
g_ADRTable=(((unsigned int)ADRESH)<<8)+ADRESL;
g_Count++;
if(g_Count==12)
g_Count =0;
OverFlag=1;//
else
GO_DONE = 1;//启动AD
else
while(1);
void main(void)
//voidDisplayData();
char i=0,j=0;
int tmp = 0;//
int adc_v = 0;
TRISA0 = 1;
SEG_BITSEL_PORT_DIR = 0;//位选端口的方向寄存器,确定输出端口
SEG_FONT_PORT_DIR = 0;//字形输出端口的方向寄存器,确定输出端口
ADFM = 1;
PCFG3:PCFG0 = 0000;
ADCON0 = 0B11000001;
ADIE = 1;
ADIF = 0;
PEIE = 1;
GIE = 1;
for(i=0;i<15;i++)
GO_DONE = 1;
while(GO_DONE)
if(OverFlag==1)
for(i=0;i<12;i++)//冒泡法排序
for(j=i+1;j<12;j++)
if(g_ADRTable > g_ADRTable)
tmp = g_ADRTable;
g_ADRTable = g_ADRTable;
g_ADRTable = tmp;
tmp = 0;
for(i=2;i<10;i++)
tmp = tmp + g_ADRTable;
tmp = tmp >>3;//将数按照 2进制像右移动.每向右移动一位,相当于 除2的n次幂
adc_v = tmp;
adc_v = ((long)adc_v*5000/1023);
OverFlag = 0;
GO_DONE = 1;
DisplayData(adc_v);
void DisplayData (unsigned int iData )
char i=0,j=0;//
char k = 0,NumStr[ 5 ]={0,0,0,0,0};
NumStr=iData / 1000;//取整
NumStr=iData % 1000/100;
NumStr=iData % 100/10;
NumStr=iData % 10;
for(i=0;i<10;i++)
SEG_BITSEL_PORT = k =0X01;
for(j=0;j<=4;j++)
SEG_BITSEL_PORT = k;
if(j==1)
SEG_FONT_PORT = Seg7TableN]&0b01111111;
else
SEG_FONT_PORT = Seg7TableN];
delayms(5);
k = k <<1;//把1向左移1为显示
int i=0,j =0;
for(i=0;i < ms;i++)
for(j =0; j < DLY_MS;j++)
//帮忙看下是什么原因,4位数码管电压显示均为0,麻烦知道的发烧友指点呀,
扫描频率不对吧,太快或太慢,建议先一位一位点亮再说,一步一步调。 一叶倾城wwq 发表于 2021-11-30 10:30
我尝试了,结果还是不可以,不知道问题具体出在哪里 AD转换部分有没问题,是不是转换结果就是0 ningling_21 发表于 2021-11-30 11:24
你是说这个吗?
if(j==1)
//将这个修改成
if(j==1)
//结果还是一样,没有解决任何问题 这个问题需要分为两部分:一是数码管驱动问题,而是AD采集和转换问题。写个for循环,把显示值从0000-》1111-》2222.。。。-》9999都显示对了,确认驱动没有问题,然后再看AD采样是否正确,AD采样输入给一个固定电压,在转换完成以后打断点看转换的数值是否是预期的,如果AD转换没有问题那就去找AD值转换到显示的问题,这个应该很容易就能找到问题 void DisplayData (unsigned int iData )
char i=0,j=0;//
NumStr=iData % 10;
for(i=0;i<10;i++)
for(j=0;j<=4;j++)
if(j==1)
else
delayms(5);
这个函数有问题。
显示数字进行切换时。应当关闭当前显示。比如SEG_BITSEL_PORT=0 或者 SEG_FONT_PORT=0xff;
比如先关闭SEG_BITSEL_PORT 驱动,然后 设置下一个字符 SEG_FONT_PORT,然后打开显示,驱动 SEG_BITSEL_PORT 。 细看问题不少。这个程序显示函数应当在中断中执行。要不然每次显示都停留在最后一个字上。还有看样子只有4位数显示,可是却定义了5位数的数组,显示指针也错乱了。
得推导重写。先写出一个定时中断函数。然后添加应用 直接放代码估计没几个人看,先表述问题,然后描述处理过程,有问题的话自己都表述不下去了。
页:
[1]
