奔跑的牛 发表于 2021-12-23 17:37
[M480] QSPI 4-BIT Transmission
[*]Application: This example code is used for the M480 series microcontroller (MCU) to send QSPI 4 serial data bits simultaneously.
[*]BSP Version: M480 BSP CMSIS V3.05.001
[*]Hardware: NuMaker-M483KG V1.1
This example code is used to configure two QSPIs to transfer serial data bits to other device. Through 2-bit transfer mode, two QSPIs transfer the four serial data bits simultaneously.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1221143146
页: [1]
查看完整版本: [M480] QSPI 4-BIT Transmission
