ZCC541AKP替代SY5864
DescriptionThe ZCC541A/B series is a high input voltage
(40V), low-dropout linear regulator (LDO) able to
provide 1A load current. The ZCC541A/B family
LDO offers EN pin to enable and disable the LDO
output, EN pin can take 40V input voltage.
The LDO features very fast response against line
voltage transient and load current transient, and
ensures no overshoot voltage during the LDO start
up and short circuit recovery
The device features integrated short-circuit and
thermal shutdown protection.
Fixed voltages of 5.0V , 3.3V , 3.0V and 1.8V
are available on ZCC541BKP with adjustable
output voltages to 0.6V on ZCC541AKP.
Features
Fixed and adjustable output voltages to 0.6V
High Input Voltage Rating:Up to 40V
High Output Current:1A
High PSRR:65dB at 1kHZ
Low Dropout Voltage:1.5V@1A
Fixed Output Voltages:
1.8V, 3.0V, 3.3V,5.0V and ADJ
High-accuracy Output Voltage: ±2%
Fast Transient Response
Integrated Short-Circuit Protection
Enable pin is available
Integrated Thermal Protection
Available Packages:ESOP8
页:
[1]
