xxmmi 发表于 2022-1-2 12:43
timer2进不了中断
或一开中断就死机了
使用STM32F103TB,中密度器件,裸机,各位大大给看看
dingy 发表于 2022-1-2 12:46
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
xxmmi 发表于 2022-1-2 12:48
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
      uint8 i   = 0;
      uint32 code = 0;
PeriphClkEnable();
      NVIC_Configuration();
      PinCfg();
      Timer2Init();
xxmmi 发表于 2022-1-2 12:50
void PeriphClkEnable(void)
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA
                               | RCC_APB2Periph_GPIOB
//        | RCC_APB2Periph_GPIOC
        | RCC_APB2Periph_GPIOD
//        | RCC_APB2Periph_GPIOE
                               | RCC_APB2Periph_AFIO
                               | RCC_APB2Periph_USART1
//                              | RCC_APB2Periph_ADC1
//                              | RCC_APB2Periph_TIM1
        , ENABLE);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2
//                              | RCC_APB1Periph_USART3
//        | RCC_APB1Periph_UART4
//        | RCC_APB1Periph_UART5
//        | RCC_APB1Periph_I2C1
//        | RCC_APB1Periph_I2C2
//                              | RCC_APB1Periph_DAC
                         | RCC_APB1Periph_TIM2
        , ENABLE);
xxmmi 发表于 2022-1-2 12:52
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Enable the TIM2 global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
xxmmi 发表于 2022-1-2 12:54
void Timer2Init(void)
//         NVIC_InitTypeDef NVIC_InitStructure;
TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
//   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
//   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
//   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
//   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
//   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//   NVIC_Init(&NVIC_InitStructure);
TIM_TimeBaseStructure.TIM_Period = F_MY / 2;                        /* 设置自动重载寄存器值为最大值      */
TIM_TimeBaseStructure.TIM_Prescaler = (uint16)PRESCALER - 1;      /* 计数频率为主频 / PRESCALER      */
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
      TIM_ARRPreloadConfig(TIM2, ENABLE);
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
TIM_ITConfig(TIM2, TIM_IT_Update , ENABLE);//开启计数中断
/* TIM2 enable counter */
TIM_Cmd(TIM2, ENABLE);//开启时钟
xxmmi 发表于 2022-1-2 12:56
void TIM2_IRQHandler(void)
      if(TIM_GetITStatus(TIM2,TIM_IT_Update)!=RESET)
                TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
//               TIM_Cmd(TIM2, DISABLE);
//               printf("\n\r0x%08x", 0x12345678);
                Flag = 1;
pangb 发表于 2022-1-2 12:58
这个103的例子一堆吧,官方的开发资源包里有这个应用的例子吧
pengf 发表于 2022-1-2 17:02
看了下程序没啥问题,你用CUBE软件生成初始化代码看看
huangchui 发表于 2022-1-2 17:04
用CUBE生成一个也行,简单不用怎么调试。
chuxh 发表于 2022-1-2 17:05
你也可以换成、TIM3试试,看下你的定时器配置是否有问题
supernan 发表于 2022-1-2 17:07
换个定时器试下,我没怎么用TIM2 一般TIM3或者TIM5
wyjie 发表于 2022-1-2 17:09
感觉进不了中断或一开中断就死机,
supernan 发表于 2022-1-2 17:11
注意启动文件里的中断函数名跟你实际函数体是否一致,注意选正确的启动文件;
huangchui 发表于 2022-1-2 17:13
另外相关中断请求位在中断里做了清除没有;
jlyuan 发表于 2022-1-2 17:15
cubeF 1里有个TIM3的例子,不过用宏表示了,应该可以直接修改成2,你试试看
supernan 发表于 2022-1-2 17:17
* @file    TIM/TIM_TimeBase/Src/main.c
* @authorMCD Application Team
* @version V1.5.0
* @date    14-April-2017
* @brief   This sample code shows how to use STM32F1xx TIM HAL API to generate
*          a time base of one second with the corresponding Interrupt request.
* @attention
* <h2><center>&copy; COPYRIGHT(c) 2016 STMicroelectronics</center></h2>
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
*   1. Redistributions of source code must retain the above copyright notice,
*      this list of conditions and the following disclaimer.
*   2. Redistributions in binary form must reproduce the above copyright notice,
*      this list of conditions and the following disclaimer in the documentation
*      and/or other materials provided with the distribution.
*   3. Neither the name of STMicroelectronics nor the names of its contributors
*      may be used to endorse or promote products derived from this software
*      without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32F1xx_HAL_Examples
/** @addtogroup TIM_TimeBase
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* TIM handle declaration */
TIM_HandleTypeDef    TimHandle;
/* Prescaler declaration */
uint32_t uwPrescalerValue = 0;
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void Error_Handler(void);
/* Private functions ---------------------------------------------------------*/
* @briefMain program
* @paramNone
* @retval None
int main(void)
/* STM32F1xx HAL library initialization:
       - Configure the Flash prefetch
       - Systick timer is configured by default as source of time base, but user
         can eventually implement his proper time base source (a general purpose
         timer for example or other time source), keeping in mind that Time base
         duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
         handled in milliseconds basis.
       - Set NVIC Group Priority to 4
       - Low Level Initialization
HAL_Init();
/* Configure the system clock to 24 MHz */
SystemClock_Config();
/* Configure LED3 & LED4 */
BSP_LED_Init(LED3);
BSP_LED_Init(LED4);
/*##-1- Configure the TIM peripheral #######################################*/
    In this example TIM3 input clock (TIM3CLK)is set to APB1 clock (PCLK1),
    since APB1 prescaler is equal to 1.
      TIM3CLK = PCLK1
      PCLK1 = HCLK
      => TIM3CLK = HCLK = SystemCoreClock
    To get TIM3 counter clock at 10 KHz, the Prescaler is computed as following:
    Prescaler = (TIM3CLK / TIM3 counter clock) - 1
    Prescaler = (SystemCoreClock /10 KHz) - 1
    Note:
   SystemCoreClock variable holds HCLK frequency and is defined in system_stm32f1xx.c file.
   Each time the core clock (HCLK) changes, user had to update SystemCoreClock
   variable value. Otherwise, any configuration based on this variable will be incorrect.
   This variable is updated in three ways:
      1) by calling CMSIS function SystemCoreClockUpdate()
      2) by calling HAL API function HAL_RCC_GetSysClockFreq()
      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
/* Compute the prescaler value to have TIMx counter clock equal to 10000 Hz */
uwPrescalerValue = (uint32_t)(SystemCoreClock / 10000) - 1;
/* Set TIMx instance */
TimHandle.Instance = TIMx;
/* Initialize TIMx peripheral as follows:
       + Period = 10000 - 1
       + Prescaler = (SystemCoreClock/10000) - 1
       + ClockDivision = 0
       + Counter direction = Up
TimHandle.Init.Period            = 10000 - 1;
TimHandle.Init.Prescaler         = uwPrescalerValue;
TimHandle.Init.ClockDivision   = 0;
TimHandle.Init.CounterMode       = TIM_COUNTERMODE_UP;
TimHandle.Init.RepetitionCounter = 0;
TimHandle.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_Base_Init(&TimHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
/*##-2- Start the TIM Base generation in interrupt mode ####################*/
/* Start Channel1 */
if (HAL_TIM_Base_Start_IT(&TimHandle) != HAL_OK)
    /* Starting Error */
    Error_Handler();
while (1)
* @briefPeriod elapsed callback in non blocking mode
* @paramhtim : TIM handle
* @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
BSP_LED_Toggle(LED3);
* @briefSystem Clock Configuration
*         The system Clock is configured as follow :
*            System Clock source            = PLL (HSE)
*            SYSCLK(Hz)                     = 24000000
*            HCLK(Hz)                     = 24000000
*            AHB Prescaler                  = 1
*            APB1 Prescaler               = 1
*            APB2 Prescaler               = 1
*            HSE Frequency(Hz)            = 8000000
*            HSE PREDIV1                  = 2
*            PLLMUL                         = 6
*            Flash Latency(WS)            = 0
* @paramNone
* @retval None
RCC_ClkInitTypeDef clkinitstruct = {0};
RCC_OscInitTypeDef oscinitstruct = {0};
/* Enable HSE Oscillator and activate PLL with HSE as source */
oscinitstruct.OscillatorType= RCC_OSCILLATORTYPE_HSE;
oscinitstruct.HSEState      = RCC_HSE_ON;
oscinitstruct.HSEPredivValue= RCC_HSE_PREDIV_DIV2;
oscinitstruct.PLL.PLLState    = RCC_PLL_ON;
oscinitstruct.PLL.PLLSource   = RCC_PLLSOURCE_HSE;
oscinitstruct.PLL.PLLMUL      = RCC_PLL_MUL6;
if (HAL_RCC_OscConfig(&oscinitstruct)!= HAL_OK)
    while(1);
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
   clocks dividers */
clkinitstruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
clkinitstruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
clkinitstruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
clkinitstruct.APB2CLKDivider = RCC_HCLK_DIV1;
clkinitstruct.APB1CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&clkinitstruct, FLASH_LATENCY_0)!= HAL_OK)
    while(1);
* @briefThis function is executed in case of error occurrence.
* @paramNone
* @retval None
/* Turn LED4 on */
BSP_LED_On(LED4);
while (1)
#ifdefUSE_FULL_ASSERT
* @briefReports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @paramfile: pointer to the source file name
* @paramline: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
   ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
chuxh 发表于 2022-1-2 17:20
解决了没。例子里用的回调函数,你是直接用的中断处理,不太清楚这两个有什么关系。
xxmmi 发表于 2022-1-2 17:25
能不能debug,看看死哪个循环了。
heweibig 发表于 2022-1-2 17:28
能不能debug,看看死哪个循环了。
页: [1] 2
查看完整版本: timer2进不了中断
