【N32G457 】OLED屏显示驱动
#申请原创#OLED屏有多种类型,按接口方式可分I2C接口和SPI接口方式,按色彩可分为单色、双色及彩色方式。此外,按几何尺寸分又有0.91寸、0.96寸等规格。从价格和占用引脚资源看,使用0.91寸I2C接口的单色屏是比较经济的。为此,可以硬件和软件2种方式来实现OLED屏的显示驱动。从使用灵活性的角度,这里采用软件的方式来实现,并按如下关系来连接:CLK---PE2DIN ---PE4图1 器件连接 故进行如下的定义:#defineCLK_PIN 1#defineDIN_PIN 3 #defineOLED_SCLK_Clr()rt_pin_write(CLK_PIN,PIN_LOW);#defineOLED_SCLK_Set()rt_pin_write(CLK_PIN,PIN_HIGH); #defineOLED_SDIN_Clr()rt_pin_write(DIN_PIN,PIN_LOW);#defineOLED_SDIN_Set()rt_pin_write(DIN_PIN,PIN_HIGH);为实现I2C方式发送数据,相应的函数为:void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
unsigned char m,da;
da=IIC_Byte;
OLED_SCLK_Clr();
for(i=0;i<8;i++)
m=da;
m=m&0x80;
if(m==0x80)
OLED_SDIN_Set();
else
OLED_SDIN_Clr();
rt_hw_us_delay(2);
da=da<<1;
OLED_SCLK_Set();
rt_hw_us_delay(2);
OLED_SCLK_Clr();
rt_hw_us_delay(2);
该OLED屏的初始化函数为:void OLED_Init(void)
Write_IIC_Command(0xAE);
Write_IIC_Command(0x40);
Write_IIC_Command(0xb0);
Write_IIC_Command(0xc8);
Write_IIC_Command(0x81);
Write_IIC_Command(0xff);
Write_IIC_Command(0xa1);
Write_IIC_Command(0xa6);
Write_IIC_Command(0xa8);
Write_IIC_Command(0x1F);
Write_IIC_Command(0xd3);
Write_IIC_Command(0x00);
Write_IIC_Command(0xd5);
Write_IIC_Command(0xf0);
Write_IIC_Command(0xd9);
Write_IIC_Command(0x22);
Write_IIC_Command(0xda);
Write_IIC_Command(0x02);
Write_IIC_Command(0x8d);
Write_IIC_Command(0x14);
Write_IIC_Command(0xdb);
Write_IIC_Command(0x49);
Write_IIC_Command(0xaf);
进行OLED屏的清屏函数为:void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
OLED_WR_Byte(0xb0+i,OLED_CMD);
OLED_WR_Byte(0x00,OLED_CMD);
OLED_WR_Byte(0x10,OLED_CMD);
for(n=0;n<128;n++) OLED_WR_Byte(0,OLED_DATA);
实现字符串显示的函数为:void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
unsigned char j=0;
while (chr!='\0')
使用以上函数,实现图2所示效果的程序代码为: rt_pin_mode(DIN_PIN, PIN_MODE_OUTPUT); OLED_Clear(); OLED_ShowString(20,0,"N32G457TEST",16); OLED_ShowString(20,2,"OLEDDISPLAY",16);图2 显示效果
显示为什么这么暗呢? daichaodai 发表于 2022-1-11 20:59
显示为什么这么暗呢?
使用时不小心,电源接反过一次,前半部分烧毁了,只能凑乎用了! 淘宝一块开发板,玩一玩!!! 这OLED被楼主玩坏了 应该是角度的问题,看上去像烧屏了呢!
页:
[1]
