五年前写的C++代码,好久没有用C++了,生疏了。
一个通信程序的会话管理部分:
#include <iostream>
#include <memory>
#include "InterfaceApiImp.h"
#include "Error.h"
#include "json/json.h"
#include <log4cxx/logger.h>
#include <log4cxx/logstring.h>
#include <log4cxx/propertyconfigurator.h>
#include "Log4cxxWrapper.h"
using namespace log4cxx;
extern LoggerPtr g_logger;
using namespace std;
void SessionImp::ProcessFrame(const char *buf, int length)
int i,len = length,count = 0;
string newFrame;
int pos=0;
len =0;
LoggerWrapper dsLog= LoggerWrapper::GetInstance();
if(buf == NULL){
dsLog.Log(true,LOGGER_ERROR,"buf == NULL , [%s][%s][%d]\n",__FILE__,__PRETTY_FUNCTION__,__LINE__);
for(i=0;i<length;i++){
if(buf == '\0'){
len = i-pos;
pos = i;
newFrame.clear();
newFrame.assign(m_rdBuffer.begin(),m_rdBuffer.end());
len += m_rdBuffer.size();
if(len>1){
OnFrame(newFrame);
m_rdBuffer.clear();
} else {
m_rdBuffer.push_back(buf);
return;
void SessionImp::SetConnection(Connection * conn)
LoggerWrapper& dsLog = LoggerWrapper::GetInstance();
if(conn == NULL){
dsLog.Log(true,LOGGER_ERROR,"%s:SessionImp::%s:%derror param",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return;
m_connection = conn;
int SessionImp::SendMessage(string &str)
int ret;
str =str+'\0';
if(m_connection != NULL){cout << "==================== ts cmd: " << str << endl;
ret = m_connection->Send(str.data(),str.length());
if(ret < 0){
dsLog.Log(true,LOGGER_ERROR,"%s:SessionImp::%s:%d",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return ret;
return -1;
void SessionImp::ShowReadBuf()
vector<char>::iterator iter;
for (iter = m_rdBuffer.begin(); iter != m_rdBuffer.end(); iter++){
cout << (*iter);
cout << endl;
TsSessionImp::TsSessionImp(/*ITsSessionUser *sessionUser,*/TsSession *tssession)
//m_sessionUser = sessionUser;
m_tssession = tssession;
m_sessionType = SESSION_TS;
//void TsSessionImp::SetSessionUser(ITsSessionUser *sessionUser)
void TsSessionImp::Close()
// close connect
struct TsSessionInfo *tsSessionInfo;
list<struct TsSessionInfo*>::iterator tlit;
SessionManagerImp& smi =SessionManagerImp::GetInstance();
m_connection->Close();
if (this->m_connection){
delete this->m_connection;
this->m_connection = NULL;
for (tlit = smi.m_tsSessionList.begin();tlit != smi.m_tsSessionList.end();tlit ++) {
tsSessionInfo = *tlit;
if(tsSessionInfo != NULL){
if(tsSessionInfo->session == this->m_tssession){
smi.m_tsSessionList.erase(tlit);
delete tsSessionInfo;
break;
delete this;
void TsSessionImp::OnData(const char *buf, int length, Connection *conn)
ProcessFrame(buf,length);
// called when user can write data to network.
void TsSessionImp::OnWrite(Connection *conn)
// called when the connection is broken, if user call Connection::Close(), //&&&
// will not get this callback.
void TsSessionImp::OnDisconnect(int reason, Connection *conn)
if(this->m_tssession != NULL)
smi.OnSessionClose(*this->m_tssession);
Close();
bool TsSessionImp::OnFrame(string &frame)
list<struct TsSessionInfo*>::iterator it;
//ITsSessionUser* tsSessionUser;
Json::Valuevalue;
std::auto_ptr<Json::Reader> pJsonParser(new Json::Reader(Json::Features::strictMode()));
ITsNewFrame* itsu;
if(!pJsonParser->parse(frame,value)){
dsLog.Log(true,LOGGER_ERROR,"message Decode error! %s : %s : %d",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return false;
if(value["type"].isNull() ||!value["type"].isString()){
return false;
if(value["type"] == "LinkResponse"){
for(it = smi.m_tsSessionList.begin();it != smi.m_tsSessionList.end();it ++) {//printf("@@@@@@@@@@@ leng:%d 0x%x (%d)\n",smi.m_tsSessionList.size(),it,__LINE__);
tsSessionInfo = *it;
tsSessionInfo->timeOut = 0;
break;
} else {
itsu= smi.GetTsNewFrame();
if(itsu == NULL){
dsLog.Log(true,LOGGER_ERROR,"%s:%s:%d smi.GetSessionUser() == NULL\n",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return false;
itsu->OnNewFrame(this->m_tssession,frame);
return true;
/////////////////////// ts client session ///////////////////////
void TsClientSessionImp::Close()
void TsClientSessionImp::OnData(const char *buf, int length, Connection *conn)
void TsClientSessionImp::OnWrite(Connection *conn)
void TsClientSessionImp::OnDisconnect(int reason, Connection *conn)
bool TsClientSessionImp::OnFrame(string &frame)
/////////////////// /// app server session /////////////////////
void AppServerSessionImp::Close()
delete this;
void AppServerSessionImp::OnData(const char *buf, int length, Connection *conn)
//printf("++++++++++++++++++++++++++++++++++: \n%s\n",buf);
dsLog.Log(true,LOGGER_DEBUG,"\n\n ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++\n MSG From App:\n%s\n",buf);
void AppServerSessionImp::OnWrite(Connection *conn)
void AppServerSessionImp::OnDisconnect(int reason, Connection *conn)
smi.OnSessionClose(*this);
Close();
bool AppServerSessionImp::OnFrame(string &frame)
IAppNewFrame* iael = smi.GetAppNewFrame();
if(iael == NULL){
dsLog.Log(true,LOGGER_ERROR,"GetAppEventListener error! %s : %s : %d",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return false;
iael->OnNewFrame(this->m_session,frame);
return true;
//////////////////////// app client session ///////////////////
void AppClientSessionImp::Close()
delete this;
void AppClientSessionImp::OnData(const char *buf, int length, Connection *conn)
void AppClientSessionImp::OnWrite(Connection *conn)
void AppClientSessionImp::OnDisconnect(int reason, Connection *conn)
Close();
bool AppClientSessionImp::OnFrame(string &frame)
Json::Valuevalue;
return false;
if(value["command"].isNull() ||!value["command"].isString()){
return false;
if(value["command"] == "response"){
cout << "app client OnDisconnect from(OnFrame) "<< endl;
Close();
} else {
dsLog.Log(true,LOGGER_ERROR,"this message may be not a AppClientSession message! %s : %s : %d",__FILE__,__PRETTY_FUNCTION__,__LINE__);
return false;
return true;
#include <iostream>
#include "ConfigManager.h"
#include "DataShow.h"
#include <execinfo.h>
#include <string.h>
#include "AppResultSubmit.h"
using namespace cdy;
SessionManagerImp::SessionManagerImp(/*SessionManager &wrapper*/)
//:m_appEventListener(NULL)
//,m_sessionUser(NULL)
:m_idleConnectionChecker(-1)
,m_connectionTimeout(-1)
//,m_timerHandler(NULL)
,m_dataShow(NULL)
struct timeval tv1={8, 0};
m_idleConnectionChecker = EventLooper::GetInstance().ScheduleTimer(&tv1, TF_FIRE_PERIODICALLY, this);
struct timeval tv2={1, 0};
m_connectionTimeout = EventLooper::GetInstance().ScheduleTimer(&tv2, TF_FIRE_PERIODICALLY, this);
SessionManagerImp::~SessionManagerImp()
if(m_appListener){
m_appListener->Stop();
deletem_appListener;
if(m_tsListener){
m_tsListener->Stop();
delete m_tsListener;
EventLooper::GetInstance().CancelTimer(m_idleConnectionChecker);
EventLooper::GetInstance().CancelTimer(m_connectionTimeout);
TimerID SessionManagerImp::NewTimer(unsigned int dwInterval,TimerHandler pTimerHander )
TimerID timerForApp;
struct timeval tv={dwInterval, 0};
timerForApp = EventLooper::GetInstance().ScheduleTimer(&tv, TF_FIRE_PERIODICALLY, this);
m_timerMap = pTimerHander;
printf("timerID: %d %s:%d\n",timerForApp,__FUNCTION__,__LINE__);
//if(m_timerHandler == NULL)
// m_timerHandler = pTimerHander;
return timerForApp;
void SessionManagerImp::KillTimer(TimerID id)
EventLooper::GetInstance().CancelTimer(id);
map<TimerID,TimerHandler>::iterator iTimer = m_timerMap.find(id);
if(iTimer !=m_timerMap.end())
m_timerMap.erase(iTimer);
//if(m_timerHandler != NULL)
// m_timerHandler = NULL;
SessionManagerImp& SessionManagerImp::GetInstance()
staticSessionManagerImp instance_;
return instance_;
bool SessionManagerImp::StartListenForAppServer(IAppNewFrame &appNewFrame)
LoggerWrapper &loggerUser = LoggerWrapper::GetInstance();
short port;
//IAppEventListener listener;
//m_appEventListener = &listener;
m_appNewFrame = &appNewFrame;
m_appResultSubmit = &DocAppResultSubmit::GetInstance();//&appResultSubmit;
m_appResultSubmit->add(&VideoAppResultSubmit::GetInstance());
m_appResultSubmit->add(&DpptAppResultSubmit::GetInstance());
m_appResultSubmit->add(&NoUseTsAppResultSubmit::GetInstance());
const string& addr = ConfigManager::GetIp();//appInfo.GetAppListenIp();
port =(short)ConfigManager::GetAppPort();//(short)appInfo.GetAppListenPort();
m_appListener = newAcceptor(addr, port,this);
return m_appListener->StartListen() == 0;
bool SessionManagerImp::StartListenForTS(ITsNewFrame &tsNewFrame,ITsServerLeave &tsServerLeave)
m_tsNewFrame = &tsNewFrame;
m_tsServerLeave = &tsServerLeave;
m_tsListener = newAcceptor(ConfigManager::GetIp(), (short)ConfigManager::GetTsPort(),this);
return m_tsListener->StartListen() == 0;
bool SessionManagerImp::DestoryConnectToServer(string ip,unsigned int port)
map<TargetAttributeT *,IConnectorAcceptor *>::iterator it;
for(it = m_longConnectors.begin();it != m_longConnectors.end();it ++){
if(((TargetAttributeT *)it->first)->ip == ip && ((TargetAttributeT *)it->first)->port == port){
// TODO: close this connection;
if(it->first != NULL)
delete it->first;
if(it->second)
delete it->second;
m_longConnectors.erase(it);
break;
void SessionManagerImp::SetDataShowProvider(IDataShowProvider &dataShow)
m_dataShow = &dataShow;
printf("####################### datashow: 0x%x\n",m_dataShow);
void print_trace(void)
int i;
const int MAX_CALLSTACK_DEPTH = 32; /* 需要打印堆栈的最大深度 */
void *traceback;/* 用来存储调用堆栈中的地址 */
/* 利用 addr2line 命令可以打印出一个函数地址所在的源代码位置
* 调用格式为: addr2line -f -e /tmp/a.out 0x400618
* 使用前,源代码编译时要加上 -rdynamic -g 选项
char cmd = "addr2line -f -e ";
char *prog = cmd + strlen(cmd);
/* 得到当前可执行程序的路径和文件名 */
int r = readlink("/proc/self/exe",prog,sizeof(cmd)-(prog-cmd)-1);
/* popen会fork出一个子进程来调用/bin/sh, 并执行cmd字符串中的命令,
* 同时,会创建一个管道,由于参数是'w', 管道将与标准输入相连接,
* 并返回一个FILE的指针fp指向所创建的管道,以后只要用fp往管理里写任何内容,
* 内容都会被送往到标准输入,
* 在下面的代码中,会将调用堆栈中的函数地址写入管道中,
* addr2line程序会从标准输入中得到该函数地址,然后根据地址打印出源代码位置和函数名。
FILE *fp = popen(cmd, "w");
/* 得到当前调用堆栈中的所有函数地址,放到traceback数组中 */
int depth = backtrace(traceback, MAX_CALLSTACK_DEPTH);
for (i = 0; i < depth; i++)
/* 得到调用堆栈中的函数的地址,然后将地址发送给 addr2line */
fprintf(fp, "%p\n", traceback);
/* addr2line 命令在收到地址后,会将函数地址所在的源代码位置打印到标准输出 */
fclose(fp);
void SessionManagerImp::SendAppMessage(const string addr,const unsigned int port,const string msg,void* pTaskMessage)
{//连接失败后尝试三次间隔时间暂定5分钟
static unsigned int ConnectTimes = 0;
Connector *connector=NULL;
static unsigned int connectErrorTimes = 0;
struct ConnectorInfo *connectorInfo;
if(addr == "" || msg == "" || port < 0){
printf("addr: %s msg: %s port:%d\n",addr.c_str(),msg.c_str(),port);
// print_trace();
dsLog.Log(true,LOGGER_ERROR," parameter error! line:%d\n",__LINE__);
return;
if (!connector)
connector = new Connector(addr, port, this);
try_connect:
if (connector->Connect(300) == 0){
connectorInfo = new struct ConnectorInfo;//(struct ConnectorInfo *)malloc(sizeof(struct ConnectorInfo));
if(connectorInfo == NULL){
dsLog.Log(true,LOGGER_ERROR," new struct ConnectorInfo error! \n");
return;
connectorInfo->msg = msg;
connectorInfo->re_connect_times = 0;
connectorInfo->pTaskMessage = pTaskMessage;
m_connectors = connectorInfo;
} else {
delete connector;
connectErrorTimes ++;
if (connectErrorTimes < 3){
goto try_connect;
return;
void SessionManagerImp::OnNewSession(SessionImp &session)
list<SessionImp*>::iterator alit;
if(session.m_sessionType == SESSION_APP_CLIENT){
} else if(session.m_sessionType == SESSION_APP_SERVER){
void SessionManagerImp::OnNewSession(TsSession &session)
void SessionManagerImp::OnSessionClose(SessionImp &session)
SessionImp *session_imp;
for (alit = m_appClientSessionList.begin();alit != m_appClientSessionList.end();alit ++) {
session_imp = *alit;
if(session_imp == &session){
m_appClientSessionList.erase(alit);
break;
for (alit = m_appServerSessionList.begin();alit != m_appServerSessionList.end();alit ++) {
m_appServerSessionList.erase(alit);
break;
void SessionManagerImp::OnSessionClose(TsSession &session)
if(m_tsServerLeave != NULL)
m_tsServerLeave->OnServerLeave(session);
for (tlit = m_tsSessionList.begin();tlit != m_tsSessionList.end();tlit ++) {//printf("@@@@@@@@@@@ leng:%d 0x%x (%d)\n",m_tsSessionList.size(),tlit,__LINE__);
if(tsSessionInfo->session == &session){
break;
void SessionManagerImp::OnConnection(Connection *conn, IConnectorAcceptor *ca)
int ret;
TsSession *ts_session;
//TsSessionImp *ts_session_imp;
TsClientSession *tsClientSession;
//TsClientSessionImp *tsClientSessionImp;
map<IConnectorAcceptor*,struct ConnectorInfo *>::iterator it;
map<TargetAttributeT *,IConnectorAcceptor *>::iterator lcit;
if(!ca){
return;
if (conn){
if (ca->IsConnector() == false){//accepter
if (ca == m_tsListener) {//ts
ts_session = new TsSession();
if(ts_session == NULL){
dsLog.Log(true,LOGGER_ERROR," new TsSession error! \n");
return;
conn->SetConnectionSink(ts_session->m_imp);
tsSessionInfo = new struct TsSessionInfo;
if (tsSessionInfo == NULL){
dsLog.Log(true,LOGGER_ERROR,"malloc error!\n");
tsSessionInfo->session = ts_session;
ts_session_imp = (TsSessionImp *)ts_session->m_imp;
//ts_session_imp->SetSessionUser(this->m_sessionUser);
ts_session_imp->SetConnection(conn);
m_tsSessionList.push_back(tsSessionInfo);
OnNewSession(*ts_session);
} else if (ca == m_appListener){ //app
session_imp = new AppServerSessionImp(conn/*,this->m_appEventListener*/);
if(session_imp == NULL){
dsLog.Log(true,LOGGER_ERROR," new AppServerSessionImp error! \n");
return;
conn->SetConnectionSink(session_imp);
m_appServerSessionList.push_back(session_imp);
OnNewSession(*session_imp);
} else {
} else {//connector
for(lcit = m_longConnectors.begin();lcit != m_longConnectors.end();lcit ++){
if((IConnectorAcceptor *)lcit->second == ca){
tsClientSession = new TsClientSession();
dsLog.Log(true,LOGGER_ERROR," new AppClientSessionImp error! \n");
return;
//conn->SetConnectionSink(session_imp);
//session_imp->SetConnection(conn);
conn->SetConnectionSink(tsClientSession->m_imp);
tsClientSession->m_imp->SetConnection(conn);
TsClientSessionInfoT *info = new TsClientSessionInfoT;
info->session =tsClientSession;//->m_imp->m_session;
info->ip = ((TargetAttributeT *)lcit->first)->ip;
info->port = ((TargetAttributeT *)lcit->first)->port;
m_tsClinetSessionList.push_back(info);
// TODO:OnNewSession(*session_imp);
return;
it = m_connectors.find(ca);
if(it != m_connectors.end()){//
session_imp = new AppClientSessionImp(conn);
return;
m_appClientSessionList.push_back(session_imp);
if(it->second != NULL){
ret = session_imp->SendMessage(it->second->msg);
m_appResultSubmit->OnResultSubmit(ret,it->second->pTaskMessage);
dsLog.Log(true,LOGGER_INFO,"Send app message:%s, %s:%s:%d",it->second->msg.c_str(),__FILE__,__PRETTY_FUNCTION__,__LINE__);
delete ca;
delete it->second;
m_connectors.erase(it);
} else {// error ,Can not find connector
dsLog.Log(true,LOGGER_ERROR,"Can not find connector! :%d",__LINE__);
delete ca;
} else {
//Added by wwz 160424 for test
printf("conn is NULL\n");
// cout << "not connected, try again!" << endl;
if (ca->IsConnector() == true){//connector
if(it == m_connectors.end()){//This connector does not exist
cout << "This connector does not exist :%d" << endl;
} else {
if(it->second->re_connect_times == 0){
it->second->re_connect_times = 3; //Join the Error handling map
} else {
if(it->second->re_connect_times == 1){//Connection failed three times
//Added by wwz 160424 for test,for connection failure
printf("connection failure,send task result fail!\n");
delete ca;
delete it->second;
m_connectors.erase(it); //it->second
} else {
it->second->re_connect_times -= 1;
void SessionManagerImp::OnTimer(TimerID tid)
string json;
Json::Value root;
root["type"] = "SvrLinkCheck";
map<TimerID,TimerHandler>::iterator iTimer;
//root.toStyledString();
json = root.toStyledString();
//SvrLinkCheck svrLinkCheck;
map<IConnectorAcceptor*,struct ConnectorInfo *>::iterator mit;
list<struct TsSessionInfo *>::iterator it;
//TsMessageBase *msg;
TsSession *tsSession;
if (tid == m_connectionTimeout){
for(mit = m_connectors.begin();mit != m_connectors.end();){
if(mit->second != NULL){
if(mit->second->re_connect_times >= 1){
if(((Connector *)(mit->first))->Connect(300) != 0){// Remove from map directly
if(mit->first != NULL)
delete mit->first;
delete mit->second;
m_connectors.erase(mit ++);
} else {
mit ++;
} else {
mit ++;
else
mit ++;
if (lcit->second == NULL){
if(((TargetAttributeT *)lcit->first)->reconnectInterval >= LONG_CONNECT_RETRY_INTERFAL){
if (!connector)
connector = new Connector(((TargetAttributeT *)lcit->first)->ip,((TargetAttributeT *)lcit->first)->port, this);
lcit->second = connector;
} else {
((TargetAttributeT *)lcit->first)->reconnectInterval = 0;
} else {
((TargetAttributeT *)lcit->first)->reconnectInterval += 1;
} else if(tid == m_idleConnectionChecker) {
for(it = m_tsSessionList.begin();it != m_tsSessionList.end();) {//printf("@@@@@@@@@@@ leng:%d 0x%x (%d)\n",m_tsSessionList.size(),it,__LINE__);
tsSessionInfo = *(it++);
if(tsSessionInfo == NULL){
dsLog.Log(true,LOGGER_ERROR," tsSessionInfo is NUL!");
return;
tsSession = tsSessionInfo->session;
if(tsSession == NULL){
dsLog.Log(true,LOGGER_ERROR," tsSession is NUL!");
return;
if(tsSessionInfo->timeOut == 1) {// Timeout handling
dsLog.Log(true,LOGGER_DEBUG,"Timeout handling!session:0x%x sessionimp:0x%x\n",tsSessionInfo->session,tsSessionInfo->session->m_imp);
OnSessionClose(*tsSessionInfo->session);
tsSession->Close();
} else {
tsSessionInfo->session->SendMessage(/**msg*/json);
tsSessionInfo->timeOut = 1;
//}else if(tid == m_timerForApp){
// m_timerHandler();
} else { //app timer handle
for(iTimer = m_timerMap.begin();iTimer != m_timerMap.end();++ iTimer){
if(tid == iTimer->first){
((TimerHandler)iTimer->second)();
break;
//IAppEventListener* SessionManagerImp::GetAppEventListener() const
// return m_appEventListener;
IAppNewFrame *SessionManagerImp::GetAppNewFrame() const
return m_appNewFrame;
//ITsSessionUser* SessionManagerImp::GetSessionUser() const
// return m_sessionUser;
ITsNewFrame* SessionManagerImp::GetTsNewFrame() const
return m_tsNewFrame;
void SessionManagerImp::ShowConnectors()
int i;
if(m_dataShow == NULL)
return;
m_dataShow->DataPrint("\n\n\n++++++ connectors:\n");
for(mit = m_connectors.begin(),i = 0;mit != m_connectors.end();mit ++,i ++){
m_dataShow->DataPrint("----------------the %dth elem: \n",i);
m_dataShow->DataPrint("connector: 0x%x\n",(Connector *)(mit->first));
m_dataShow->DataPrint("msg: %s\n",((struct ConnectorInfo *)mit->second)->msg.data());
m_dataShow->DataPrint("re_connect_times: %d\n",((struct ConnectorInfo *)mit->second)->re_connect_times);
m_dataShow->DataPrint("\n\n\n");
void SessionManagerImp::ShowTsSessionList()
int i;
return;
m_dataShow->DataPrint("\n\n\n++++++ ts_session_list:\n");
for(it = m_tsSessionList.begin(),i = 0;it != m_tsSessionList.end();it ++,i ++) {//printf("@@@@@@@@@@@ leng:%d 0x%x (%d)\n",m_tsSessionList.size(),it,__LINE__);
m_dataShow->DataPrint("----------------the %dth elem:\n",i);
m_dataShow->DataPrint("session: 0x%x\n",tsSessionInfo->session);
m_dataShow->DataPrint("timeOut:%d\n",tsSessionInfo->timeOut);
void SessionManagerImp::ShowAppServerSessionList()
int i;
return;
m_dataShow->DataPrint("\n\n\n++++++ app_server_session_list:\n");
for (alit = m_appServerSessionList.begin(),i = 0;alit != m_appServerSessionList.end();alit ++,i ++) {
m_dataShow->DataPrint("session_imp: 0x%x\n",*alit);
void SessionManagerImp::ShowAppClientSessionList()
int i;
return;
m_dataShow->DataPrint("\n\n\n++++++ app_client_session_list:\n");
for (alit = m_appClientSessionList.begin();alit != m_appClientSessionList.end();alit ++,i ++) {
页:
[1]
