zhangnan123 发表于 2022-1-12 15:36
PIC24EP512
PIC24EP512GUB814的串口程序中,接收中断一直进不去怎么回事,哪位大神能帮我看看程序吗?
/* Files to Include                                                         */
/* Device header file */
#if defined(__XC16__)
    #include <xc.h>
#elif defined(__C30__)
    #if defined(__PIC24E__)
            #include <p24Exxxx.h>
    #elif defined (__PIC24F__)||defined (__PIC24FK__)
        #include <p24Fxxxx.h>
    #elif defined(__PIC24H__)
        #include <p24Hxxxx.h>
    #endif
#endif
#include <stdint.h>      /* Includes uint16_t definition                  */
#include <stdbool.h>       /* Includes true/false definition                  */
#include "system.h"      /* System funct/params, like osc/peripheral config */
#include "user.h"          /* User funct/params, such as InitApp            */
#include "libpic30.h"      /* C30函数库                                       */
#include "common.h"
/* Global Variable Declaration                                                */
#define ModPulseCtl PORTDbits.RD1
/* i.e. uint16_t <variable_name>; */
uint8_t ReceivedState = 0;
uint8_t ReceivedChar = 0;
uint8_t UartReceivedData = {0,0,0,0} ;
uint16_t Int_Mask = 0;          /* 中断标志 */
/* Main Program                                                               */
void __attribute__ ( (interrupt, no_auto_psv) ) _U1RXInterrupt( void )
    IFS0bits.U1RXIF = 0;
    switch( ReceivedState )
      case 0:
                  ReceivedChar = U1RXREG;
                  if( ReceivedChar == 0x55 ) ReceivedState = 1;
                  else ReceivedState = 0;
                  break;
      case 1:
                  if( ReceivedChar == 0xAA ) ReceivedState = 2;
                  break;
      case 2:
                  UartReceivedData = U1RXREG;
                  ReceivedState = 3;
                  break;
      case 3:
                  ReceivedState = 4;
                  break;
      case 4:
                  ReceivedState = 5;
                  break;
      case 5:
                  ReceivedState = 6;
                  break;
      case 6:
                  if( ReceivedChar == 0x5A ) ReceivedState = 7;
                  break;
      case 7:
                  if( ReceivedChar == 0xA5 )
                        ReceivedState = 0;
                        Int_Mask = 1;
                  break;
/*此段关于串口的程序在网络传输时不需要*/
void __attribute__ ( (interrupt, no_auto_psv) ) _U1TXInterrupt( void )
    IFS0bits.U1TXIF = 0;
void __attribute__((interrupt, auto_psv)) _DMA0Interrupt(void)
_DMA0IF = 0; /* Clear DMA interrupt flag to prepare for next block */
int16_t main(void)
    /* Configure the oscillator for the device */
    ConfigureOscillator();
    /* Initialize IO ports and peripherals */
    Port_Inint();
    InitApp();
    Interrupt_Init();
    /* TODO <INSERT USER APPLICATION CODE HERE> */
    while(1)
    if( UartReceivedData == 0x01 )
    {ModPulseCtl = 1;
      U1TXREG= 0x23; }
    else
            ModPulseCtl = 0;
void InitApp(void)
Uart_Init();
void Uart_Init(void)
      U1MODEbits.STSEL = 0;         // 1-Stop bit
      U1MODEbits.PDSEL = 0;         // No Parity, 8-Data bits
      U1MODEbits.ABAUD = 0;         // Auto-Baud disabled
      U1MODEbits.BRGH = 0;            // Low-Speed mode
      U1MODEbits.UEN = 0;
      U1BRG = 20;                  // Baud Rate setting for 115200
      U1STAbits.URXISEL0 = 0;//Bits6,7 Int. on character recieved
      U1STAbits.URXISEL1 = 0;//Bits6,7 Int. on character recieved
      U1STAbits.UTXISEL0 = 0;
      U1STAbits.UTXISEL1 = 0;
      RPOR5bits.RP84R = 1;            //TXs
      RPINR18bits.U1RXR = 83;          //RX
      U1MODEbits.UARTEN = 1;// And turn the peripheral on
      U1STAbits.UTXEN = 1;
tpgf 发表于 2022-2-5 16:08
楼主 还需要看一下io的初始化程序
heimaojingzhang 发表于 2022-2-5 16:18
开始中断使能了吗
keaibukelian 发表于 2022-2-5 16:25
中断向量没有指错吧
labasi 发表于 2022-2-5 16:32
还需要开启总中断
paotangsan 发表于 2022-2-5 16:38
一次中断都不进入吗
renzheshengui 发表于 2022-2-5 16:46
有一个文件里边屏蔽了中断向量需要解除屏蔽
页: [1]
查看完整版本: PIC24EP512
