490864153 发表于 2022-1-15 10:50
GD32F103C8T6 CAN没有输出
回环模式,可以读取回数据,但是我重映射的PB8,PB9没有信号出来,外接的TJA1050,请问有遇到类似问题的吗?
代码如下
can_trasnmit_message_struct transmit_message;
can_receive_message_struct receive_message;
uint8_t CAN_Tx_Buf;
uint8_t CAN_Rx_Buf;
    \brief      initialize CAN and filter
    \paramcan_parameter
      \arg      can_parameter_struct
    \paramcan_filter
      \arg      can_filter_parameter_struct
    \param none
    \retval   none
void BSP_CANInit(void)
    can_parameter_struct          can_parameter;
    can_filter_parameter_struct   can_filter;
    /* configure CAN0 NVIC */
    nvic_irq_enable(USBD_LP_CAN0_RX0_IRQn,1,2);
    /* enable CAN clock */
    rcu_periph_clock_enable(RCU_CAN0);
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
    /* configure CAN0 GPIO */
    gpio_pin_remap_config(GPIO_CAN_FULL_REMAP,ENABLE);
    gpio_init(GPIOB,GPIO_MODE_IPU,GPIO_OSPEED_50MHZ,GPIO_PIN_8);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_9);
    /* initialize CAN and filter */
    can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT, &can_filter);
    /* initialize CAN register */
    can_deinit(CAN0);
    /* initialize CAN parameters */
    can_parameter.time_triggered = DISABLE;                                                        //TTC 时间触发通信        0: 禁用时间触发通信        1: 使能时间触发通信
    can_parameter.auto_bus_off_recovery = DISABLE;                        //ABOR 自动离线恢复        0: 通过软件手动地从离线状态恢复        1: 通过硬件自动的从离线状态恢复
    can_parameter.auto_wake_up = DISABLE;        //AWK 自动唤醒        0: 通过软件手动的从睡眠工作模式唤醒 1: 通过硬件自动的从睡眠工作模式唤醒
    can_parameter.no_auto_retrans = ENABLE;//DISABLE;        //ARD 自动重发禁止        0: 使能自动重发        1: 禁用自动重发
    can_parameter.rec_fifo_overwrite = DISABLE;                                        //RFOD 禁用接收FIFO满时覆盖        0: 使能接收FIFO满时覆盖        1: 禁用接收FIFO满时覆盖
    can_parameter.trans_fifo_order = DISABLE;                                                //TFO 发送FIFO顺序        0: 标识符(Identifier)较小的帧先发送        1: 所有等待发送的邮箱按照先进先出(FIFO)的顺序发送
#ifdef TEST_LOOPBACK
    can_parameter.working_mode = CAN_LOOPBACK_MODE;                                //回环模式
#else
    can_parameter.working_mode = CAN_NORMAL_MODE;                                //通信模式
#endif
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;                //SJW 再同步补偿宽度        再同步补偿占用的时间单元数量= SJW+1
    can_parameter.time_segment_1 = CAN_BT_BS1_6TQ;                        //BS1 位段1        位段1占用的时间单元数量=BS1+1
    can_parameter.time_segment_2 = CAN_BT_BS2_5TQ;            //BS2 位段2        位段2占用的时间单元数量=BS2+1
    can_parameter.prescaler = 6000 / CAN_BAUDRATE;                        //BRP 波特率分频系数
    /* initialize CAN */
    can_init(CAN0, &can_parameter);
    /* CAN0 initialize filter */
    can_filter.filter_number = 0;        //disable filter
//    can_filter.filter_mode = CAN_FILTERMODE_LIST;                                //FMx 过滤器模式        0: 掩码模式        1: 列表模式
    can_filter.filter_mode = CAN_FILTERMODE_MASK;                                //FMx 过滤器模式        0: 掩码模式        1: 列表模式
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;                        //FSx 过滤器位宽        0: 16-bit位宽        1: 32-bit位宽
    can_filter.filter_list_high = FILTER_LIST_HIGH;                        //FDx 过滤器数据
    can_filter.filter_list_low = FILTER_LIST_LOW;                                //FDx 过滤器数据
        //列表模式下:
        //0: 标识符的Bit(x)必须为0
        //1: 标识符的Bit(x)必须为1
    can_filter.filter_mask_high = FILTER_MASK_HIGH;                        //FDx 过滤器数据
    can_filter.filter_mask_low = FILTER_MASK_LOW;                                //FDx 过滤器数据
        //掩码模式下:
        //0: 标识符的Bit(x)不需参与比较
        //1: 标识符的Bit(x)需要参与比较
    can_filter.filter_fifo_number = CAN_FIFO0;                                        //FAFx 过滤器关联FIFO        0: 关联FIFO0        1: 关联FIFO1
    can_filter.filter_enable = ENABLE;        //FWx 过滤器激活        0: 没有激活        1: 激活工作
    can_filter_init(&can_filter);
    /* enable can receive FIFO0 not empty interrupt */
    can_interrupt_enable(CAN0, CAN_INTEN_RFNEIE0);
void CAN_process(void)//测试 1秒定时调用
                CAN_Tx_Buf = 0x55;
                CAN_Tx_Buf = 0xAA;
                CAN_Tx_Buf = 0x01;
                CAN_Tx_Buf = 0x02;
                CAN_Tx_Buf = 0x03;
                CAN_Tx_Buf = 0x04;
                CAN_Tx_Buf = 0x05;
                CAN_Tx_Buf = 0x06;
                BSP_CANWrite(CAN0, CAN_Tx_Buf);
void BSP_CANWrite(uint32_t can_periph, uint8_t *buff)
                uint8_t i;
    uint32_t timeout = 0xFFFF;
    uint8_t transmit_mailbox = 0;
#endif
                for (i = 0; i < 8; i++)
                                transmit_message.tx_data = buff;
    /* initialize transmit message */
    transmit_message.tx_sfid = TX_SFID;                                        //SFID/EFID 标识符
        //STID: 标准格式帧标识符
        //EXID: 扩展格式帧标识符
    transmit_message.tx_efid = TX_EFID;                                        //EFID: 扩展格式帧标识符
    transmit_message.tx_ft = CAN_FT_DATA;                                //FT 帧种类        0: 数据帧        1: 遥控帧
//    transmit_message.tx_ff = CAN_FF_STANDARD;                //FF 帧格式        0: 标准格式帧        1: 扩展格式帧
    transmit_message.tx_ff = CAN_FF_EXTENDED;                //FF 帧格式        0: 标准格式帧        1: 扩展格式帧
    transmit_message.tx_dlen = TX_DLEN;                                        //DLC 数据长度
#ifndef TEST_LOOPBACK
                /* transmit message */
                can_message_transmit(can_periph, &transmit_message);
#else
    transmit_mailbox = can_message_transmit(can_periph, &transmit_message);
    /* waiting for transmit completed */
    while((CAN_TRANSMIT_OK != can_transmit_states(can_periph, transmit_mailbox)) && (0 != timeout)){
      timeout--;
    timeout = 0xFFFF;
    /* waiting for receive completed */
    while((can_receive_message_length_get(can_periph, CAN_FIFO0) < (TX_DLEN - 1)) && (0 != timeout)){
      timeout--;
    /* initialize receive message*/
    receive_message.rx_sfid = 0x00;
    receive_message.rx_ff = 0;
    receive_message.rx_dlen = 0;
    receive_message.rx_data = 0x00;
    can_message_receive(CAN0, CAN_FIFO0, &receive_message);
                for(i = 0; i < TX_DLEN; i++)
                                System.com.can_rx = receive_message.rx_data;
                CAN_TO_USART(COM_RS422);
#endif
    \brief      this function handles CAN0 RX0 exception
    \paramnone
    \param none
    \retval   none
void CAN0_RX0_IRQHandler(void)
                uint8_t i;
                gd_eval_led_toggle();
    /* check the receive message */
//    if((TX_SFID == receive_message.rx_sfid) && (CAN_FF_STANDARD == receive_message.rx_ff) && (TX_DLEN == receive_message.rx_dlen))
    if((TX_EFID == receive_message.rx_efid) && (CAN_FF_EXTENDED == receive_message.rx_ff) && (TX_DLEN == receive_message.rx_dlen))
    }else{
GPIO_CAN_FULL_REMAP,PB8,9不是全映射,是半映射,data:image/png;base64,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**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**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
页: [1]
查看完整版本: GD32F103C8T6 CAN没有输出
