STM32 USART出现乱码
USART使用串口助手调试时出现乱码的情况,一般都是波特率的问题,例如:向串口发送“hello world\r\n”,但是串口助手收到的数据却是这样:于是我仔细检查代码中设置的波特率的大小,发现没错,也是设置为115200,但是串口助手上显示的还是乱码。我再仔细检查与USART相关的代码,包括UASRT初始化、中断、以及发送数据的类型。。。,很绝望,还是没有找出这个BUG!
以下是我的UASRT相关设置代码:
void Uart1_Init(void)
//GPIO端口设置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA的时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); //使能USART1时钟
//USART1对应引脚的复用
GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1);
GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);
//USART1端口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
//USART1 初始化
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);//使能USART1
//开中断
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;
NVIC_InitStructure.NVIC_IRQChannelSubPriority =3;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)
uint16_t Usart_Data;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
USART_ClearITPendingBit(USART1,USART_IT_RXNE);
Usart_Data = USART_ReceiveData(USART1);
USART_SendData(USART1, Usart_Data);
} main函数
int main(void)
int i, len;
char buffer = {"hello world\r\n"};
len = strlen(buffer);
NVIC_PriorityGroupConfig( NVIC_PriorityGroup_2);
Systick_Init();
Uart1_Init();
while(1)
for(i=0; i<len; i++)
USART_SendData(USART1, (uint16_t)buffer);
while(USART_GetFlagStatus(USART1,USART_FLAG_TC) == RESET);
delay_s(1);
} 。。。找了半天终于把问题找出来了,原来还是波特率的问题。虽然设置USART1时的波特率没错,但是系统的HSE_VALUE(高速外部时钟的值)与开发板实际的值不符,导致开发板串口的波特率与串口助手设置的不一致,这就是出现乱码的原因!USART1是挂载在AHB1,所以HSE_VALUE对UASRT1的波特率有影响。本人使用开发板的HSE为8MHz,而工程中默认为25MHz,故把它改过来即可。 打开工程里面的stm32f4xx.h文件,找到下图位置:
把其中的HSE_VALUE改为开发板实际的值即可
修改好重新编译下载到开发板中运行,此时串口助手能正常显示接收的数据。
页:
[1]
