wirelesswifi6 发表于 2022-2-10 13:21
Wallys Qualcomm Atheros QCN9074 Single Band 6GHz 4x4 WiFi 6E 802.11ax
DR9074-6E(PN02.7)
#QCN9074 802.11ax 4x4 MU-MIMO 6GHz #wifi6E
QCN9074 11ax 4x4 6G M.2
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Absolute Maximum Rating
ParameterRatingUnit
Operating Temperature Range-20 to 70ºC
Storage Temperature Range-40 to 90ºC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I²C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
QSDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.925GHz-7.125GHz
Data Rates for WALN
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz at 6GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
TBD
Reference Design
PN02.7
Dimensions (WxHxD)
57mm x 63mm x 6mm
页: [1]
查看完整版本: Wallys Qualcomm Atheros QCN9074 Single Band 6GHz 4x4 WiFi 6E 802.11ax
