juventus9554 发表于 2022-2-19 14:20
keil中的 target IRAM1 和 IRAM 以及 noInit 什么作用?
RAMx      Specify the ZI and RW areas, typically located in RAM space.
IRAMx      Specify the ZI and RW areas, typically configured through the startup-code.
default      The check box, in front of each entry, enables the area globally for the application. Individual modules may be assigned in the Properties dialog to specific areas.
off-chip/on-chip      Specifies whether this is an internal or external ROM or RAM.
Start      Specifies the starting address of the area in HEX format.
Size      Specifies how large the area is. Also in HEX format.
NoInit      Specifies areas that should be excluded from zero initialization.
juventus9554 发表于 2022-2-19 14:23
翻译过来还是意义不明确。。求大佬解释。
chuxh 发表于 2022-2-19 14:27
RAMx可以直接使用;
IRAMx不能直接使用,需要启动代码配置后才能使用,比如SDRAM;
NoInit就是不需要初始化为0的空间。
juventus9554 发表于 2022-2-19 14:29
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
页: [1]
查看完整版本: keil中的 target IRAM1 和 IRAM 以及 noInit 什么作用?
