灵动微 MM32F103CxT6硬件IIC
/*** @briefConfigures I2C Device port.
* @paramulSpeed I2C baudrate.
* @retval None
static void Config_I2cDevice ( uint32_t ulSpeed )
GPIO_InitTypeDef xGPIO_InitStruct;
I2C_InitTypeDef xI2C_InitStruct;
/* Enable clock. */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );
RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
/* Configure scl & sda GPIO parameters. */
xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_OD;
xGPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
xGPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_Init( GPIOB, &xGPIO_InitStruct );
/* Configure I2C parameters. */
xI2C_InitStruct.I2C_ClockSpeed = ulSpeed;
xI2C_InitStruct.I2C_Mode = I2C_Mode_MASTER;
xI2C_InitStruct.I2C_OwnAddress = 0x0;
if ( ulSpeed <= 100000 ) { /* Configure speed in standard mode */
xI2C_InitStruct.I2C_Speed = I2C_Speed_STANDARD;
} else { /* Configure speed in fast mode */
xI2C_InitStruct.I2C_Speed = I2C_Speed_FAST;
I2C_Init( I2C1, &xI2C_InitStruct );
/* Enable i2c1 port. */
I2C_Cmd( I2C1, ENABLE );
I2C 硬件驱动(a)、 根据官方提供源码修改,并且将其封装在 HAL_i2c 库文件内;
(b)、 该OLED 仅需要 写操作;
(c)、 在发送 STOP 停止信号前需延时 5us 才能正常显示(后续再找原因)。/**
* @briefWrites buffer of data to the I2C EEPROM.
* @parampxIO :typedef struct { GPIO_TypeDef* xPort; uint16_t usScl; uint16_t usSda; }I2C_GPIO_t;
* @parampBuffer : pointer to the buffercontaining the data to be written
* to the EEPROM.
* @paramWriteAddr : EEPROM's internal address to write to.
* @paramNumByteToWrite : number of bytes to write to the EEPROM.
* @retval None
ErrorStatus I2C_WriteBuffer( const I2C_GPIO_t* pxIO, I2C_TypeDef* I2Cx, uint8_t DeviceAddr, uint8_t WriteAddr, uint16_t NumByteToWrite, uint8_t* pBuffer)
uint32_t I2C_Timeout;
uint16_t write_Num;
xGPIO_InitStruct.GPIO_Pin= pxIO->usScl | pxIO->usSda;
xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init( pxIO->xPort, &xGPIO_InitStruct );
I2C_Cmd(I2Cx, DISABLE);
I2C_Send7bitAddress( I2Cx, DeviceAddr, I2C_Direction_Transmitter );
I2C_Cmd(I2Cx, ENABLE);
I2C_SendData( I2Cx, WriteAddr );
I2C_Timeout = 0x1000;
while ( ( I2C_GetFlagStatus( I2Cx, I2C_STATUS_FLAG_TFE ) ) == RESET ) {
if ( ( I2C_Timeout-- ) == 0 ) {
return ERROR;
for ( write_Num=0; write_Num<NumByteToWrite; write_Num++ ) {
return ERROR;
I2C_SendData( I2Cx, *( pBuffer + write_Num ) );
/* 96MHz 工作频率下,延时5us. */
for ( uint16_t i=480; i>0; i-- );
I2C_GenerateSTOP( I2Cx, ENABLE );
while ( ( I2C_GetITStatus( I2Cx, I2C_IT_STOP_DET ) ) == RESET ) {
return ERROR;
/* If all operations OK, return sEE_OK (0) */
return SUCCESS;
OLED 程序模块仅提供 Cmd & Data 部分,大部分和网络上的大同小异,可参考(正点原子、中景园电子、etc)。这篇**主要是 MM32 的 I2C/**
* @briefWrite commands to the screen.
* @paramucCmd Write command to be written.
* @retval None.
static void Screen_WriteCmd( uint8_t ucCmd )
I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x00, 1, &ucCmd );
* @briefWrite data to the screen.
* @paramucCmd Write data to be written.
* @retval None.
static void Screen_WriteDat( uint8_t ucDat )
I2C_WriteBuffer( &xConfig, I2C_DEVICE, I2C_ADDR, 0x40, 1, &ucDat );
这就可以了? 点赞 应该都需要 一定的延时吧 中景源电子主要开发哪个型号的开发板啊
也可以进行模拟
对时钟源要求是不是比较高了啊
如果时钟源不可靠了会不会就会通讯失败了啊
延时的原因是什么呢
之前使用ST的芯片,在I2C这部分就总是出现问题,现在灵动的应该好用多了。 这个没有bug吗 使用中断了吗 模拟iic它不香吗 硬件IIC不太习惯的
页:
[1]
