gaoyang9992006 发表于 2022-3-3 16:55
[N32G45x] +突然烧录不了的解决方法
@21小跑堂
收到开发板了,包装盒很漂亮,还送了一条非常给力的miniUSB数据线,然后就上级测试了。非常棒的板子,Lib库函数很好用。
开发板上自带三个LED,都标注了连接到了哪个IO引脚。
绿色LED----PB5
蓝色LED----PB4
红色LED----PA3
其中PB4引脚比较特殊,一定要记得看手册与提供的相关例子。
* Copyright (c) 2019, Nations Technologies Inc.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* - Redistributions of source code must retain the above copyright notice,
* this list of conditions and the disclaimer below.
* Nations' name may not be used to endorse or promote products derived from
* this software without specific prior written permission.
* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY NATIONS "AS IS" AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
* DISCLAIMED. IN NO EVENT SHALL NATIONS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* @file main.c
* @author Nations
* @version v1.0.0
* @CopyRight Copyright (c) 2019, Nations Technologies Inc. All rights reserved.
#include "main.h"
#include <stdio.h>
#include <stdint.h>
* @briefInserts a delay time.
* @param count specifies the delay time length.
void Delay(uint32_t count)
    for (; count > 0; count--)
* @briefConfigures LED GPIO.
* @param GPIOx x can be A to G to select the GPIO port.
* @param Pin This parameter can be GPIO_PIN_0~GPIO_PIN_15.
void LedInit(GPIO_Module* GPIOx, uint16_t Pin)
    GPIO_InitType GPIO_InitStructure;
    /* Check the parameters */
    assert_param(IS_GPIO_ALL_PERIPH(GPIOx));
                        //使用PB4作为IO。
                GPIO_ConfigPinRemap(GPIO_RMP_SW_JTAG_SW_ENABLE,ENABLE);
                RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_AFIO, ENABLE);
    /* Enable the GPIO Clock */
    if (GPIOx == GPIOA)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
    else if (GPIOx == GPIOB)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    else if (GPIOx == GPIOC)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOC, ENABLE);
    else if (GPIOx == GPIOD)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOD, ENABLE);
    else if (GPIOx == GPIOE)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOE, ENABLE);
    else if (GPIOx == GPIOF)
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOF, ENABLE);
    else
      if (GPIOx == GPIOG)
            RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOG, ENABLE);
    /* Configure the GPIO pin */
    if (Pin <= GPIO_PIN_ALL)
      GPIO_InitStructure.Pin      = Pin;
      GPIO_InitStructure.GPIO_Mode= GPIO_Mode_Out_PP;
      GPIO_InitPeripheral(GPIOx, &GPIO_InitStructure);
* @briefTurns selected Led on.
void LedOn(GPIO_Module* GPIOx, uint16_t Pin)
    GPIOx->PBSC = Pin;
* @briefTurns selected Led Off.
void LedOff(GPIO_Module* GPIOx, uint16_t Pin)
    GPIOx->PBC = Pin;
* @briefTurns selected Led on or off.
* @param Pin This parameter can be one of the following values:
*@ARG GPIO_PIN_0~GPIO_PIN_15: set related pin on
*      @ARG (GPIO_PIN_0<<16)~(GPIO_PIN_15<<16): clear related pin off
void LedOnOff(GPIO_Module* GPIOx, uint32_t Pin)
    GPIOx->PBSC = Pin;
* @briefToggles the selected Led.
void LedBlink(GPIO_Module* GPIOx, uint16_t Pin)
    GPIOx->POD ^= Pin;
* @brief Assert failed function by user.
* @param file The name of the call that failed.
* @param line The source line number of the call that failed.
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
    while (1)
#endif // USE_FULL_ASSERT
* @briefMain program.
int main(void)
    /*SystemInit() function has been called by startup file startup_n32g45x.s*/
    LedInit(GPIOB, GPIO_PIN_ALL);
    LedInit(GPIOA, GPIO_PIN_ALL);
                LedOnOff(GPIOA, GPIO_PIN_ALL);
                LedOnOff(GPIOB, GPIO_PIN_ALL);
    while (1)
                        LedBlink(GPIOB,GPIO_PIN_ALL);
                        LedBlink(GPIOA,GPIO_PIN_ALL);
                        Delay(0x28FFFF);
这是让3个LED一起闪烁的Blink程序。
当我测试完这个跑马灯后,就因为忙,先放一边了。今天下午突然来用,发现烧录不进去了,报错如下:
刚开始我以为板子坏了呢,找了好多原因没找到。。。
终于找到了可能的原因,测试一下,OK,好了。
方法:
1.板子上电之前先将BOOT0引脚接到3.3V高电平
2.板子上电
3.BOOT0置低电平
4.重新烧录程序开发板上对应针脚位置如下图所示。
这属于把SWD和JTAG都给关了,程序下载不进去了。
如果你遇到突然下载不进去的时候,可以试试这个方法,看看是不是在自己不经意的时候关闭了下载端口功能。
598330983 发表于 2022-3-3 17:09
感谢分享经验啊,我有个其他厂家板子也是这个问题,我去试试看
hayden0 发表于 2022-3-3 17:36
我的N32L436板子PB4没这问题,不会关掉SWD
单片小菜 发表于 2022-3-7 10:38
主要看看电压是否正确,如果电压没有问题的话,都好说了。
两只袜子 发表于 2022-3-9 15:27
关键在于电压把
一路向东 发表于 2022-4-19 19:00
无法烧录的情况,可能原因
1)SWD口配置了读写保护L1和L22)SWD口的PA13和PA14脚IO口配置被更改 3)IO驱动能力不足,SWD接线过长等
解决方法:
1)读保护L1,可以上拉boot0脚,连接SWD口或者使用国民download tool连接PA9和PA10串口,解除读保护后恢复2)IO配置被更改,可以 上拉boot0脚,芯片复位,重新连接SWD口,全擦除后恢复
3)写保护L2配置后,SWD口被锁死,不可恢复。
4)IO驱动能力不足:线尽量短;仿真速率调低;SWDIO接10K上拉,SWDCLK接10K下拉;IO配置提高驱动能力,内部上下拉等
有其他的大家可以一起补充
无法烧录的情况,可能原因
1)SWD口配置了读写保护L1和L22)SWD口的PA13和PA14脚IO口配置被更改 3)IO驱 ...
总结的很全面。
麻花油条 发表于 2022-4-20 11:04
七楼的问题解决思路很不错
七楼的问题解决思路很不错
是的,他总结的很全面,我只是发了一下,我这次遇到的那种问题的。
jiekou001 发表于 2022-4-26 18:50
感谢分享,我的那个板子可能也是这个问题。
zhuomuniao110 发表于 2022-11-16 22:12
PB4这个端口有 特别的吗,我看有人说点不亮。
PB4复位后默认是JTAG功能口,需要remap配置关闭JTAG,只打开SWD功能,之后再按照GPIO配置即可
klbyf 发表于 2024-4-15 16:50
谢谢!
dongnanxibei 发表于 2024-4-18 16:34
很有用的方法。
页: [1]
查看完整版本: [N32G45x] +突然烧录不了的解决方法
